Acer e1 usb not worknig
  • mo000
    • Nov 2017
    • 276
    • algeria
    hi everyone
    Acer E1-570 all usb not worknig
    i have 5v ALW but usb en signal is missing from KBC
    i try reset bios but nothing happen
    sd card reader is worknig
    what i can do in this case ?
  • mon2
    • Dec 2019
    • 14094
    Re: Acer e1 usb not worknig
    What is the voltage on SY6288D (U25), pin # 4 ?
    Note that the enable on this device is with the '#' suffix = ACTIVE LOW.
    So with a voltage ~0 volts on EN pin, the USB load switch (U25) should enable. If this is not the case, then the load switch could be defective.
    If you see a logic high, ~3v3 on EN pin, then the KBC is wanting the USB port to be OFF.
    • mo000
      • Nov 2017
      • 276
      • algeria
      0v .
      so could be PCH or bios issue .
      • mo000
        • Nov 2017
        • 276
        • algeria
        SY6288D for usb3 +USB3_VCCA
        but even usb2 not working .
        • mo000
          • Nov 2017
          • 276
          • algeria
          yes in standby i have usb 3.3en signal
          and usb3 vcca
          • mon2
            • Dec 2019
            • 14094
            If U25, pin # 4 (EN#) = 0v then the PCH is requesting that the USB load switch be turned ON.
            Can you confirm the voltage of the following pins:
            U25, pins # 2-3
            U25, pins # 6-7-8
            With EN# = 0; the voltage on pins 2-3 (+5VALW) should travel onto the output pins # 6-7-8.
            If you do not see this, then U25 is defective and has been damaged from some surge event.
            • mo000
              • Nov 2017
              • 276
              • algeria
              U25, pins # 2-3
              U25, pins # 6-7-8
              YES i have all voltages on U25 .
              • mon2
                • Dec 2019
                • 14094
                Ok. So you have Vbus the USB connector to power the USB device (mouse, thumbdrive, etc.).
                Remove all power. Meter in DIODE mode.
                Red meter lead (yes, RED) to GROUND.
                Black meter lead to the USB connector signals:
                (@D15) U3RXDN0
                (@D15) U3RXDP0
                (@D15) U3TXDN0
                (@D15) U3TXDP0
                The diode readings will allow us to review if the ESD transient diodes on the USB 3.0 port pins are damaged or not.
                Do confirm if D15 is present on your logic board or not. Assuming this ESD diode array is present.
                U2DP0_L
                U2DN0_L
                PS: The USB 2.0 signal lines do NOT have any ESD protection = very cheap logic board and may not even pass CE requirements. We pay < $ 0.05 USD for a USB protection device in low volumes of 5k-20k / order from offshore mfrs.
                Can only imagine how low cost the same product will be if purchased in the volumes of this logic board mfr. Zero excuse to not include the ESD devices on the USB 2.0 port pins other than a cheap quality design by amateurs.
                • mo000
                  • Nov 2017
                  • 276
                  • algeria
                  (@D15) U3RXDN0
                  (@D15) U3RXDP0
                  (@D15) U3TXDN0
                  (@D15) U3TXDP0
                  U2DP0_L
                  U2DN0_L
                  no D15
                  this motherboard is trash .
                  • mon2
                    • Dec 2019
                    • 14094
                    Still check the readings of each to ground for the USB pins.
                    Very lame of them to not stuff this low cost ESD protection device which most likely has caused many failures out in the field.
                    • mo000
                      • Nov 2017
                      • 276
                      • algeria
                      U3RXDN0 U3RXDP0 = 325
                      U3TXDN0 U3TXDP0 = no reading
                      even the webcam no working
                      yes shame on them , they make a lot of money from making motherboard low and less protection .
                      • mon2
                        • Dec 2019
                        • 14094
                        When you boot into Windows -> do you see the presence of the USB interface in the device manager tree ? This should be the very bottom of the Device Manager tree -> click the '+' to expand the view.
                        If you launch the camera app -> does the app complain that the camera cannot be found ?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          all USB+webcam not working-its a sure sign of bad pch . You need to replace the SOC/PCH. If you are interested in replacing it and have the necessary tools/skills, then do read my microcode guidance(Sticky thread) before replacing.
                          • mo000
                            • Nov 2017
                            • 276
                            • algeria
                            yes usb interface is present
                            yes camera not found .
                            • mo000
                              • Nov 2017
                              • 276
                              • algeria
                              I'm pretty sure is Bad PCH ; All usb rail is not working .
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                So will it go to trash or you plan to replace SOC/PCH. Btw, is it SOC mb??
                                • mo000
                                  • Nov 2017
                                  • 276
                                  • algeria
                                  it's PCH .
                                  • mo000
                                    • Nov 2017
                                    • 276
                                    • algeria
                                    mcplslg123
                                    mon2
                                    thank you for help
                                    it's PCH issue .
                                      09-06-2024, 05:27 AM
                                      Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                      09-07-2024, 05:00 AM
                                      Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                      This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 04:10 AM
                                      Acer Aspire A317-53-32Z4 + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Acer Aspire A317-53-32Z4 + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-32Z4 + Pack Gold Acer 17'' boardview and A317-53-32Z4 + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                      09-07-2024, 03:10 AM
