MacBook Air A1370 charging issue
  • mon2
    • Dec 2019
    • 14667
    Re: MacBook Air A1370 charging issue
    With meter in voltage mode, place red meter probe on c7050 on one side. Black meter probe to ground.
    What is voltage when the battery is connected?
    Then repeat with red meter probe on other side of c7050.
    Expecting to see the same voltage as on the series resistors on these traces.
    Can you post pics of the logic board for this area?
    • 74kieran
      • Dec 2021
      • 33
      • Uk
      0v each side. And attached a image
      • 74kieran
        • Dec 2021
        • 33
        • Uk
        I will re check my PP3V42_G3H_REG voltage
        • mon2
          • Dec 2019
          • 14667
          Based on the post # 22 (0 volts on both sides of C7050) - it appears that you have broken traces.
          See attached.
          Remove all power. Meter in lowest resistance mode scale.
          Check the resistance between pads # 1 and #2. It should be about 0 ohms since this is a direct PCB trace (unless the trace is damaged).
          Confirm it.
          Then check the resistance between pad # 1 and # 3 (at the IC). Again, as a direct PCB trace, the resistance should be ~0 ohms.
          Confirm it.
          Then repeat for the other side of the cap @ C7050.
          If you see other resistance values, the PCB traces are damaged and can be repaired easily but first need to see these readings.
          Also, do test the resistance between pad # 2 & # 3 for the top of C7050.
          Then again for pad # 2 & # 3 for the bottom of C7050.
          This is to confirm which trace(s) are damaged.
          Update - from the posted pic - is there a solder short on the IC ??
          Apply flux on these IC pads -> hot air till the pads are no longer looking like they are shorted. Use low air pressure but high heat to allow the solder to melt and wick up under the IC.
          The pads look like they are shorting.
          • 74kieran
            • Dec 2021
            • 33
            • Uk
            I agree it does look like there is a solder short. Going to order a better microscope now which hopefully comes tomorrow so can double check. It seems i get 0.03ohms on R7051 and 0.01ohms on R7052.
            When it comes tomorrow I will double check and update the thread.
            Thanks for your help
            • 74kieran
              • Dec 2021
              • 33
              • Uk
              #26
              I don’t think they are touching. I have included a photo. It’s strange as I had no continuity before plugging it in. Soon as I plug a charger in and unplug it. There is no continuity. I’m get 0.03-0.04 ohms. Would this be a faulty IC chip do you recon?
              • 74kieran
                • Dec 2021
                • 33
                • Uk
                #27
                • mon2
                  • Dec 2019
                  • 14667
                  Can you provide detail on how you are measuring this area of the circuit?
                  Follow the schematic for a point of reference and post the measurements for each leg of the parts with their resistance values.
                  The IC may be faulty but we should first check each measurement.
                  • 74kieran
                    • Dec 2021
                    • 33
                    • Uk
                    #29
                    Sorry it has been a while. I have done some further testing. Here are all of my finding so far
                    U7000 Pin 18 to R7051 pin 1 is 0hms Voltage of R7051 pin 1 is 0.16v
                    U7000 Pin 17 to R7052 pin 1 is 0hms Voltage of R7052 pin 1 is 0.16v
                    C7050 Pin 1 is 0.17v (This does move around 0.13v-0.18v)
                    C7050 Pin 2 is 0.17v (This does move around 0.13v-0.18v)
                    U7000 Pin 18 is 0.18v
                    U7000 Pin 17 is 0.18v
                    The schematic you shown for U7000 is for a different board. Is there a way of testing the voltage going into the IC Chip.
                    • 74kieran
                      • Dec 2021
                      • 33
                      • Uk
                      #30
                      Currently looking at U9480 as there is no voltage on any pin. I am currently following schematics backwards to see where the 3.3v stops
                      • 74kieran
                        • Dec 2021
                        • 33
                        • Uk
                        #31
                        Is there any common issue to this sort of issue?
                        • 74kieran
                          • Dec 2021
                          • 33
                          • Uk
                          #32
                          I have found the the green light only works when laptop is on. But the laptop still decharges. I have also found if the laptop is used without battery then it will shutdown randomly(Anywhere up to 1 minute). I have also found that L7630 is getting hot
                          • drlarsen
                            MacBook Air M1 A2337 battery/charging issue
                            by drlarsen
                            Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                            I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                            On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                            After some hours, the battery status did not improve. Restore via DFU did not help.
                            I connected the power adapter to a Kill-a-Watt...
                            07-17-2025, 02:35 PM
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • Simone Vergani
                            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                            by Simone Vergani
                            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                            To assist with troubleshooting, I'm attaching two power circuit schematics:
                            • Power
                            03-05-2025, 02:25 PM
                          • Julian Bailey
                            HP ProBook 445 G8 Battery not charging
                            by Julian Bailey
                            Hi all
                            We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                            The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                            I have gone around the board with a MM and cant find anything
                            Windows shows the battery fine,...
                            10-11-2024, 10:34 AM
                          • Schluchti45
                            MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
                            by Schluchti45
                            i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
                            Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
                            11-18-2024, 02:05 AM
