Lenovo nm-c371
  • Luís Amaral
    • Nov 2013
    • 78
    • Portugal
    Lenovo nm-c371
    Hello, i'm working on a Lenovo nm-c371 that arrive me dead, replace the KB controller now turns on but i do not have keyboard,
    already flash EC, changed 8176fn-56a and i cannot figure out why keyboard does not work.
    When i flash EC with vertyanov programer give me some errors, i do not know if is normal, already changed two KBC...
    Anyone have any ideia ?
  • ekozeko333
    [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
    by ekozeko333
    I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
    🔥 The Problem Started After Suspected ESD/PD Fault
    I experienced a power issue or ESD event through a USB-C charger
    After that, the NX20P5090 power switch was visibly burned and was replaced
    Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • abhorsen
    Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
    by abhorsen
    Hey guys,
    Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
    Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
    Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
    07-06-2023, 10:22 AM
  • Nicola Bianchi
    Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
    by Nicola Bianchi
    Hello!
    A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
    No the machine power up, but it stuck in a recovery state and I can not do much.
    Lenovo X1 Nano Gen 1
    Type: 20UN - X021US
    S/N: R9 - 10W2D9
    I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
    So here I am to ask for help.
    I opened the laptop and I found a chip that may be the target, on it I've:
    Winbond 25R256...
    01-11-2025, 09:50 AM
  • Valtekken
    Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
    by Valtekken
    Specs:
    • CPU=AMD Ryzen 5 3500U
    • GPU=(integrated) Radeon Vega Mobile
    • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
    • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
    Hello everyone.
    My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
    A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
    09-10-2025, 04:14 PM
  • HotSaladMan
    Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
    by HotSaladMan
    *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
    Model : Lenovo ThinkBook 14S Yoga ITL
    S/N : MP28JT19
    MFG Date : 2022/02/09
    Factory ID PRC4
    MO : MPNXB26080FX
    MTM : 20WE001US
    MODULE FCC ID : PD9AX201NG
    IC : 1000M-AX201NG
    BOARD INFO
    FLV34 LA-KO51P
    REV : 1B 2020-08-24
    Bit of Info
    Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
    chip id, so i would always uncheck the id check, so it would bypass the error
    i did in fact make...
    11-07-2024, 07:46 AM
