asus x2020e no power
  • kalilinux25
    • Mar 2018
    • 2085
    • ZAMBOANGA SIBUGAY
    I just waited the battery to arrive because the board has battery issue the after testing the laptop it wont turn on at all..
    CHECK
    1st , 2nd mosfet not shorted
    pq8801 pin4 0v
    pin 321 0.9v
    pin 5 19v
    voltage wont pass throught the second mosfet im missing a signal at pin 4 of the first mosfet
    cehcking the charging IC PU8800
    PIN1 - 0.9V
    PIN2 - 0.9V
    PIN3 - 0.4V
    PIN4 - 0.4V
    PIN5 - 0V
    PIN6 - 3.1V
    PIN7 - 0V
    PIN8 - 0V
    PIN9 - 0V
    PIN 10 - 0V
    PIN 11 - 1.5V
    PIN 12 - 0.9V
    PIN13 - 0.9V
    PIN 14 - 0V
    PIN 15 -0V
    PIN 16 - 6.0V
    PIN 17 - 5.8V
    PIN 18- 0.9V
    PIN 19 - 0.9V
    PIN 20 - 20V
    hope someone can tell if the charger ic is dead or not?
  • kalilinux25
    • Mar 2018
    • 2085
    • ZAMBOANGA SIBUGAY
    Re: asus x2020e no power
    this is the boardview no available schematic BOARD: X202E REV 2.0
    • kalilinux25
      • Mar 2018
      • 2085
      • ZAMBOANGA SIBUGAY
      my ACDET is 3.1 must be 3.3v an
      and BATDRV must be 12.4v I get only 1.5v
      also missing acok
      • kalilinux25
        • Mar 2018
        • 2085
        • ZAMBOANGA SIBUGAY
        I also dried a working charer ic like this BQ24735RGRR readings didnt change. board ic is a bq24725A
        • kalilinux25
          • Mar 2018
          • 2085
          • ZAMBOANGA SIBUGAY
          overall trying to repair the issue it was just have a bad bios now itws working
          • kalilinux25
            • Mar 2018
            • 2085
            • ZAMBOANGA SIBUGAY
            i used this
            • mon2
              • Dec 2019
              • 14106
              Good job! Thanks for the closure.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Not very convinced. Never had a case where bios flash solved +19V not passing on to CLR. It may be 'coz of heat applied during bios chip solder/desolder.
                • kalilinux25
                  • Mar 2018
                  • 2085
                  • ZAMBOANGA SIBUGAY
                  yes also its my first time ncountring this type of issue
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • Scotchmist
                    Asus GA502D keeps blowing mosfet
                    by Scotchmist
                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                    I have removed the mosfet and can run the laptop no problem
                    The MOSFET is FDPC5018SG
                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                    08-24-2024, 02:23 PM
                  • MicroSMD Lab
                    ASUS ROG Zephyrus GPU Mosfet repeat failure
                    by MicroSMD Lab
                    The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
                  • Timp74
                    Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                    by Timp74
                    Hi All,
                    Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                    I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                    08-13-2021, 01:11 PM
                    ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                    This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                    09-07-2024, 02:50 AM
