does anyone knows the replacement for this mosfet mdu1514?I cannot find same mosfet anyone can help please
					mdu1514 replacement
	Tags: None
 Re: mdu1514 replacement
 See attached. The TI part CSD17578Q5ATshould work.
 https://www.ti.com/product/CSD17578Q...#order-quality
 https://www.aliexpress.com/wholesale...psort=1&page=1Last edited by mon2; 02-26-2022, 07:19 AM.Comment
			by DoOm86Hello.
 I have a notebook with a shorted mosfet, it's a E6930 GA8125.
 It seems to be a 30V dual asymmetric N-channel AlphaMos.
 Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
 And here is where I need help!
 It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
 I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
 Thanks!...
			by jm942Hi,
 My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
 I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
 I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
 I did voltage injection on the cpu with 0.7V and i have a current...
			by JaneI tried to use this method:
 Testing an N-channel MOSFET:
 Step 1: Discharge the Gate (turn off the MOSFET)
 Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
 Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
 Step 2: Charge the Gate (turn on the MOSFET)
 Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM
			by String2016Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
			by String2016i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
- Loading...
