Dell Inspiron 5378 Charging Issue
  • mgrharry
    • Sep 2016
    • 211
    • usa
    Working on a Dell Inspiron 5378. Initially system had a short to ground. Injected voltage and found bad cap. Short gone, system powers on, but does not detect charger properly, despite known good dc jack and charger. It's a bit different from usual power id issue-- in bios it shows "AC Adapter Unknown" if power is plugged in but it also shows battery discharging and if AC is unplugged it does not update, still shows AC adapter unknown until system is rebooted. If powered up with no AC adapter it reports that correctly.
    Photos attached.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Inspiron 5378 Charging Issue
    What is the mb code?? SIO number??
    • mgrharry
      • Sep 2016
      • 211
      • usa
      SIO mec1404.
      ncp81208 voltage regulator.
      Motherboard
      DPN 0pg0mh
      P/N: 455081010002
      mo: 28155885 VER: 1B
      STARLORD13_R
      Thank you.
      • mgrharry
        • Sep 2016
        • 211
        • usa
        Is that the info you needed?
        • mgrharry
          • Sep 2016
          • 211
          • usa
          ISL 95521AHRZ
          https://cdn.badcaps-static.com/pdfs/...58450f7479.pdf
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            MEC1404-Pin36 is PS_ID. Check whether you have voltage here or not?? Also resistance on this pin??
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • computerbacon79
              Dell Inspiron 3480 All in One corrupt Bios issue
              by computerbacon79
              The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
              05-06-2025, 06:43 PM
              DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
              09-12-2024, 03:36 PM
              DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
              This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
              09-12-2024, 03:30 PM
