Macbook Air, no backlight 820-3024
  • ginobarabasi
    • Feb 2022
    • italy
    Hello everybody, this is my first post of this very interesting forum. I hope I can give my help if I can.
    I am having a problem with Macbook air, board 820-3024: there is no backlight.
    I measured some voltages and found the following:
    PPBUS_SW_LCDBKLT_PWR = 8V
    PPBUS_SW_LCDBKLT_PWR_SW = 7.8V
    PPVOUT_SW_LCDBKLT = 7.6V (I think it should be more high)
    I tested:
    D9701 seems OK
    C 9796 seems OK
    C 9797 seems OK
    C 9799 seems OK
    L9701 seems OK
    F9700 seems OK
    at this point I suppose it could be the U9701 damaged, but before trying to change it, I ask all of you if you have any advice.
    Thank you everybody
  • mon2
    • 14666
    Re: Macbook Air, no backlight 820-3024
    Correct. It should be. In the range of 25-50v when enabled.
    measure the voltage readings for:
    BKL_SCL
    BKL_SDA
    BKL_EN
    Post the measurements.
    The backlight IC is the LP8550 from TI and is a very common part that does get damaged. The intensity and function of the component is configured using the 2 wire I2C line (SCL & SDA).
    Using an I2C bus analyzer, you can monitor the traffic to learn more or review the datasheet from TI's (not the rapper) website.
    • piernov
      • Jan 2016
      • 4439
      • France
      Bkl_pwm
      • ginobarabasi
        • Feb 2022
        • italy
        thank you for the help. I think I should view these signals with an oscilloscope, because the mean value measured with a multimeter is not useful, right?
        • mon2
          • 14666
          A voltage meter check should be fine for the I2C and enable line check.
          The scope will help for the PWM line.
          I2C is an open drain interface that will feature pull-up resistors on each, the SCL & SDA lines. We are checking for stuck logic levels on the I2C bus which will cause faults.
          Often the exercise results in the replacement of the LP8550 device which is a WLCSP packaged component. With care, it is not difficult to replace.
          • Comp_Pro
            No Backlight Macbook A1990 820-01041
            by Comp_Pro
            Hello all,
            Am trying to figure out this backlight issue with this A1990 Macbook Pro.
            Tests performed:
            There is no backlight even with a good screen.
            Backlight IC is receiving the correct support voltages.
            Fuse F8400 ok
            Current sense resistor R8400 ok
            Backlight IC is receiving 3.3V on enable pin.
            Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
            Backlight IC receiving 5V from PP5V_G3S
            Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
            I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
            05-06-2024, 10:23 PM
          • Constantinos
            Macbook Pro A2442 820-02098 No image but has backlight
            by Constantinos
            Hi all
            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
            Obviously, he decided against this and gave it to me so that I could have a crack at it.
            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
            08-24-2024, 09:48 AM
          • francescoranchi
            MacBook Pro A1909 LCD (no backlight)
            by francescoranchi
            Hello Everyone,
            I'm looking at purchasing a used LCD from ebay for my macbook A1990 2018 15inch which LCD I cracked. Since new / used but working displays cost around 500$ , I found a Grade A+ LCD display for A1990 which has a good price of 110$ but has no backlight.
            I would need just to make sure that what I know/my reasoning is correct:
            - No backlight means flexgate issue, therefore changingthe flexcable would be enough (I can microsolder to fix the flexgate problem, done it a few times already)
            - Seller confirmed its a LCD issue, and not an issue with the...
            12-04-2023, 06:46 AM
          • tommy97
            Apple MacBook A2337 - No backlight
            by tommy97
            Hi guys, I've got MacBook Air a2337 with no backlight. Once while testing it displayed with the backlight, however after restart problem come back.
            The laptop was tested with fully working screen.
            PP5v_BKLT_A/B 5V
            PP5v_BKLT_D 5V
            PP5V_S2 5V
            PP5V_SW_LCD 0.4V
            P5VS2_PWR_EN 1.8V
            P5VS2_BST_R 8V
            P5VS2_SW 5V
            PPBUS_5VS2_VIN 5V
            PPVOUT_LCDBKLT - Doesn't short 0V
            FP800 - Both sides 12v
            BKLT_EN_R & BL_PWR_EN - around 1.8v
            LP800 0.014V On both sides (should be 12? / no short)
            UC300 & UP800 Replaced...
            12-02-2024, 08:26 AM
          • rcanpolat
            M1 MacBook Pro 2021 A2485 - No backlight display
            by rcanpolat
            I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
            Here’s what I’ve observed so far:
            • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
            • I did some basic resistor
            08-24-2025, 02:16 PM
