X556UJ-XO114T with i5 6200U & Nvidia 920M ?
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello ,
    Sudden death of the laptop, was working in the night. By morning completely dead. No power light , nothing.
    Used my multimeter , and saw 19v in the mosftets that come inside.
    I thought the BIOS Chip maybe in the night (it passed an update ?maybe). It was opened for lot of hours (it had airflow from beneath,and electricity from my UPS) so this 2 are out of the question.
    I used the link of peste to burn in a new , bios dump,but again nothing.
    Laptop keeps staying at dead point.
    I am attaching the bios dump of peste.
    Any thoughts were i should look ?
  • mon2
    • Dec 2019
    • 14175
    Re: X556UJ-XO114T with i5 6200U & Nvidia 920M ?
    Post the voltage readings of each pin of the first mosfet.
    Then continue to do the same for the second mosfet.
    Attach the external recommended and known good adapter for this laptop.
    Does the main power rail pass through the mosfets onto the logic board?
    • Acnologia
      • Dec 2016
      • 421
      • Poland
      mosfet 1
      19.0 all pins.
      Except (pin 8 ,24volt)
      mosfet 2
      19.0 all pins
      except (pin 5 , 24 volt)
      • mon2
        • Dec 2019
        • 14175
        Can you share the markings on the topside of each mosfet ?
        I think you may be reading the pin #1 incorrectly as most mosfets are 8 pins; with 4 on each side.
        The pin #1 will be the TOP LEFT of the device and the numbering will be in a 'U' pattern.
        1 8
        2 7
        3 6
        4 5
        and expecting that GATE = pin # 4 = 24V = good voltage to have for the mosfet to turn ON but we can confirm it once you share the markings so we can hunt down a datasheet.
        • Acnologia
          • Dec 2016
          • 421
          • Poland
          1 8
          2 7
          3 6
          4 5
          I think i read it correctly ? Don't know.
          Here is the picture in detail how are the values.
          • Acnologia
            • Dec 2016
            • 421
            • Poland
            Here are some high detail photos (64Mpixel)
            https://i.postimg.cc/tg7nJyZn/10.jpg
            https://i.postimg.cc/KvyTNdVC/7.jpg
            https://i.postimg.cc/K80gm4zy/8.jpg
            https://i.postimg.cc/BnSKW2Jg/9.jpg
            • mon2
              • Dec 2019
              • 14175
              Just know that Pin # 4 = 24v.
              Review your logic board and read off the topside markings of these 2 mosfets @ PQ8906 and PQ8907.
              Or take a clear pic and post it here as an attachment. LOL - you just did
              • Acnologia
                • Dec 2016
                • 421
                • Poland
                Yes,i that's why i attached it.
                • Acnologia
                  • Dec 2016
                  • 421
                  • Poland
                  For some reason i don't see 3.3volt in the BIOS chip. Trying to find where it comes from ,but i cannot.
                    • 20855
                    Post a link to the boardview/repair guide. Check the voltages at all grey coils
                    • Acnologia
                      • Dec 2016
                      • 421
                      • Poland
                      Here is the attachment.
                      • Acnologia
                        • Dec 2016
                        • 421
                        • Poland
                        All the grey (coils) are 0.00 except the one that is near the battery connector at 0.23volt
                          • 20855
                          Are you powering the board by the soldered brown wire in your picture,or using the adapter connected to the power jack
                          • Acnologia
                            • Dec 2016
                            • 421
                            • Poland
                            Both ways.
                            The cable that i soldered was on the back. To use my power supply , to find the short in case there is one.
                            But it doesn't "draw" any Ambs my power supply. It stays in 0.00 even if i use 3.0v
                            I even removed the first (2 mosfets) just in case i can see something else, that is wrong. Nothing again...
                              • 20855
                              Solder the 2 mosfets back,plug charger in and test voltage on PR8911 .Unplug charger and post resistance on all large grey coils
                              • Acnologia
                                • Dec 2016
                                • 421
                                • Poland
                                Sorry for my delay replied @SMDFlea .
                                I did, solder the mosfets back , and get the same values to the mosfets.
                                All the grey (big coils) all are 0.00v no change on the voltage.
                                • Acnologia
                                  • Dec 2016
                                  • 421
                                  • Poland
                                  Something else that i found.
                                  All the red circles, are beeping , in both ends. ( i removed them and still they were beeping)
                                  I removed the green chip (that i circled in case this was the problem) but again the beep is in all capacitors .
                                  The rest that are around and are NOT circled they are not beeping (only 1 side)
                                  But the ones in red, they all beep in both ends...
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Test them in ohms mode and post the values. They are expected to show very low values. What is the resistance on pin8 of bios chip??
                                    • Acnologia
                                      • Dec 2016
                                      • 421
                                      • Poland
                                      Sorry for my delay .
                                      The pin8, after a while it shows 0,86 (in my multimeter with selection of the 2M Ωhm)
                                      Now, i found something else...
                                      QFN-8 , G4 GUE , 2R0F04 chip.
                                      One shows the resistance 0,510...the next to it ,shows only 1/4 of the value .
                                      Here is picture.
                                      • Acnologia
                                        • Dec 2016
                                        • 421
                                        • Poland
                                        Any thoughts?
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
                                          NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                                          The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                                          10-02-2024, 08:52 AM
                                          NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                                          The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                                          10-02-2024, 07:51 AM
                                          NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                                          The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                                          10-01-2024, 01:54 PM
                                          HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 03:30 PM
