Asus Ux303UB, Battery not detected after mb change
  • lordalex
    • Apr 2018
    • 8
    • lahr
    Hello Guys,
    my asus laptop ux303ub stoppped working. I guess the mainboard had a cap / mosfet problem, but i couldnt fix it. It stopped to charge and no power with cable or battery.
    So i got a spare board from a UX303LNB, which was working, but the battery connector was gone.
    I bought it, soldered the connector from my board in and installed win10 again.
    so far so good, but the laptop isnt recognizing my battery correct. It stays on, but doesnt show a percentage or something and laptop gets very slow without ac plug.
    I cant boot the laptop via battery. if i plug the cable in, i can boot and if i remove the cable, the laptop stays on.
    The battery connector has 8 pins. 3 Red, 3 GND. all conneted right.
    yellow and white. The pads were gone on the spare board, but i could reconnect them to the little ic next to it with the help of the schematics i found here. So i think this isnt the problem.
    what else could be wrong? Some charging ic? Is there an ic at the battery that is faulty?
  • mon2
    • Dec 2019
    • 14201
    Re: Asus Ux303UB, Battery not detected after mb change
    Hi.
    1) yes, the laptop has a charger IC that is controlling multiple mosfets (think of as solid state relays).
    2 of such mosfets are linked to the AC adapter in and used to power the logic board.
    Then another 1 of the mosfets is used to connect the battery to the same logic board main power rail.
    More details in how this works is posted above with a sticky from @Piernov. A must read.
    2) in the posted repair guide for this model on this forum, focus in sheet #2 - the very top graphic.
    This is the charger ic.
    On the left are the 2 mosfets that connect the power adapter to power the logic board using the AC_BAT_SYS rail.
    Remove the battery.
    Attach the power adapter. Meter in DC volts (30V or higher scale).
    Measure the voltage on each pin of the first mosfet.
    Every mosfet has source, drain, gate pins. Post the full markings of each mosfet. The repair guide is blurry to read (or my eyes are weak).
    Often each mosfet is 8 pin with 4 pins on each side.
    Usually, pins 1-2-3 = source. Gate = pin 4. Drain = 5-6-7-8.
    Then we can find datasheets for each mosfet. The datasheet will show the location of each pin with pin numbers.
    Source = adapter input. Drain = should be the same as adapter voltage. Gate voltage is expected to be HIGHER than adapter voltage by ~+6v. So around 24 to 25 volts on pin #4 of each mosfet. Confirm it.
    Both mosfets should be ON to create AC_BAT_SYS.
    Post each voltage measurement.
    Next, remove all power. Attach the battery (only).
    What is the voltage on the battery? Is the battery known to be good?
    This battery will be mated to another mosfet. See the graphic in the repair guide.
    What is the part number of the mosfet?
    What are the voltage readings of each pin on the battery mosfet?
    Again, this battery mosfet will connect to the same target AC_BAT_SYS rail to power the logic board.
    Very likely you have defective mosfets. They are very inexpensive to source.
    Near these mosfets will be charger IC. What are the full markings on this IC ?
    Post all measurements to move forward. Will review again after some beauty rest.
    • lordalex
      • Apr 2018
      • 8
      • lahr
      okay, ill test it tomorrow. im at work right now
      Will laptop start with battery even if data/clk (yellow and white) are not connected right? it was my first guess, since the pads were missing and i just connected them to the right pins of the ic, the pin was going to.
      • mon2
        • Dec 2019
        • 14201
        The I2C pins on the battery are used to communicate with the BMS (battery management system).
        The BMS reports the details of the battery pack such as charge cycles of the battery; serial number; etc.
        Do measure also the voltage on the I2C lines so we can confirm these pins are not stuck.
        If they are stuck, the charger ic may just turn OFF the battery mosfet.
        You may have the I2C lines reversed (SCL and SDA) which will not cause any damage but will not allow the charger to communicate with the battery pack.
        Post the details.
