[help]asus x510unr rev 3 dead
  • phantomEVO
    • Mar 2013
    • 488
    hi friend, please help with this motherboard. i don't know the history. but it is totally dead!
    when i insert power supply i have full short!
    i have found short to ground on pl8302.
    removing pl8302 i have short only on one side: +1.0VSUS
    i've removed jumper pjp8303 and i have short on both sides.
    i've descovered (i don't remember how) that removing PU8302 i haven't full short connecting power supply
    i've discovered that i have FULL SHORT ON +1.0VSUS
  • mon2
    • Dec 2019
    • 14012
    Re: [help]asus x510unr rev 3 dead
    Remove all power -> meter in the lowest scale -> measure the resistance to ground of this rail. Post the resistance reading and meter scale used for the measurement.
    If the resistance is very low, the CPU could be dead.
    • phantomEVO
      • Mar 2013
      • 488
      with my fluke 17b+ SCALE AUTO (red probe on ground black on 1.0vsus) i have 0,7 ohm
      • mon2
        • Dec 2019
        • 14012
        Check the attached and remove the parts in 'X' to see if the low resistance to ground is due to the filter caps.
        • phantomEVO
          • Mar 2013
          • 488
          in the motherboard (rev 3) there aren't the 4 capacitor... so it's not a capacitor problem.
          i'v removed capacitor PCE8302 with no luck
          • mon2
            • Dec 2019
            • 14012
            After removing PCE8302, which side of PJP8303 has the low resistance ? Both pins ??
            • phantomEVO
              • Mar 2013
              • 488
              0.7 ohm left side (1.0vsus)
              11.7 ohm right side
              • phantomEVO
                • Mar 2013
                • 488
                maybe its' a cpu fault?
                • phantomEVO
                  • Mar 2013
                  • 488
                  help!
                  • mon2
                    • Dec 2019
                    • 14012
                    Confirm the partial schematic posted earlier. If you have broken each of the 'X' marked PCB jumpers, why is there such a low resistance to ground on the LEFT side = regulator side of the traces ?
                    That is almost a direct solder short to ground.
                    Locate the root cause of this fault.
                    The right side is the consumer (load) side and ~11 ohms may be ok for a CPU. CPU designs these days are current sucking pigs (not to be confused with the salt eating women of Star Trek).
                    • phantomEVO
                      • Mar 2013
                      • 488
                      i cant broke the jumper, because those jumpers are not present on the motherboard...
                      please open the board view and you will see
                      • mon2
                        • Dec 2019
                        • 14012
                        Which jumper are you referencing ? Each jumper is fixed on the logic board ?
                        Only pjp8303 has been removed ?
                        If yes, focus on the 2 mosfets linked to this voltage rail.
                        Place the meter in resistance mode. Remove all power.
                        Check the resistance of the following mosfet pins:
                        source (1-2-3) & drain (5-6-7-8)
                        source (1-2-3) & gate (4)
                        gate (4) & drain (5-6-7-8)
                        Review the above for PQH8301 and PQL8302. Post the resistance readings.
                        • phantomEVO
                          • Mar 2013
                          • 488
                          psp8303 and psp8302 are not present, nor visible on the motherboard i can see only a VIA
                          i can see and remove pjp8303 and it has been removed from the beginning to isolate the vsus line
                          PQH8301
                          Source drain 1,6 ohm
                          source gate 132 ohm
                          gate drain 132 ohm
                          pql8302
                          Source drain 11,8 ohm
                          source gate 1,8 mohm
                          gate drain 4 mohm
                          BUT I REMEMBER YOU THAT I HAVE REMOVED pl8302 to isolate the line...one line is connected to those mosfets.... removing it, i have short only tho the other side...so it's not a mosfet problem!
                          • mon2
                            • Dec 2019
                            • 14012
                            Can you confirm the measurements for PQH8301 mosfet?
                            Which scale on your meter was used?
                            These are very low resistance values and appears to be shorted.
                            • phantomEVO
                              • Mar 2013
                              • 488
                              i confirm...autoscale mode but even removing it, i still have short on both side of pjp8303
                              cutting psl8303 i have short only on one side of pjp8303 (pin 2 vsus line)
                              vsus line has also two jumper sl2632 and sl2623...and they come always to u0301....so i think that u0301 is the problem...
                              • mon2
                                • Dec 2019
                                • 14012
                                Ok. To confirm, you have PL8302 lifted by one leg or removed from the board ?
                                Still have this low resistance ? Then review the trace with PSP8302 -> leads to a resistor @ PR8313. Is this correct ?
                                Remove PR8313 but do not lose it.
                                After removing PR8313, do you still have this very low resistance to ground ?
                                • phantomEVO
                                  • Mar 2013
                                  • 488
                                  Removed from one side. But Why you care about pl8302? Cutting psp8302 like i said, i have short only on one side pjp8303…And the side not shorted is connected to pl8302…
                                  However, now I’m outsider: when i come Back, i will check for you!!!! THANKS!!
                                  • phantomEVO
                                    • Mar 2013
                                    • 488
                                    resistor removed, stil 0,9ohm on 1vsus
                                    • Beton
                                      Finding a dead short component
                                      by Beton
                                      Hi guys!
                                      I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                      So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                      I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                      I have a bench PSU and if I try to inject voltage the voltage...
                                      12-10-2021, 01:05 PM
                                    • Prott
                                      Gigabyte GTX1080 - identifying a dead short on vmem
                                      by Prott
                                      Hey!
                                      I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
                                      I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
                                      Is there any way to narrow down the search for a short? I would prefer not to remove...
                                      07-04-2023, 06:29 AM
                                    • DynaxSC
                                      Extreme High Current & Low Voltage Short Killer ??
                                      by DynaxSC
                                      Hi Folks
                                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                      After taking off the socket, the shorts dissappear again.
                                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                      10-15-2024, 10:13 AM
                                    • JimMc0
                                      Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
                                      by JimMc0
                                      Hi there,
                                      I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
                                      The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
                                      03-27-2024, 08:36 AM
                                    • Mabot17
                                      ASUS gaming laptop GL704GV GPU DEAD SHORT
                                      by Mabot17
                                      Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                      i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                      Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                      05-10-2025, 11:04 AM
