help acer v3-471g backlight problem....
  • rheyntau
    • Feb 2021
    • 29
    • philippines
    hi guys....gud day ...i have an acer v3-471g
    DAZQSAMB6E0 REV E model ZQSA
    the problem is after 5 to 10 mins the backligt is off but i can see the display/graphics with a flashlight...
    i already try other lcd and it has same probmem......
    can anyone help me.....
    thanks in advance...
  • mon2
    • Dec 2019
    • 14256
    Re: help acer v3-471g backlight problem....
    Hi. Can you post the schematic? Or link it if it is on this forum.
    • mon2
      • Dec 2019
      • 14256
      I think I have the schematic for this logic board.
      Update - referenced the wrong schematic earlier from the database.
      measure the voltage on pin # 26 (BL_ON) of the CN1 connector:
      a) when the backlight is ON
      b) when the backlight is OFF
      • rheyntau
        • Feb 2021
        • 29
        • philippines
        this is the schem....
        • rheyntau
          • Feb 2021
          • 29
          • philippines
          i test the voltage on bl_0n whenthe backlight is on 3.2v and when it off after 5 mins.... 0.5v.....
          • mon2
            • Dec 2019
            • 14256
            How do you get the backlight to turn on again? Power cycle the unit?
            What is the history of the unit? Liquid damage?
            Perhaps a lid sensor fault and the logic board thinks the lid is closed.
            Can you turn off all power savings mode?
            What if you enter the bios setup screen and leave it on this screen? Will the display backlight remain on ? Test the idea. Leave it on in bios mode for 15-30 mins.
            • rheyntau
              • Feb 2021
              • 29
              • philippines
              itry to turn on and off...its dsame if i turn it off for how many hour and if i open it again the backlyts on and after 5 mins it off and if i torn ooff it again and on it again the backlyt is off even ot boot...
              i try to injected 3v on bl on and the backlyt on...
              • rheyntau
                • Feb 2021
                • 29
                • philippines
                update i try to remove Q2 and test it now it has a backlyt ...d Q2 marking code is K72 F.....i have a scrap board and the transistor code is K72 X1 ist d same?
                • mon2
                  • Dec 2019
                  • 14256
                  What is the voltage on pin #2 of Q1 mosfet ?
                  Voltage on pin #2 of Q3 ?
                  To check if a mosfet is damaged, remove all power.
                  Meter in resistance mode (2k scale).
                  Check the resistance between:
                  Source and drain
                  Source and gate
                  Gate and drain
                  Of each mosfet Q1 and Q2.
                  Q2 may be ok. If you remove Q2, backlight will work since the default pull up voltage of ~3v will appear on the BL_ON pin due to pull up resistor @ R40.
                  First need to confirm if any of the mosfet driver parts are being turned off for this signal line.
                  Post your voltage readings.
                  • rheyntau
                    • Feb 2021
                    • 29
                    • philippines
                    thank you so much for the help and advice..i replace Q2 and now its fine ....
                    Last edited by piernov; 02-17-2022, 05:15 AM. Reason: remove full quote of previous post
                    • KleeMapple
                      • Nov 2022
                      • 3
                      • Philippines
                      hi guys newbie here can u gave me a pic were Q2 located on board DAZQSAMB6E0 REV.E MODEL :ZQSA . I got a same problem like yours sir .
                      • mon2
                        • Dec 2019
                        • 14256
                        Hi. Personally have never seen the board and do not see a boardview file in my database.
                        Review the connector for the LCD display. This backlight circuit featuring Q2 should be nearby. The mosfet is very common and is a SOT23 package (3 legs) = 2N7002.
                        See attached as a reference for the component shape. Do not worry about the topside markings as your logic board may be fitted with a different version of the same part (many vendors build this part).
                        Post clear pics of the LCD connector and nearby parts for a review. About to enter my beauty sleep mode after a bit of Aliexpress shopping...
                          • 21002
                          ZQSA Rev F boardview https://www.badcaps.net/forum/showthread.php?t=50906
                          • mon2
                            • Dec 2019
                            • 14256
                            Thanks @SMDFlea.
                            See attached.
                            • KleeMapple
                              • Nov 2022
                              • 3
                              • Philippines
                              Thnx.^^ guys i know where to look now.btw can i ask? i had old laptop that has q5 to q36 or bunch of it.can i used it to replaced dmg Q1 o Q2?
                              • KleeMapple
                                • Nov 2022
                                • 3
                                • Philippines
                                Or should i chck its volts?
                                • mon2
                                  • Dec 2019
                                  • 14256
                                  On the laptop that is not working, measure the voltage to ground of each pin of Q2.
                                  Meter in dc volts, 50 volts or higher scale. Backlight is usually a higher voltage of 25-50 volts.
                                  Red meter probe to point to test.
                                  Black probe to ground.
                                  Post each measurement.
                                  • grbo92
                                    Backlight problem Acer LA-031P
                                    by grbo92
                                    i have one acer Nitro 5 without backlight on my desk.
                                    Mainboard model: LA-L031P GH53Z REV 1B
                                    Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                                    11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                                    Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                                    Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                                    09-09-2024, 03:49 AM
                                    09-06-2024, 05:27 AM
                                  • Dobrowol
                                    Asus GA402RK keyboard and kb backlight problem
                                    by Dobrowol
                                    Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                    04-28-2025, 04:30 PM
                                  • fmajbour
                                    Acer Nitro 5 model A515-51 keyboard problem
                                    by fmajbour
                                    I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                    Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                    i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                    I have check the keyboard connector on the mainboard every thing looks ok.
                                    Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                    I need your advice if anyone face...
                                    11-13-2023, 09:50 PM
                                  • ahmarzo
                                    Acer TMX314-51 laptop battery problem
                                    by ahmarzo
                                    I have acer laptop tmx314-51 with part no 6050A3020501.
                                    The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
                                    But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
                                    I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
                                    The schematic is not available...
                                    04-11-2025, 09:14 AM
