Lenovo E570 3v Power issue
  • coltron
    • Jan 2021
    • 98
    • England
    Hope someone can help with a Lenovo E570 not powering on.
    3V Rail missing and ic getting very hot
    With reference to link:-
    https://www.badcaps.net/forum/showth...highlight=E570
    Read later posts for schematics, boardview and latest comments.
    SMDFlea comment regarding resistances around the ic, I had already pulled the IC from the board before digesting the suggestion. (because the chip gets very hot with coil getting hot soon after charger is plugged in).
    0.2v at the power button, prior to removing the chip.
    pin 1 (3v5v on)120kohm
    pin 2 (3v p.good) open?
    pin 3 (3v alw FB) open?
    pin4 (3v alw out ) 902ohm
    pin 5 (3vl or n6093) 1ohm
    pin 6 (3vbs) open?
    pin 7 (3v in) 626ohm
    pin 8 ( 3v in ) 626ohm
    pin 9 (gnd) 0ohm
    pin 10 (3v lx) 902ohm
    These are motherboard readings with meter leads black to gnd and red to pin being measured.
    The chip itself has no apparent shorts and may be ok?
    I'm haven't tried power injection, but my intention is 2v - 2amp onto pin 5.
  • mon2
    • 14360
    Re: E570 3v Power issue
    If any part is getting hot, remove all power.
    Meter in resistance mode.
    Check the resistance to ground of the rail linked to the power supply IC that is getting hot.
    • coltron
      • Jan 2021
      • 98
      • England
      Thanks for your comment Mon2.
      The resistance value of pin 9 pad on the motherboard is zero ohm, but fair point. How could i check on the grnd pad on the ic?
      • coltron
        • Jan 2021
        • 98
        • England
        On second read of your suggestion
        pin 7 and 8 are 3v in, they are both 626 ohm
        pin 10 goas to the coil/inductor which has a resistance just under 1k.
          • 21204
          Can you desolder RE3 and check the resistance to ground on both pins
          • coltron
            • Jan 2021
            • 98
            • England
            Ok Thanks SMDflea, I have de - soldered R3 and measured resistances:-
            3v-ec = 001
            3vl = circa 600
            I'm assuming this is bad and points to a short on chip UE1?
              • 21204
              3v-ec = 001
              3vl = circa 600
              It could be yes.Inject voltage and see what heats up, start at 1V 1A
              • coltron
                • Jan 2021
                • 98
                • England
                Thanks for reply SMDFlea
                Just to be clear, your suggestion is to inject voltage on R3 (ec side)?
                (I consider myself very new to this)
                  • 21204
                  Yes on that side. I must be the EC thats shorted
                  • coltron
                    • Jan 2021
                    • 98
                    • England
                    Thanks and yes, as suspected, the big Lenovo chip gets hot in the middle.
                    IT8586E
                    1735 - FXA
                    ES00KA
                    I've found one on eBay, :-
                    IT8586E
                    1948 - fxa
                    ECZ3GA
                    Would this suffice?
                    • misha97123
                      • Feb 2021
                      • 36
                      • Qazaqstan
                      IT8586E
                      1735 - FXA
                      ES00KA
                      IT8586E
                      1948 - fxa
                      ECZ3GA
                      Would this suffice?
                      yep.
                      but after soldering a new chip, you need to reflash the 128kb dump for it, is not known kind of garbage inside the chip
                      • coltron
                        • Jan 2021
                        • 98
                        • England
                        I have a lenovo B50 50 with a similar chip starting with IT8586E, would this chip work with the E570?
                        • coltron
                          • Jan 2021
                          • 98
                          • England
                          I think its worth mentioning that the laptop this board belongs to had a mangled dc socket, ( sqaure type) the plastic surrounding the centre pin was missing and pins bent.
                          That,s ebay lol
                          I believe this may of killed the super i/o chip.
                            • 21204
                            You should use a chip with the same 3 letter suffix FXA. Sometimes you can use one with a different suffix but its trial and error if it will work or not.
                            Using the EC from the B50 50 might work if it shares the same EC code as the E570 ,it could be generic enough though to make it boot and from there you could update the bios and EC with the update from the support site.If it doesn`t boot then you will have to program the EC,if you have a programmer that will do it,or buy a pre programmed chip from ebay or Ali.
                            Desolder the old chip and check that the short has truly gone.
                            • coltron
                              • Jan 2021
                              • 98
                              • England
                              Re: Lenovo E570 3v Power issue
                              Sound advice. I will desolder the io chip and go from there. Thanks again
                              • tomodachi
                                • Apr 2012
                                • 603
                                • Turkey
                                could be a codec IC short as well
                                • coltron
                                  • Jan 2021
                                  • 98
                                  • England
                                  I,ve comared e570 board view with b50 50 and some of the b50 pins do different things to the e570.
                                  A programmed chip seems the best option though a good value e570 board may appear on Ebay
                                  Thanks everyone for your help.
                                  • GLISIT
                                    by GLISIT
                                    01-16-2025, 02:29 PM
                                  • claws77
                                    lenovo flex 5 14itl05 power sequence issue
                                    by claws77
                                    hi guys, my motherboard will not start no matter what
                                    when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                                    but rest nothing happens no sign of life.
                                    this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                                    with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                                    but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                                    i have no knowledge of motherboards ....
                                    10-20-2024, 02:48 PM
                                  • justice171
                                    Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                                    by justice171
                                    I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                                    Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                                    1. Verified that all critical voltages are present:
                                      • 3.3V and 5V are always present if DC is plugged.
                                      • 1.8V on the BIOS chip is present.
                                    2. Checked the power button functionality:
                                      • When pressed, the voltage drops to 0V, indicating the button is functional.
                                    3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                                      • Confirmed connectivity is intact, ruling out issues
                                    11-26-2024, 12:39 AM
                                  • yaya3gmax
                                    Laptop Power Issue – Works on Battery, Fails on Adapter Load
                                    by yaya3gmax
                                    Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                                    Symptoms:
                                    • Laptop works normally on a pre-charged battery.
                                    • Battery does not charge when adapter is connected.
                                    • Without battery:
                                      • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                                      • Speakers “pop” when power cut occurs indicating harsh sutdown.
                                      • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                                    08-21-2025, 07:16 AM
                                  • hendeky
                                    Lenovo 15IMH05 Power Issue
                                    by hendeky
                                    I have a problem with my laptop. I just short circuit the eDP cable by an accident. Then i try to open it. i press the power button it was powered the rgb keyboard but after a few seconds and it just shut down. When i opened it up and unplug everything from motherboard i can't see any physical damage from ICs, capacitors and MOSFETs. I found a broken fuse FG3. But it just powers up LCD Display. I try to power it on with DC Adapter and feel some heat from an IC. IC is repeatedly power on and off. I tracked the schematic and i found some MOSFET and main 5V/3.3V controller. After that i...
                                    03-23-2025, 11:45 AM
