Doubts with a diode Lenovo A10-70 Tablet (A7600-F)
  • Arkangelus
    • Feb 2021
    • 20
    • Chile
    Hi friends! I am trying to repair this tablet and I found that this zener diode (part number CDZ55C5V6S) has a hole in the middle (attached photos and schematic). I have searched on Aliexpress, to order that diode, and I can't find it.
    My question is, will there be a replacement for this diode? And which diode could replace it that is similar to this?
    Thank you very much in advance for reading my question
  • mon2
    • Dec 2019
    • 14106
    Re: Doubts with a diode Lenovo A10-70 Tablet (A7600-F)
    What is the part # reference in the schematic for this blown (holy?) part ?
    Which connector is on the other side of this blown part ?
    Never mind - datasheet is attached. Looks to be a 5v6 zener. Let me look around.
    • Arkangelus
      • Feb 2021
      • 20
      • Chile
      Thank you very much for answering. On the other side there are no more components and it is perfect. Nothing burnt. It's just that diode that has a big hole in it.
      • mon2
        • Dec 2019
        • 14106
        Ran out of time earlier...this is an 0805 smd size zener diode at 5v6 rating. Nothing special.
        100PCS SMD Zener diode 0805 0.25W BZT52C10V 3V 3V3 7V5 6V8 5V6 5V1 4V7 12V 10V 15V 16V 18V 20V 24V SOD-323
        https://a.aliexpress.com/_mKycjrW
        Select the 5v6 rated part.
        • Arkangelus
          • Feb 2021
          • 20
          • Chile
          oh man! You are very kind to help me with this. I'm a newbie who's been at this for a very short time and it's wonderful to find people like you willing to help. Eternally grateful for your time and disposition. Thank you very very much!!!
          • mon2
            • Dec 2019
            • 14106
            No worries. One extra comment is that the original part appears to be a 500mW rated part = 0.5W.
            The one I have linked is 250mW rated = 0.25W.
            Ask each vendor if they can supply in 0805 size, the 500mW part at 5v6. Certainly supply the original part # from the above datasheet. They should be able to find it.
            Good luck!
              Lenovo ThinkPad X1 Tablet (3rd Gen) Hybrid (2-in-1) X Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad X1 Tablet (3rd Gen) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Tablet (3rd Gen) boardview and X1 Tablet (3rd Gen) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 08:47 AM
            • unimatrix93
              TV backlight zener diode
              by unimatrix93
              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
              The led strips has 9 6V leds.
              02-10-2025, 12:13 PM
              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
              by sam_sam_sam
              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
              I bought this from an eBay seller but unfortunately they only had one
              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
              I bought three of from them to also make battery packs with this output power limit in mind
              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
              04-23-2025, 05:50 AM
            • nev1001
              What zener diode might fix the sound on Maestro Mayhem gaming chair?
              by nev1001
              Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
              The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
              It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
              I think an issue could be a zener diode (or capacitor) which has shorted out.
              The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
              04-17-2025, 05:09 PM
            • Vincenzo2
              Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
              by Vincenzo2
              My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
              Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
              I put some pictures here to show that it is labeled "M7"....
              09-07-2023, 07:43 PM
