TOSHIBA C40-D Cant use new battery
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    Hi all my colleagues, today I want to ask you guys for help, maybe someone can take the time to help me with this toshiba C40-D mobo problem, the problem is, when using a new battery, it can't turn on even though I use a charger too and only lights the indicator flashes orange, I've swapped this new battery up to 3x but the result is still the same, and I can't find a schematic for this mobo, and this is the measurement for each pin on the ISL88732 charger ic when using a new battery (Without charger)
    PIN1(NC)= 0V
    PIN2(ACN)=0.23V
    PIN3(VREF)=0V
    PIN4(ICOMP)=0V
    PIN5(NC)=0V
    PIN6(VCOMP)=0V
    PIN7(NC)=0V
    PIN8(ICM)=0.10V
    PIN9(SDA)=3.29V
    PIN10(SCL)=3.29V
    PIN11(VDDSMB)=3.34V
    PIN12(GND)
    PIN13(ACOK)=0.01V
    PIN14(NC)=0V
    PIN15(VBF)=11.5V
    PIN16(NC)=0V
    PIN17(CSON)=11.5V
    PIN18(CSOP)=11.5V
    PIN19(PGND)
    PIN20(LGATE)=0V
    PIN21(VDDP)=0V
    PIN22(DCIN)=1.15V
    PIN23(PHASE)=11.5V
    PIN24(UGHATE)=11.5V
    PIN25(BOOT)=11.12V
    PIN26(VCC)=0V
    PIN27(CSSN)=11.01
    PIN28(CSSP)=11.01V
    below I attach the schematic of the toshiba C40-A which uses the same charger ic
  • mon2
    • Dec 2019
    • 14667
    Re: TOSHIBA C40-D Cant use new battery
    Does the laptop work to power on with the power adapter (remove the battery to test) ?
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      when using a power adapter (without a battery) it turns on properly, but when using a power adapter with a battery it won't turn on, and using a battery only without a power adapter can't turn on either.
      • mon2
        • Dec 2019
        • 14667
        Need to check the BATTERY mosfet.
        Locate the mosfet and then remove all power (no battery).
        Use meter in resistance mode (2k scale is ok).
        Check & post the resistance between:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Suspecting that you have a defective battery mosfet but it is only from the past reviews of similar cases.
        Once you find the battery mosfet, post a pic or at least the full markings on the component. Assuming that this will be a common 8 pin N-channel mosfet with 8 pins as per above labels.
        • Yosua
          • Jun 2021
          • 221
          • Indonesia
          thanks for your help, this is for battery fet measurement with 2k mode
          s-d = 467 ohms
          s-g = not showing
          d-g = not showing
          I think there is no problem with this battery fet.
          I forgot to tell you, that this laptop can work when using the old battery but can't charge and must use an adapter
          • mon2
            • Dec 2019
            • 14667
            s-d = 467 ohms
            is a low reading.
            reference - see the RESISTANCE chart for source-drain
            http://electronicsbeliever.com/how-t...-is-defective/
            Can be caused by this battery mosfet being defective.
            What are the markings on this mosfet ?
            • Yosua
              • Jun 2021
              • 221
              • Indonesia
              is a low reading.
              Reference - see the resistance chart for source-drain
              can be caused by this battery mosfet being defective.
              pq19 = 4439gmt
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                is a low reading.
                and this is the voltage measurement on pq19
                using a new battery (without adapter)
                pins 1,2,3= 11.12v
                pin 4= 2.64v
                pins 5,6,7,8=11.12v
                using new battery and plugged adapter
                pins 1,2,3= 19.12v
                pin 4= 18.81v
                pins 5,6,7,8=11.12v
                • mon2
                  • Dec 2019
                  • 14667
                  Datasheet for the mosfet is attached.
                  It is a p-channel enhancement mosfet. So to turn this mosfet ON, the GATE must be more negative than the voltage on SOURCE / DRAIN.
                  reference:
                  http://www.learningaboutelectronics....hannel-MOSFETs
                  The gate voltage looks good to turn it ON.
