macbook retina A1398 820-00138 works slowly
  • sdogs
    • Feb 2016
    • 86
    • Italy
    Hi, ;-)
    i am trying to understand what is happening to this macbook retina 15 A1398 from 2015 year with logic 820-00138.
    The macbook had a swollen battery, it seemed to explode, removed the battery the macbook has power, starts without errors but is very slow, very slow. From resource monitoring all cpu cores work very high even without applications started.
    I tried another trackpad flat, I disconnected the webcam, I disconnected the wifi card, I tried another IO board, I tried with more SSD hard drives.
    I did apple hardware test, no errors, checked all sensors and temperatures are ok, has no damaged components, carefully observed under microscope, could it be bad SMC?
    I made the following measurements:
    PPBUS_G3H 12,60v
    PPVIN_S5_HS_COMPUTING_ISNS 12,60v
    PPVIN_S5_HS_OTHER3V3_ISNS 12,60
    PPVIN_S5_HS_OTHER5V_ISNS 12,60
    PPDCIN_G3H 18
    PPDCIN_G3H_ISOL 18
    PP3V42_G3H 3,4
    PPVRTC_G3H 3,3
    PP5V_S5 5
    PP5V_S4 5
    PP5V_S3 5
    PP5V_S0 5
    PP3V3_S5 3,3
    PP3V3_S4 3,3
    PP3V3_SUS 3,3
    PP3V3_S3 3,3
  • mon2
    • Dec 2019
    • 14169
    Re: macbook retina A1398 820-00138 works slowly
    https://www.ifixit.com/Answers/View/...t+battery+swap
    • piernov
      • Jan 2016
      • 4435
      • France
      MacBooks require a good battery to work properly.
      • sdogs
        • Feb 2016
        • 86
        • Italy
        forgive my inexperience, so if I start it now with no battery connected will it work slowly?
        • piernov
          • Jan 2016
          • 4435
          • France
          https://logi.wiki/index.php/Throttling
          • sdogs
            • Feb 2016
            • 86
            • Italy
            thanks for the information, they were very useful, however the problem remained, I tried an original and working battery and even with this connected it does not start. It sees the battery and the remaining charge but if I turn off the power it turns off completely, as if it were not connected.
            • mon2
              • Dec 2019
              • 14169
              ?? If you remove the external and original power adapter, the logic board will turn OFF even if you have the battery connected ?
              • sdogs
                • Feb 2016
                • 86
                • Italy
                yes, if I turn off the power, it turns off. when it is on it sees the battery and the remaining charge
                • mon2
                  • Dec 2019
                  • 14169
                  Using the battery ONLY (no power adapter) - meter in DC volts (20v scale is ok), check the attached points of interest.
                  Measure each and post the readings.
                  • sdogs
                    • Feb 2016
                    • 86
                    • Italy
                    f7140 pin n2 12,30v
                    q7155 pin 5 12,30v
                    c7145 pin 1 12,30v
                    r7150 pin 1-3 12,30v
                    unfortunately the scheme is different from the logic board, I am attaching a photo, I hope I have measured well
                    • mon2
                      • Dec 2019
                      • 14169
                      f7140 pin n2 12,30v
                      PPBUS_G3H is too low. This means that the SMC has not boosted the value with the battery only case.
                      reference:
                      https://www.logi.wiki/index.php?title=PPBus_G3H
                      See attached. Check the voltage on D7050 dual ESD diode with the battery ONLY attached.
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        You asked to measure on battery not AC adapter.
                        • sdogs
                          • Feb 2016
                          • 86
                          • Italy
                          reference:
                          d7050 pin 1 3,4v pin 2 3,4v only whit battery
                          • mon2
                            • Dec 2019
                            • 14169
                            Readings are ok.
                            What is the voltage of SMC_RESET_L ?
                            • sdogs
                              • Feb 2016
                              • 86
                              • Italy
                              Readings are ok.
                              SMC_RESET_L 3,4v
                              • sdogs
                                • Feb 2016
                                • 86
                                • Italy
                                Originally posted by sdogs
                                SMC_RESET_L 3,4v
                                maybe u7100 defective due to overcharging battery that has swollen?
                                • sdogs
                                  • Feb 2016
                                  • 86
                                  • Italy
                                  update:
                                  after a rework on the SMC chip everything works very well, even without AC power supply it stays on, the cpu cores work regularly, it works !!!!!
                                  Thank you very much for helping me ;-)
