HP 15-DA0005TU (LA-G073P) not turn on , no display
  • alankanyl
    • Jan 2022
    • 6
    • China
    Preamble: Not water damage. Suddenly black screen during use, can't turn on afterward.
    This is my first chip-level laptop repairing.
    Detail diagnosis: AC LED on, battery charge normal. Power LED on but no display and no error LED blinks. Long press power button can turn off the power LED. When no RAM, power LED is keeping on and all know voltage is present(detail is as below). When RAM is installed, no display, all voltage measured but the power self turns off after 30 sec.
    Voltage measured:
    V19: 19.7V
    3VALW: 3.36V
    5VS: 5.02V
    3VS: 3.36V
    V2P5: 2.57V **
    V1P8: 1.82V
    V1P2: 1.24V
    V1P05: 1.05
    VNN: 1.02V
    VCGI: 0.72V
    VDDQ: 1.2
    VMemory: 1.2V
    VTT: 0.6V
    Basically, all LDO or DC-DC can be measured with the correct output. The above V2P5 is just a guess from the label (broad label PU2501), Gemini-Lake does not define this power rail.
    While on, measure with an oscilloscope: 19.2M/32.768K oscillate, G781 temperature IC reports <35C. LCDVDD low seems epd_vdden is low (since no schematic is available, it is just a guess from a similar schematic of LA-G07EP)
    Tried cleaning original bios, same symptom. Tried HP stock bios without any modification, 5.3 blinks.
    Conclusion:
    POST fails at VGA initialization with a timeout. Possible faults from 1) fried CPU, 2) support circuit for display, or 3) RAM. Since I don't have another RAM module to verify, I wish to rule out 1) and 2) first.
    Any suggestion on further diagnosis??
  • lapfix
    • Mar 2020
    • 2764
    • my workshop
    Re: HP 15-DA0005TU (LA-G073P) not turn on , no display
    i faced same issue , same 5.3 blinks and strange i solve it with this bios ( not same txe region ! ) so try post #20
    https://www.badcaps.net/forum/showthread.php?t=94441
    • alankanyl
      • Jan 2022
      • 6
      • China
      Thanks to Lapfix, but it does not work. With this bios(at post#20), there is no timeout after 30sec but still, no display, and epd_vdden remains low.
      I have compared this bios with HP stock bios. It is very similar to version F35, except for the DMI region and 3C8420~3C8453. It may be some code at 3C8420~3C8453 that disabled the timeout function.
      From a good point of view, bios issue can be ruled out
      • Udemzy
        • May 2017
        • 164
        • Guatemala
        How can you rule out bios issue when the one you compared don't have same bid number?
        • mon2
          • 14664
          Without the ram, will the laptop remain on indefinitely?
          • alankanyl
            • Jan 2022
            • 6
            • China
            all bios compared with same BID:084AA
            • alankanyl
              • Jan 2022
              • 6
              • China
              Yes, it keeps on indefinitely without RAM. All mentioned voltage present.
              • mon2
                • 14664
                Test again with different known good ram.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Might be defective kbc . Have u programmed the kbc??
                  • alankanyl
                    • Jan 2022
                    • 6
                    • China
                    No, I haven't programmed the kbc. Thanks for this inspiration.
                    One point I wish to clarify. In desktop, bios initialize video before kbc check. At which kbc error will be reported on screen. Does Laptop bios go in different way?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      I dont agree with your views regarding desktop.