                  Concern is if this mosfet is ALWAYS on due to damage since the resistance between source & drain is quite low for the mosfet.
                  I would consider to at least remove this mosfet -> measure the mosfet leads again when it is out of circuit but recommend to replace with a known good mosfet.
                  The laptop will have I2C (SMBUS) interface pins (SDA & SCL).
                  Without power & no battery, what are the resistance readings for these lines to ground ? Need to be sure that the battery gauge is working.
                  When you are using the laptop with the adapter AND the battery is connected, what does Windows report on the status of the mated battery ? Can Windows even find the battery ? What is the % charge reported by Windows ?
                  • Yosua
                    • Jun 2021
                    • 221
                    • Indonesia
                    for the resistance of the SDA and SCL pins on the 632 ohm battery connector for these two pins.
                    and when using an old battery it can light up but can't charge but the battery can be detected
                    • Yosua
                      • Jun 2021
                      • 221
                      • Indonesia
                      pq19 measurement when disconnected from mobo
                      s-d=497 ohms
                      s-g= not showing
                      d-g= not showing
                      • Yosua
                        • Jun 2021
                        • 221
                        • Indonesia
                        any one can help me?
                        • mon2
                          • Dec 2019
                          • 14667
                          Replace this mosfet and test again.
                          • Yosua
                            • Jun 2021
                            • 221
                            • Indonesia
                            thank you sir for your advice, but i have replaced it and the result is still the same, does this have nothing to do with TEMP_BATT or pin ID on the battery connector?
                            • mon2
                              • Dec 2019
                              • 14667
                              What are the resistance readings for the replacement mosfets?
                              Which replacement mosfet was used for this repair?
                              Next, with the power on, what are the voltage readings for the I2C (smbus) lines. These should be ~3v3 for each.
                              With only the battery, what are voltage readings on the mosfet?
                              Post the above values.
                              • mon2
                                • Dec 2019
                                • 14667
                                Interested in the MBDATA and MBCLK voltage readings with the battery connected.
                                Be sure that the battery connector pins for these 2 lines are reaching the charger IC. You can confirm this with removing all power.
                                Meter in resistance mode (2k scale). Then check the resistance between the battery connector pin and the target IC. We cannot have a break on these communication lines.
                                • mon2
                                  • Dec 2019
                                  • 14667
                                  Does this mean that Windows is able to report a battery % value?
                                  While power adapter is attached, the battery % continues to deplete and does not charge? The resistance to ground for the I2C lines looks low so concerned if these lines are ok.
                                  • Yosua
                                    • Jun 2021
                                    • 221
                                    • Indonesia
                                    for the smbus voltage everything is normal sir, there is no problem and appears 3v when using the battery or not using the battery, and I measured with a buzzer between the battery connector and this smbus pin there is no sign of a broken line
                                    and when using only batteries, the mosfet shows 11v and I think that's normal right?
                                    for replacement mosfet have 478ohm sir
                                    • Yosua
                                      • Jun 2021
                                      • 221
                                      • Indonesia
                                      sorry for taking so long to post this, because i was trying to work on an easier mobo first, and now i'm still fighting for this c40d mobo
                                        NVDC charger configuration...
                                        11-05-2024, 03:28 PM
                                        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                        Narrow VDC applications where the system power source is
                                        either the battery pack or the regulated output of the charger.
                                        This makes the max voltage to the system equal to the max
                                        battery voltage instead of the max adapter voltage. Operating
                                        at lower system voltage can improve...
                                        11-05-2024, 04:43 PM
                                      • flat-earther
                                        how to prevent a connected charger from draining battery when not charging?
                                        by flat-earther
                                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                        So the battery is backfeeding the charger and being drained.
                                        How can I prevent...
                                        08-07-2025, 01:04 PM
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                        Bauer tool battery pack charging with a HERCULES charger modification
                                        by sam_sam_sam
                                        The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                        Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                        05-06-2023, 12:17 PM
