MacBook Pro 15" Late 2013 no chime or boot but green light on charger
  • Gigabit2
    • Apr 2022
    • 264
    • United Kingdom
    I have a late 2013 MacBook Pro 15" here, with light on charger but does not boot with or without battery installed. Can anyone provide assistance?
    I checked these rails:
    PPDCIN_G3H - 19.80 (20V mode)
    PP3V42_G3H - 3.41 (20V mode)
    PPBUS_G3H - 12.56 (20V mode)
    PP3V3_S5 - 3.32 (20V mode)
    These look okay to me, where should I look next?
  • mon2
    • Dec 2019
    • 14201
    Re: MacBook Pro 15" Late 2013 no chime or boot but green light on charger
    What is the 820-xxxx markings on your logic board ?
    Any liquid damage ?
    What is the history of this unit ?
    • Gigabit2
      • Apr 2022
      • 264
      • United Kingdom
      Hi mon2,
      820-3787-A.
      No liquid damage.
      Previous owner reported they changed the battery and then it developed an unknown logic board fault after.
      • mon2
        • Dec 2019
        • 14201
        Ok.
        See attached. Meter in DC volts mode (5V or higher is ok).
        Check the voltage readings (with adapter & battery connected) of:
        SMBUS_BATT_SCL
        SMBUS_BATT_SDA
        @ D7050, pin # 1 and # 2. Black meter lead to ground. Red meter lead to diode pin.
        • reformatt
          • Feb 2020
          • 1410
          Probable pry damage around trackpad during removal of battery (probably shorting a rail etc). Disconnect everything except magsafe connector, and see if it starts up. Recommend getting a chipmunk USB tester if you don't already have one.
          • Gigabit2
            • Apr 2022
            • 264
            • United Kingdom
            I removed all components and still no boot. Without battery connected, LED on charger is orange not green, is this expected?
            • Gigabit2
              • Apr 2022
              • 264
              • United Kingdom
              Pin 1: 3.4V
              Pin 2: 3.4V switching to 3V back to 3.V constantly
              • Gigabit2
                • Apr 2022
                • 264
                • United Kingdom
                Possible is just bad probing on Pin 2, showing 3.3V to 3.4V oscillating on re-test
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  check voltage on L7520 after plug in power; check if it pulse (stay with probe for around 30 seconds after plug in power.
                  check voltage on U1950 (possible fault in here )
                  • piernov
                    • Jan 2016
                    • 4435
                    • France
                    Why not go through the list of power rails as usual?
                    • Gigabit2
                      • Apr 2022
                      • 264
                      • United Kingdom
                      L7520 pin 1 showing 5V and no pulse.
                      I apologise, is wrong board. Is actually 820-3362-A!
                      Pin 1 on U1950 showing .023 on 2V mode!
                      • Gigabit2
                        • Apr 2022
                        • 264
                        • United Kingdom
                        I checked PP1V5 on pin 1 R8135, is showing low voltage, not 1.5V and multimeter is pinging that it is shorted to ground
                        • Gigabit2
                          • Apr 2022
                          • 264
                          • United Kingdom
                          L7870 showing 0.91V on pin 1, think is a bit low?
                          • Gigabit2
                            • Apr 2022
                            • 264
                            • United Kingdom
                            Can anyone help?
                            I noticed PP1V5_S0 is very low, showing only on 300m mode.
                            I looked at U7810, PP3V3_S5 is okay at 3.3V but pin 8 is coming out as 300m as above.
                            I already replaced U7810 and the issue remains - I also replaced all components in this circuit.
                            • mon2
                              • Dec 2019
                              • 14201
                              Unable to locate this board - is it 820-3462-A ?
                              No U7810 in the schematic...
                              • Gigabit2
                                • Apr 2022
                                • 264
                                • United Kingdom
                                820-3662
                                • mon2
                                  • Dec 2019
                                  • 14201
                                  Ok, after a bit of a chase, for future readers, the schematic to use for the 820-3662-A is the 820-00138. Makes perfect sense to me
                                  Measure the voltages of points 1, 2 and 3. Post each reading.
                                  Then remove all power -> meter in resistance mode -> measure the resistance to ground of L7870, pin # 2.
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    820-3662 schematics are available. 820-00138 is a different board. (2013 vs. 2015)
                                    • mon2
                                      • Dec 2019
                                      • 14201
                                      Thanks. Need a GPS to navigate this thread with the assorted board numbers.
                                      XinZhiZao has the A1398 820-3662 schematics and boardview files.
                                      The above regulator schematic (U7810) is still relevant.
                                      • Gigabit2
                                        • Apr 2022
                                        • 264
                                        • United Kingdom
                                        Pin 1: 3.32V
                                        Pin 2: 3.22V
                                        Pin 3: 0.58V
                                        L7870 resistance: 3.75 on 20k mode.
