A1278 820-2936-B Missing PP5V_SUS
  • Amraks
    • Nov 2011
    • 725
    All important voltages are there
    So noticed I have no voltage here
    PM_SLP_SUS_L 0.00v
    and have voltage here I understand this is a operator value for u7040 and PM_SLP_SUS needs voltage to turn on.
    SMC_BATLOW_L 3.30v
    These are voltages measurements I have taken I am unsure if this is a problem with PCH or SMC
    SYSCLK CLK32K RTC 0.81
    RTC RESET L 3.30v
    PHC SRTCRST L 3.30v
    PCH INTRUDER L 3.015v
    PCH INTVRMEN L 3.22
    PPVRTC_G3H 3.3v
    RTC_RESET_L 3.30v
    PCH_SRTCRST_L 3.30v
    PCH_INTVRMEN_L 3.22v
    PCH_DSWVRMEN_L 3.20v
    SYSCLK_CLK32K_RTCX1 0.81v
    PP3V3_S5 3.40v
    PM_DSW_PWRGD 3.47v
    PP3V3_SUS 0.00v
    PM_BATLOW_L 0.12MV
    PM_RSMRST_L 0.00v
    PM_PWRBTN_L 3.47v
    PP3V3_S5 3.41v
    PP5V_S3 0.00v
    P5VS3_EN_L 3.45v
    PM_SLP_S4_L 0.00v
    ADAPTER_SENSE 3.40v
    SMC_ADAPTER_EN 3.46v
    PM_SUS_EN 0.00v
    P5VSUS_EN_L 4.89v
    P5VSUS_SS 4.89
    PP5V_S5 5.0v
    PP5V_SUS 0.060v
    PM_SLP_SUS_L 0.00v
    SMC_BATLOW_L 3.30v
    PPVRTC_G3H 3.33v
    5V3V3_REG_EN 3.42v
    P3VS5_LL 3.341V
    P3V3S5_VBST_R 7.67V
    P3V3S5_VBST 7.67V
    P5VP3V3_REG3 3.34V
    P3V3S5_ENTRIP 0.731V
    P3V3S5_VFB 2.35V
    P5VP3V3_REG3 3.34V
    P5VP3V3_VREF 2.01V
    P5VS3_VFB 0.00V
    P5VS3_ENTRIP 0.00V
    P5VS3_VO1 0.00V
    P5V3V3_PGOOD 0.00V
    P5VS3_VBST 3.53V
    PS5VS3_DRVH 0.00V
    P5VS3_LL 0.00
    P5VS3_DRVL 0.00V
    PPBUS_S5_HS_OTHER_ISNS 12.63
    P3V3S5_EN_L 0.00V
    P3V3S3_EN_L 3.3V
  • mon2
    • 14634
    Re: A1278 820-2936-B Missing PP5V_SUS
    For the rails that you suspect to be incorrect, remove all power, meter in resistance mode (lowest scale).
    Check the resistance to ground for that rail.
    Post the resistance reading.
    • Amraks
      • Nov 2011
      • 725
      Resistance
      pm_slp_sus_l is 94.5k
      • Amraks
        • Nov 2011
        • 725
        I have solved this problem it was under PCH I pushed some flux under chip and heated with hot air at 200c.
        Then flooded under chip with alcohol and went back over with hot air.
        I had given up on fan spin and left it connected while I stepped out to the shop only to find it was still hot when I got back so I disconnected it and connected fan then had the fan spin.
        Reassembled laptop and it's fixed. Not sure how long or what was going on with PCH chip, laptop has been refurbished apparently so who knows what's been fixed on it before.
        But gave it hot and cold starts all week and it didn't fault once.
