Hello i have a msi GP63 and the gtx 1060 is not detect in the bios and not detect in windows , i have flash the vbios with programmer and same mistake, i have the ec do mistake with keyboard key not work or keyboard not work , i know i have to chance the ec but it's possible the ec do the gtx not detect in bios and in windows? i have check the voltage of the vga and it's good the die of the gpu is little hot at used
msi GP63 gtx not detect and keyboard mistake
Re: msi GP63 gtx not detect and keyboard mistake
i have check with camera and i have find pin 2 to 5 is joined each other , computer work less than 5 minute in windows and the two graphic card have error in ec , i have delete the driver and after no error. How to know if it's this pin is dead that do no picture and hot cpuComment
i have change the ec, same mistake, and now i have 3V on pin 2,3,4,5 . but i have a bios put from msi website without dmi.i have save my original bios. It's a dead cpu?. When lcd freeze it's do artefact.Comment
i have check all the voltage is good. i have change again the ec and now the voltage is good as pin joined, pin joined can kill cpu gpu or pch? without heatsink just cpu be hot and computer shutdown , with heatsink fan cpu work and after 20minute of power on the pch is hot. the pin joined go to pch see diagramComment
You mus first read your bios chip you must always save you original bios and it best you read it always 2 times and compare wit hxd or other program them to see it is identical als after writing you must compare your written bios with the one you flashed it this are steps what can save you a lot of times also desolder the bios chip not write with clip that can give errors. Clips doesn't work good.Comment
I do not think cpu can artefacts, I can maybe wrong. Maybe wait to the others react. I have no seen yes cpu gives artefact do you have pictures from the artefacts. Do you have also artefact on external display?Comment
cpu have a graphic card, no i don't have do a picture. Now no picture just without heatsink cpu go very hot and computer shutdown it's self because of hot cpu but my heatsink when i do the test have one of the 3 screw damage i think this is my fault.i must change the backplane before do testComment
