any way to bypass this lock
Need help to fix A2159
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by SpudgunHello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
Channel: General Capacitor Questions & Issues
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks -
what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
by oxonaterHi everyone hope all are well
I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
I suppose it's worth noting googling the part package brings up various... - Loading...
