Acer E1-570G | Z5WE1 LA-9535P
  • fezmonki
    • Feb 2022
    • Italia
    Hi everyone. I'm trying to step up my repair game from replacing bits to logic board repairs, and have my first patient.
    Issue: Laptop turns on, steady power led, orange battery led, blinking HD led.
    After research, it seems this laptop frequently has BIOS issues. So I:
    1. Purchased a CH341A eeprom programmer with clip.
    2. Read the bios multiple times.
    3. MD5 hashed them, they all came out different.
    4. Wrote the correct bios anyway.
    5. Laptop now still shows power led, but no HD activity. It will still engage in BIOS recovery mode with the keyboard combination.
    6. Purchased a new BIOS chip off ebay.
    7. Wrote the BIOS on this one, and swapped it in, no change.
    Now, after watching a bunch of videos on youtube, I went hunting for shorts on the motherboard lol. I did find a whole bunch of shorted caps, all the circled ones (and probably more I forgot between taking the picture and getting to the computer):
    Does anyone have any ideas of where to start or do I just start desoldering caps till the short is gone?
    Confession time: Between steps 5 and 6, I removed the screen cable after removing the power connector but forgot the battery in and saw a tiny spark. Unsure if related.
    I inspected the whole board under a lens and can't find any physical evidence of damage.
    Thank you.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Acer E1-570G | Z5WE1 LA-9535P
    https://www.badcaps.net/forum/showthread.php?t=88758
    When requesting help, please attach a picture of the board with voltage and resistance to ground measurements on all the large inductors after triggering power button.
    2.2. Don't suspect that something is shorted with no reason
    Shorted components are not the only failure mode of a laptop. Additionally, some places will measure low resistance to ground under normal operation. In general, high power low voltage (<2V) power rails will measure less than a few hundred ohms to ground. CPU VCore will measure a few ohms only. GPU VCore with newer NVidia GPU can even measure less than 1 ohm. It's normal. If you suspect a short to ground, always report your exact resistance to ground measurements.
    • fezmonki
      • Feb 2022
      • Italia
      Thank you, I followed your thread.
      1. The board is currently not POSTing, ram has been reseated, changed, cleaned.
      2. CPU Voltage was measured at 1.12v.
      I'd like to add the situation has gotten worse since reflashing the bios and changing the chip. It used to show activity on the USB port and attempt BIOS recovery via FN + ESC (fan sped up and USB key flashing a sequence), but ever since reflashing the first time, it only lights up the power LED and nothing happens.
      That should indicate there's an issue with the BIOS, but I tried both brand new Winbond 25Q64FVSIQ (same as the one originally on the board) and Winbond 25Q64FVSIG (what I found people selling as a replacement on ebay) chips, flashed multiple times with 1.0 BIOS I found on some forum, and 2.06 off Acers website but nothing. Motherboard shows the BIOS chip is getting its 3.3 volts, and if I start the motherboard without the BIOS chip, it complains by continuously shutting on and off.
      I'm unsure where to go from here.
      • EbrahimSiami
        Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
        by EbrahimSiami
        I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
        **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
        **What I have tried so far:**
        1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
        07-02-2025, 02:31 PM
      • Wg188
        ACER Veriton Z4660G AIO bios help
        by Wg188
        I have an Acer veriton Z4660G all in one pc,
        Model: Z4660G-I5850H1 (VZ4660G_W)
        Need bios dump and schematic would save my life !
        to make a long story short I bought this all in one used
        with a broken lcd, with the objective of making a custom desktop out of it
        ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
        06-17-2023, 02:20 PM
      • James194zt
        Acer Nitro 50-640E Corrupted BIOS Dump
        by James194zt
        My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
        All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
        04-28-2025, 03:29 PM
      • Amohac
        BIOS LOCKED ACER R753T-C1LK
        by Amohac
        Hi, I have an Acer Chromebook R753T
        with administrator lock. Could something be done in the BIOS. Attached is the “BIN” backup.
        Thank you.
        Computer:
        Acer Chromebook R753T-C1LK
        Mother: DA0ZCAMB8D0 NETWORK: D
        HSB J / 94V-0 / E89382 / 442 1/ MV-4
        Bios: WINBOND 25Q128JVPM /2139/ M138/ 42300
        16 MB
        Serial NO: NXA8ZAA0031501A1A87600
        SNID: 15010692076
        Model NO: N20Q10
        MFG Date: 2021/12/20....
        06-30-2025, 06:05 PM
      • ub6ib969
        Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
        by ub6ib969
        Model Number: PO3-650
        Part Number: DG.BK4AA.006
        Serial Number : 33400117730
        BIOS IC : XM25QH256C
        I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
        07-02-2025, 03:51 PM
