ASUS X556UJ_MB rev 2.0 touchpad
Re: ASUS X556UJ_MB rev 2.0 touchpad
Yes, looks correct. Concern is for the low voltage readings of the I2C track pad lines.
Remove the esd diode you have near this connector and measure the voltage readings again. Test again without the esd protection array.Comment
Well i'm an idiot. We know now that pin5 is ground (not pin4) so I traced a ground to a ground on a mosfet that potentially has nothing to do with the trackpad?This is nearly the exact board version I have:
https://devicedb.xyz/dev/file/3886-a...boardview-asc/
I think the boardview files here at badcaps for X555UJ are not quite for this one.
Mine is 60nb0ag0-mb1112
I traced continuity from pin5 to this chip:Comment
Basically, anything to do with the trackpad in boardview is missing on this mainboard, both sides of the board, leading to the embedded controller.
i've put that little mosfet back on, but the voltages did not change.Comment
The touchpad is really x555uj, not x555l? Same problem. The x555l is not i2c.Comment
			by rheyntauCAN ANY ONE HELP ME WITH THIS PROBLEM....ASUS C202SA CHROMEBOOK TOUCHPAD NOT WORKING AFTER INSTALL WINDOWS 10 ..IT WAS ELAN TOUCHPAD..I DOWNLOAD A DRIVER BUT ITS NOT WORKING IT SAYS "WINDOWS FOUND DRIVERS FOR YOUR DEVICE BUT ENCOUNTERED ERROR.....THE HASH FOR THE FILE ISNOT PRESENT INTHE SPECIFIED CATALOG......."
			by jamespHello guys,
need help, i have a laptop that i encountered having keyboard and touchpad not working, not immediately going to BIOS i already tried replacing even just the keyboard with a new one but still problem exists. now i only realized to checked it from bios to erase doubts. i found out both touchpad and keyboard are working only on BIOS but not on windows.
since i cant just reformat the said laptop, i tried installing MyAsus utility and updated my drivers , and windows update as well. i included updating the bios to latest 3.08 version. still kb and touchpad is working on bios... -
			This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
			by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... -
			by RhaverzGood afternoon friends
I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
I even checked that the data bus made a connection between the touchpad and the motherboard and everything... - Loading...
