Help: Acer laptop battery bms reset
  • dhan
    • Jun 2018
    • 134
    • hp
    Hello is there a way to reset the Laptop battery of ACER?
    some model works by shorting the + terminal of the battery to the output B+.
    but in acer, it does not work.
    I've change 1 pc of 18650 ( series of 4 ), and now the output of the batt is 14V, but it doesn't came out to the B+ terminal.
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    Re: Help: Acer laptop battery bms reset
    You will need manufacturer tools and software to do that kind of job which nearly impossible to acquire, and replacing single battery only is dangerous since internal resistance of batteries will show difference.
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • ahmarzo
      Acer TMX314-51 laptop battery problem
      by ahmarzo
      I have acer laptop tmx314-51 with part no 6050A3020501.
      The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
      But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
      I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
      The schematic is not available...
      04-11-2025, 09:14 AM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
