hp elitebook 840 g2 turning on and off
  • Zilicon
    • Nov 2020
    • 148
    • Nigeria
    Please help;
    the above system wit the board number 6050a2637901-mb-a02 turns on and off with the lights on.
    when the system is turned on, the fan spins but it stopped immediately, while the light turns on and off continuously.
    L6100 3.3V
    L6159 5V
    L6200 0v
    L6000 0.6v
    L6300 1v
    L6610 0v
    i checked U6200, the enable pin is 0v
    i flashed the bios, same problem still.
    please help!
  • mon2
    • Dec 2019
    • 14659
    Re: hp elitebook 840 g2 turning on and off
    Start with the adapter - is it 90W as recommended by the vendor? Does the adapter work ok and supply the DCIN voltage ?
    What is the adapter voltage ?
    Next, remove all power -> meter in resistance mode (2k scale is ok).
    Check if the first 2 mosfets are defective by checking their resistance.
    Measure the resistance between:
    (Mosfet @ Q6010)
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    If you see 'OL' = over limit - then increase the resistance scale to the next higher setting on your meter and measure again.
    If you see a low resistance reading, the mosfet is defective and needs to be replaced.
    Repeat the test with the next mosfet @ Q6011 and again Q6012.
    Post the readings.
    • Zilicon
      • Nov 2020
      • 148
      • Nigeria
      (Mosfet @ Q6010)
      Post the readings.
      thank you for your response.
      i believe the mosfets are okay, because there's voltage supply into the system.
      here are what you requested for:
      1. the adapter is rated 90W
      2. all the voltages are okay- 19.83V and 19.26v
      3. there's supply of DCIN voltage
      4. resistances- q6010 89.5k, 205.3k; q6011 205.3k, starts from 20M but continues to drop, reverse prob gives 21.32k; q6012 same with immediate previous, the other side fluctuates in K ohms
      but reverse prob gives 0.562k.
      5. q6011 19.83v; q6012 0.8v.
      in summary voltage gets to r6000.
      I felt RAM voltage missing is the cause of this problem
      • mon2
        • Dec 2019
        • 14659
        Can you post exactly the requested resistance checks ?
        For each mosfet, in order - otherwise it is very difficult to follow the details.
        • Zilicon
          • Nov 2020
          • 148
          • Nigeria
          ok.
          source and drain- 208k, 350k (prob reversed)
          source and gate- 207.5k, 220.4k (prob reversed)
          gate and drain- 0.577M, 0.577M (prob reversed)
          • mon2
            • Dec 2019
            • 14659
            Are these measurements for a single or for both mosfets ?
            • Zilicon
              • Nov 2020
              • 148
              • Nigeria
              just q6010.
              these are the readings for the other two fets:
              q6011
              source and drain 0.444M keeps increasing, 168k keeps increasing past 0.444M (reversed probe)
              source and gate 11.81M, ol (rversed probe)
              gate and drain 12.53m, ol (reversed probe)
              q6012
              source and drain 37.32k, starts at 36.7M and decreases after (reversed probe)
              source and gate 246k, starts at 40M fluctuated to ol, drops to 246k (reversed prob)
              gate and drain 249k, 206k
              • mon2
                • Dec 2019
                • 14659
                q6012
                is too low IMHO. Replace Q6012.
                reference (see the resistance table):
                http://electronicsbeliever.com/how-t...0good%20MOSFET.
                • Zilicon
                  • Nov 2020
                  • 148
                  • Nigeria
                  thanks, i will keep you updated
                  • lapfix
                    • Mar 2020
                    • 2764
                    • my workshop
                    Thank you for this site .
                    Question : i don't understand how you juge that Q6012 is defected !
                    Question : i use always diode mode for my measurements and i think that in doubt i must desoldered the mosfet and take measurements out of board , why you didn't ask for that here!
                    Thank you
                    • Zilicon
                      • Nov 2020
                      • 148
                      • Nigeria
                      negative!
                      thanks a lot
                      • Zilicon
                        • Nov 2020
                        • 148
                        • Nigeria
                        @mon2 thanks agaain for your assistance.
                        @platinumsteel messaged me privately because he was facing similar issue.
                        i'm going to post the private message here, it might be of help in the future to anyone facing similar hitch.
                        QUOTE=platinumsteel]Hi friend . Have you had any luck with your 840 g2 labtop? I have one with the same issue. Missing ram voltage. I traced it down to a bad cpu/PCH. Did yours had water damage? Mine had some water damage around some 19v mosfets and the cpu line is close to one of those lines so i think the water must of bridged it. But i will check all over again and see if i have a bad Q6010 like you[/QUOTE]
                        so let me dive in. go over the thread that i initiated, you'll see i've narrowed my diagnosis down to u6200 (the chip generating the RAM voltage) because the enable was not present, and of course "PGOOD" signal would be absent as well. on checking, the enable signal was supplied by "SLP_S4#_3R" which is from the CPU.