        • lordalex
          • Apr 2018
          • 8
          • lahr
          Thanks for your help so far!
          i attached the battery and measured the pins at the connector and the ic
          measurements i get just with battery:
          connector:
          Vpin: 11,5v
          Dat_Clk: 3.25v
          Dat_Bat:0.1v
          Mosfet near battery connector:
          Source: 11.5
          Gate: 17.3
          Drain: 11.6
          if i connect the ac with battery still connected i get following readings:
          Vpin: 11,5v
          Dat_Clk: 3.25v
          Dat_Bat:0.1v
          Source: 11.5
          Gate: 11.58
          Drain: 19.35
          • mon2
            • Dec 2019
            • 14201
            Vpin: 11,5v
            Dat_Clk: 3.25v
            Dat_Bat:0.1v
            To confirm, the last line is the I2C DAT signal ? This is not a good value and have seen this fault before. Both lines of the I2C interface should be ~3v3 which means the line is OPEN and is being pulled up by local pull-up resistors.
            Remove the battery -> check the voltage of this line again. Still same low voltage?
            If yes, it is very possible that the ESD diodes (often 3 legged part) is damaged -> they are dirt cheap. Locate near the battery connector for a 3 legged part (2 legs on one side; 1 leg on the opposite side).
            Take some clear pics and post them here.
            This part is likely damaged and should be removed off the board to restore the I2C lines back to the normal and expected ~3v3.
            The same damaged lines can cause your battery to be not detected.
            • lordalex
              • Apr 2018
              • 8
              • lahr
              Yes, its the data line from the battery connector.
              I removed the battery and measured again with only the ac plug.
              Clk gives me again 3.3. data went to 1.3
              Do you mean this little part, marked in orange?
              • mon2
                • Dec 2019
                • 14201
                Yes, that could be the one.
                Using the same meter setting -> check the voltage on each of the pins on the side with 2-pins. If this is the correct part, then one side will be 3v3 = SCL pin.
                The other pin on the same side will be the low voltage = 1v3 or whatever.
                Once it is confirmed, remove this part off the board -> apply flux and hot air and use tweezers to remove it.
                Then check the voltage again on the pads on the logic board at this location.
                If ok for both pins and ~3v3 for each -> attach the battery and test again.
                • lordalex
                  • Apr 2018
                  • 8
                  • lahr
                  ok, i guess its not the right part,
                  this one measures 5v on the left side of the pin. rest is 0.xx
                  picture 1
                  i found this part here. It has 3.3v on each side, but i dont know if it belongs to the battery.
                  picture 2
                  what im wondering is, that i cant find another SMB0_DAT and SMB0_CLK besides on this litte ic next to the battery
                  picture 3
                  EDIT
                  omg i made it!
                  i found out, that SMB0_DAT wasnt routing to the ic on the other side, while SMB0_CLK was. took a wire and connected from battery to other side of the board and it started with battery!
                  thank you so much for you help anyway. guess i couldnt find a solution without you
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • dhenion
                    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                    by dhenion
                    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                    The original board was:
                    ASUS X510UNR REV 3.0 A
                    The replacement board is:
                    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                    01-30-2024, 01:45 PM
                  • ivangserrano
                    ASUS UX303UB REV2.2 WORKS ONLY BATTERY
                    by ivangserrano
                    Hello
                    I have an ASUS UX303UB that only turns on with the battery connected, it doesn't turn on only with the charger connected.
                    With the battery and charger connected, the computer turns on but does not charge and I can see some consumption at the source, it seems to me that the charger is taking over.
                    In the work environment I can see that the battery is at 24% and does not charge or discharge.
                    I checked the 24780s load ic and I have the following voltages.
                    24780s
                    vcc - 18.85
                    24v acdriver
                    acok 1.3v
                    acdet 2.6v...
                    06-29-2024, 06:35 AM
                  • bustacaps
                    ASUS X455L Battery not detected problem.
                    by bustacaps
                    Hello everyone, my problem goes like this... I have Asus X455L laptop. Initial problem was battery not detected so I replaced it with a new battery but still not detected and since it was not detected it was not charging. The battery led(orange) indicator keeps blinking. When pressing power button without plugging the adapter it WON'T turn-on with the new battery installed. But when I plugged the adapter it turned-on immediately(not pressing power button anymore). The laptop has display by the way. Also I noticed the fan spinning fast(I can hear its sound).
                    The troubleshooting I've...
                    06-13-2022, 09:31 PM
                  • mrkmpn
                    Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                    by mrkmpn
                    Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                    This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                    03-13-2024, 01:54 PM
