a2289 no wecam
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    a2289 no wecam
    this a2289 had a no power problem , got 3v3ssd short , fixed found a shoted caps.
    Now i got no webcam detected , i see on system report but no work .
    All flex cable are connected
  • mon2
    • Dec 2019
    • 14315
    Re: a2289 no wecam
    The system report is NOT showing the webcam ?
    Check the voltage @ L8504, pin # 1.
    Check that no pins are bent on the connectors between the logic board & camera cable. Only inspect the camera connector pins with all power removed.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      Re: a2289 no wecam
      system report show it
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        Re: a2289 no wecam
        5v
        • mon2
          • Dec 2019
          • 14315
          Re: a2289 no wecam
          If the system report shows it then this implies the configuration channels for the webcam are present.
          The configuration / detection will be over the I2C_xx lines linked to the camera connector. This is assumed to be ok since the camera has been detected.
          After configuration, the data flow of the video capture will be over the MIPI_xx lines. MIPI will consist of pairs of signals for the clock & data lanes.
          The camera is a single MIPI LANE device.
          So there are 2 pins for the CLK (CLKN; CLKP).
          Also 2 pins for the DATAP; DATAN data signal lines.
          Each set is a differential pair of lines that swing at very low voltages so they can communicate at very high data rates. The interface is looking for the difference between the 'P' and 'N' lines to determine if it is a high or a low signal.
          Verify that the EMI filter is not broken @ L8502 & L8503. These filter the MIPI lines.
          Then there is a MIPI multiplexer @ U8502.
          What is the voltage of SEP_CAM_DISABLE_DFF_L ?
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            Re: a2289 no wecam
            i checked the flex cable i have 5v on board and on pin 46 but no continuity with other side ? its right
            • lordgeny
              • Apr 2016
              • 223
              • Italia
              Re: a2289 no wecam
              thats it
              • lordgeny
                • Apr 2016
                • 223
                • Italia
                Re: a2289 no wecam
                anyone with same flex can confirm that its pin number on pics?
                aniway any pin will beep
                • mon2
                  • Dec 2019
                  • 14315
                  Re: a2289 no wecam
                  I do not believe this will be the fault since the webcam is being detected.
                  If you do NOT connect this connector, does the webcam get removed from the list of hardware?
                  If the webcam is being found, it is being powered.
                  Perhaps others will share their comments.
                  • lordgeny
                    • Apr 2016
                    • 223
                    • Italia
                    Re: a2289 no wecam
                    fixed with new flex cable
                    • mon2
                      • Dec 2019
                      • 14315
                      Re: a2289 no wecam
                      Good job and thank for the update.
                      My bad is that:
                      (hindsight is 20/20)
                      1) Camera is a MIPI CSI interface
                      2) Now we know that detection of the camera is only a small portion of the interface that was known to be working with your logic board & cable.
                      3) The logic board was able to communicate / configure the CSI camera but the raw data BACK from the camera was broken - a single disconnected wire can cause the host to receive BLACK / NO VIDEO from the webcam.
                      4) The first 2 lines (pair) of the MIPI interface are bidirectional in that it is used in low speed mode (LP) to configure the MIPI device (CSI = camera in this case) while the balance of the MIPI lines are high speed and unidirectional (spits out data from the CAMERA to the HOST in this case).
                      For a MIPI DSI (display panel), the host spits out data to the LCD panel.
                      • lordgeny
                        • Apr 2016
                        • 223
                        • Italia
                        Re: a2289 no wecam
                        now this shitty , doesnt detect the battery
                        • mon2
                          • Dec 2019
                          • 14315
                          Re: a2289 no wecam
                          Measure the voltages on the esd diodes on the battery pack. These are the smbus lines (sda and clk).
                          Post the voltage readings.
                          • lordgeny
                            • Apr 2016
                            • 223
                            • Italia
                            Re: a2289 no wecam
                            SMBUS_3V3_BATT_SCL 3.3
                            SMBUS_3V3_BATT_SDA 3.3
                            SYS_DETECT_L not present
                            PP3V3_G3H_BMU 3.3
                            • mon2
                              • Dec 2019
                              • 14315
                              Re: a2289 no wecam
                              Is the battery known to be good?
                              Is the battery dead or charged?
                              With the battery only, does the battery voltage reach the battery mosfet to run the logic board?
                              What is the voltage on SYS_DETECT_L ?
                              Also post the measurements for:
                              I2C_PWR_SCL_R1
                              I2C_PWR_SDA_R1
                              • lordgeny
                                • Apr 2016
                                • 223
                                • Italia
                                Re: a2289 no wecam
                                I2C_PWR_SDA_R1 1.8
                                I2C_PWR_SCL_R1 1.8
                                SYS_DETECT_L none
                                yeas i have 1.8v at f7000
                                i dont know if battery are ok or not .
                                i Found the flex j6950 damaged i maked jumper looking at schematics , but still no charging/not detected
                                • lordgeny
                                  • Apr 2016
                                  • 223
                                  • Italia
                                  Re: a2289 no wecam
                                  with new battery it works ... thanks
                                    Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                                    09-07-2024, 07:20 AM
                                    09-07-2024, 06:38 AM