                        series of questions overwhelmed me, was the CPU bad? or was the BIOS bad?
                        i reprogrammed the BIOS chip, still no success. i was in a dilemma, so i thought to myself to isolate L6200, immediately i saw sign of life. the fan spins at top speed non stop. my enable pin is now present.
                        with L6200 isolated, there's 3.3v enable, there's Vin, but no output. i don't have a donor board, i'm looking into placing an order for the U6200 IC. the IC is "Z1268012" it is different from what's on the schematics.
                        i'll keep you guys updated. thanks
                        • Zilicon
                          • Nov 2020
                          • 148
                          • Nigeria
                          @platinumsteel, i'm sure by now you must have thoroughly cleaned the board. use ultrasonic cleaning if you have one, and if you don't, use isopropyl alcohol to clean the board thoroughly.
                          check if you have a short, the coils if any power rail is shorted. if no short, check the U6200. check the voltage missing. it appears the enable voltage is missing as well. because the enable takes you to the CPU. isolate the L6200 and apply power to the board.
                          my guess is, we might be having same challenges.
                          let's us know as it goes
                          • Zilicon
                            • Nov 2020
                            • 148
                            • Nigeria
                            i'll keep you guys updated. thanks[/QUOTE]
                            the ordered IC has arrived and fixed. sadly the problem persists. i traced the fault to U7400, i figured out it was blown. i had it replaced. voila, the system starts and it was stable. voltage is now present at L6200, but the CPU remains cold. L6610 is 0v.
                            meter readings
                            diode mode L6610 0.025
                            resistance mode 44.4
                            the buck converter u6610 has
                            Vin present, PWM present too but no output.
                            does it mean the chip is bad?
                            please help
                            • Zilicon
                              • Nov 2020
                              • 148
                              • Nigeria
                              the PWM is absent, but 5v is present at VDD
                              • OKRPKCOMP
                                • Dec 2020
                                • 439
                                • PAKISTAN
                                what is this in this diagram (d6035) near chargin pin
                                transister or what????? and no
                                Can anybody tell me plzz
                                • OKRPKCOMP
                                  • Dec 2020
                                  • 439
                                  • PAKISTAN
                                  transister or what????? And no
                                  can anybody tell me plzz
                                  where are u all guys
                                  • mon2
                                    • Dec 2019
                                    • 14659
                                    Sleeping. Rest is sometimes required...
                                    See attached. If you copy and paste the markings shown in the schematic, you will find the vendor = PANJIT. They are a company out of Taiwan.
                                    Then go to their website or any of the many resellers of their parts and stuff in the other markings in the schematic.
                                    This is a surface mounted SOT23 packaged DUAL ZENER DIODE rated @ 24 Volts. The drawing of the arrow head with the slanted lines = ZENER diode.
                                    The direction shows that it is a UNIDIRECTIONAL DIODE so the component is protecting only the positive side of the power rail.
                                    In summary, the component will trigger to suppress any voltage > 24 volts on the line. There are 2 diodes in the single package, so it can protect 2 lines.
                                    As long as the voltage on each line remains under 24 volts, this part will not be active. If > 24 volts, it will attempt to suppress the voltage to the save and max value of 24 volts.
                                    The part is not critical and can be purchased from any vendor (does not have to be PANJIT brand). I think my mom makes these. Check your local suppliers for:
                                    'SOT-23 packaged dual zener / tvs / ESD diode @ 24 volts, unidirectional'.
                                    The part should be < $ 1 USD. For sure you can buy from Aliexpress.
                                    PS: If you have a logic board where this part is damaged then this means some in-rush surge was placed on this rail and the component was killed in an attempt to protect the rest of the logic board from being damaged. This can happen in power brown outs, etc. or with a bad power adapter.
                                    Update - the datasheet is attached for this part. Order the version that is rated @ 24 Volts !! Any brand of this part will work - nothing special here to replace this component.
                                    • OKRPKCOMP
                                      • Dec 2020
                                      • 439
                                      • PAKISTAN
                                      Salute u sir
                                      Thanksss
                                      • mon2
                                        • Dec 2019
                                        • 14659
                                        The following should work fine to replace this defective component:
                                        ONSEMI ESD7272LT1G
                                        https://cdn.badcaps-static.com/pdfs/...195d4e8444.pdf
                                        ONSEMI SM24T1G
                                        https://cdn.badcaps-static.com/pdfs/...c04ef91804.pdf
                                        ST ESDA25L
                                        https://cdn.badcaps-static.com/pdfs/...5f0415f8e5.pdf
                                        ST ESDA25LY
                                        https://cdn.badcaps-static.com/pdfs/...322e89e16c.pdf
                                        Mouser has the above parts in stock but as noted, you can find them on Aliexpress or mention the details to the store on Aliexpress and they will find a suitable replacement from their local markets.
                                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:50 AM
                                          HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 05:20 AM
                                          HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
