macbook pro A1398 (820-3332-A)
  • salawayon
    • Nov 2012
    • 568
    • philippines
    got a macbook pro A1398 (820-3332-A) with an orange light on charger even battery is not connected. board is clean with no signs of liquid damage. upon checking for any short circuit via multimeter, at L7550/L7560 gives only 1ohms, and at L7510/L7520/L7530 gives only 0.9ohm. and if i set to Diode mode or continuity test at those points it gives a ZERO reading. most likely a damaged U1000?
  • reformatt
    • Feb 2020
    • 1400
    Re: Troubleshooting dead Apple MacBook Pro A1398 (820-00426-A)
    Not enough info to draw that conclusion, but it is low. Usually if you have a shorted CPU, then one of the high side MOSFET's is shorted and PPBUS_G3H is also shorted to ground as a result. Often this is from an issue with the PWM driver IC (in this case U7400). This can be from liquid damage, or even the decomposing corpse of a dead bug next to that IC.
    Do 1V voltage injection with thermal camera. You might be lucky and it's a shorted cap or low side MOSFET.
    • piernov
      • Jan 2016
      • 4435
      • France
      When it is warm, Ivy Bridge can measure close to 1 ohm.
