HELP: Asus X407UBR USB 2.0 issue
  • dhan
    • Jun 2018
    • 132
    • hp
    I wonder how to fix this laptop.
    The USB 3.0 is working but 2.0 is not detected.
    The bios side show no usb port
    The output on the USB 2.0 port is 5V.
    also, when you plug a 2.0 devices on the 3.0 port, no response at all.
    Only 3.0 devices are being recognized by the machine
    USB Device Not Recognized on the yellow triangle .
    Unknown USB Device (Port reset Failed ) on the device manager
  • mon2
    • 14003
    Re: HELP: Asus X407UBR USB 2.0 issue
    Hi. How many USB ports on this model?
    Have you tested each USB port? Same issue?
    Confirm if you have the latest bios on the logic board. You may need a working USB 3.0 thumb drive to reflash the bios firmware.
    Load bios defaults, in case the bios has been configured to USB 3.0 mode only.
    It is odd if all USB ports are not able to use slower USB devices. Also the ports should appear in the bios, unless they have been disabled. Check for this first.
    You may have damage to the USB 2.0 interface lines.
    Can you access the logic board and remove the battery for some tests?
    If yes, remove the battery, no power. Meter in diode mode.
    Red meter lead, yes red to ground.
    Black meter lead to D+ of the usb connector. What is the reading?
    Repeat with black meter lead to D- on the connector.
    Post the measurements for each USB port.
    • MakNCheese
      ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
      by MakNCheese
      I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
      Symptoms:
      • Severe lag across the system, including BIOS navigation.
      • Slow boot times and unresponsive performance in Windows.
      • Battery charges very slowly (e.g., ~5% in 2–3 hours).
      • No error messages or BSODs, just extreme sluggishness.
      What I've Tried:
      • Replaced
      06-04-2025, 12:48 AM
    • lukkihapsi
      Asus Vivobook X515JA Weird Boot Issue
      by lukkihapsi
      Asus Vivobook X515JA Laptop
      Issue :
      Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
      Tried :
      Cleaned inside for dust, applied fresh thermal paste. No Change!
      Removed keyboard, Trackpad, fingerprint sensor. No Change!
      Removed Internal SSD. No Change!
      Updated BIOS to latest version. No Change!
      Removed battery and pressing power button for 1 minute. No Change!
      Weird Part :
      Upon turning laptop ON, screen lights up - stays black,
      I...
      07-07-2025, 12:07 PM
    • DynaxSC
      ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
      by DynaxSC
      I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
      Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
      Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
      The behaviour is also really very strange, i.e.:
      • The disk shows always up in BIOS - so it is recognized, so far so good
      • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
      02-23-2025, 01:33 PM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • Safio
      Asus Rog Strix g15 g512LI BOOT ISSUE
      by Safio
      Hello
      My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
      i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
      thank you
      06-08-2024, 08:43 PM
