Mac A1502 main 820-3476a no video
  • reset1986
    • Dec 2014
    • 308
    • italia
    hello everyone, I have this motherboard that does not give an image, black screen,
    the mac turns on, charges the battery, but it does not ring and remains with black with an absorption from 0.85A 16.5v
    I flashed the bios chip, smc and CPU reflow but the situation remains unchanged
    there is no liquid damage and the main lines supply power
    Do you have any suggestions?
  • mon2
    • 14316
    Re: Mac A1502 main 820-3476a no video
    Post the voltage of PPBUS_G3H.
    Does the CAPS key led toggle after boot?
    Do you see any graphics on the lcd with a flashlight?
    Reflow of the CPU is risky without a proper bga rework station.
    See:
    https://repair.wiki/w/A1502_2013-201...ook_Pro_Retina
    • reset1986
      • Dec 2014
      • 308
      • italia
      yes i have a professional bga machine from honton,
      I have the 3.3v the machine turns on, the fan runs, there is no activity on the CAPS key, external screen not working,
      it is a classic defect of gpu, can I measure some signal in particular?
      See:
      • reset1986
        • Dec 2014
        • 308
        • italia
        I performed a reballing on the CPU, but the situation does not change, ignition and black, no CAPS key activity, absorption 16.5V 0.85A,
        I wanted to ask if they were the rams I could hear the beeps on ignition?
        I performed a reballing on the CPU, but the situation does not change, ignition and black screen, no CAPS key activity, absorption 16.5V 0.85A,
        See:
        • dellxps15
          • Feb 2014
          • 1590
          • italy
          i have just repaired one 820-3476 today.
          1° never reflow things if not needed
          2° without battery, when fan start spinning do you have magsafe light turning green then orange?
          3° cpu voltages on coil present ? pch core ? report volts here
          4° jtag connector already removed ?
          5° tried with pram reset ?
          6° try with external monitor and usb osx image on usb slot.
          7° if board is outside case whatchout from inserting display port correctly otherwise ull burn dcin.
          8° keep in mind that that lcd if no backlight is very dark and really hard to see if it's a backlight issue if u dont have a powerfull light to see it.
          9° report omh on cpu coils (black on gnd) and red on cpu coil or white resistor near cpu it should be around 170ohm
            HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
            This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
            09-12-2024, 02:00 PM
          • zimeyh
            Problem video A1502
            by zimeyh
            Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
            11-15-2023, 03:19 AM
          • iizik
            P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST need main and video BIOS
            by iizik
            P15 Gen 1 (type 20ST, 20SU) Laptop (ThinkPad) - Type 20ST needs the main BIOS and video. The client says that after the Windows updates there was a firmware update and after that the device makes the sound of music when there is no screen. Moreover, if you turn it on several times then the picture sometimes appears and it works and passes all tests (wonder)
            and may even reboot normally a couple of times
            Now he doesn't want it anymore, no matter what I tried
            It helped to change the video cable a couple of times, I ordered a new cable, it didn't help
            Of course I checked the...
            07-17-2024, 09:58 AM
          • alltvrepairs
            Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
            by alltvrepairs
            I have confirmed that I have a mainboard problem.
            I have tracked no hardware issued on board so might be a software dump required.
            I have searched a bit but wasn't able to find anything for my screen:
            Here are some more details:
            Panel: cy-nn065hgev1h
            Main: BN94-14180M P08F
            Your help much appreciated!
            05-16-2025, 03:03 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
