Dell E5570 USB poorts not working
  • saidbe
    • May 2017
    • 42
    • Chilo
    I have here Dell E5570, where poorts USB nor working.
    Any idea?
  • mon2
    • Dec 2019
    • 14203
    Re: Dell E5570 USB poorts not working
    1) every USB connector is not working ?
    2) confirm Vbus (+5v) is present
    3) if every connector is not working - check the BIOS to check if the port is enabled
    4) Remove all power. Meter in DIODE mode.
    Red meter probe to GROUND.
    Black meter to USB D+ pin. Reading ?
    Black meter to USB D- pin. Reading ?
    Repeat for each USB port. Post all measurements.
    • saidbe
      • May 2017
      • 42
      • Chilo
      thank you for your answer.
      • jayakumar
        dell 5490 la-f401p no display ( in HDMI out working )
        by jayakumar
        I have dell 5490 la-f401p problem: no display ( in HDMI out working )
        changed working bios ,working screen ,cable
        Please help me to resolve the issue
        i have more then 7 laptop's having the issue
        08-06-2024, 10:03 PM
      • Mirenia
        Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
        by Mirenia
        I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
        I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
        In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
        The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
        03-30-2025, 06:47 AM
      • Gcnewbie
        Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
        by Gcnewbie
        Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
        I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
        My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
        I opened the...
        03-29-2024, 06:55 AM
        DELL Latitude E5570 Notebook 5000 Specification for Upgrade or Repair
        This specification for the DELL Latitude E5570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E5570 boardview and E5570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
        09-06-2024, 04:40 PM
