Acer E5-771g Black screen
  • elvirpa800
    • Nov 2019
    • 27
    • Deutschland
    Hello
    I have here A Acer Laptop e5-771g mainboard DA0ZYWMB6E0 REV:E
    Dual Graphic UMA and Gefoorce gt840m
    The problem is when powering it on i can hear he is trying to Boot from DvD Rom and fan is Spinning for 3 seconds then it stopp forever and screen is Black.
    I have tryed to flash bios (All files i Founded on internet) but the problem is Same.
    I found a messure of 4 Ohm on pl7 and pl8 near the nvidia graphic chip and i have remooved the graphich chip but same problem (Black screen)
    Voltage on
    pl6=0V without nvidia gpu chip
    pl7 and pl8=0.43v without GPU chip
    pl9=1.04v
    pl10=1.47v
    pl11=1.32v
    pl12=1.5v
    pl13=2.73v
    pl14=3.32v
    pl15=5.03v
    Has someone a idea how to fix this ,Thanks for any Help
  • elvirpa800
    • Nov 2019
    • 27
    • Deutschland
    Re: Acer E5-771g Black screen
    After soldering new gpu chip the coils became
    pl6=1.32v
    Pl7 and pl8 =0.88v
    but same problem black screen
    • elvirpa800
      • Nov 2019
      • 27
      • Deutschland
      The Bios Chip 25Q64FVSIQ has follow Voltages
      Pin1-3,30V
      PIN2-3,28V
      PIN3-3,30V
      PIN4-GND
      PIN5-0V
      PIN6-0V
      PIN7-3,30V
      PIN8-3,30V
      PIN5 and PIN6 is missing Voltage but i can not find from where
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Do you have dc supply(bench psu)?? If yes measure consumption after pressing power button
        01.With ram
        02.Without ram
        If you dont have a dc supply, check DRAMRST# present or not and if present what's the voltage. If ram used is DDR3, then you can measure it on pin30 of ram slot.
        • elvirpa800
          • Nov 2019
          • 27
          • Deutschland
          Hello sir,
          It consums 270mA same with or without Ram
          DRAMRST# on pin 30 is about 119mV. Bro
          • elvirpa800
            • Nov 2019
            • 27
            • Deutschland
            Im i Right if i Think that this is an PCH Fault?
            • mon2
              • 13829
              Does your schematic reference the same SPI Flash as attached ?
              • elvirpa800
                • Nov 2019
                • 27
                • Deutschland
                Yes bro spi placed on same place (U32) 8mb flash and resistor present and ok on r507 14ohm.
                only difference is that my chip is 25Q64FVSIQ.
                i have tryed all online availible dumps but same problem.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  W25Q64FW is 1.8V bios chip
                  W25Q64FV is 3.3V bios chip
                  So not compatible. Change the bios chip as specified in diagram. You may need a 1.8V adapter to program bios chip.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Too early to jump to any conclusion. DRAMRST# will be pulled low if bios is corrupt(Though there are many many other reasons). Since your bios chip is not as per specs, you wont get dramrst#.
                    • elvirpa800
                      • Nov 2019
                      • 27
                      • Deutschland
                      mine is W25Q64FVSIQ =3.3V and it looks like this chip Set by Factory on this board (No new soldering traces on it) i think your Schematic is from Rev 3A board and mine is Rev E
                      • elvirpa800
                        • Nov 2019
                        • 27
                        • Deutschland
                        i will try to replace the Spi with identic new one may be the bios chip is faulty.
                        • elvirpa800
                          • Nov 2019
                          • 27
                          • Deutschland
                          Same problem with new chip.
                          I think the problem is missing voltage on pin 5 and pin 6 from spi chip
                          • Ariu
                            • Dec 2020
                            • 133
                            Hello, i am facing with same problem, all voltages are present but no display.
                            The Notebook is taking 0,215A when is on.
                            Is it possible to get from you the schematic rev E , and also the bios dumps that you already tried?
                              • 20276
                              Bios requests go here: https://www.badcaps.net/forum/forumdisplay.php?f=40 .Post your backup if you want a clean bios
                              • elvirpa800
                                • Nov 2019
                                • 27
                                • Deutschland
                                Hello i also dont have the rev :E Schematic and for bios i can give you ,pls open new Bios request how SMDFlea explained and i will upload the files there.
                                • Ariu
                                  • Dec 2020
                                  • 133
                                  DRAMRST# is also missing in my fall , i get only 0,1V.
                                  U12 is also ok .
                                  What can be the reason of this low voltage (suspecting 1,5V?), because i can not find any other references...
                                  • Ariu
                                    • Dec 2020
                                    • 133
                                    Ok thank you, please Post the bios dumps on this thread.
                                    https://www.badcaps.net/forum/showthread.php?t=71388
                                    • elvirpa800
                                      • Nov 2019
                                      • 27
                                      • Deutschland
                                      Ariu have you tryed to flash the Super/IO Chip?
                                      no voltage on ec it8587e
                                      pin 105 PCH_SPI_CLK_EC appear 2.75v for 1 second then drop to 0v
                                      pin 101 SPI_CS0#_UR_M 3.30v stable
                                      pin 102 PCH_SPI_SI_EC appear 3.02v for 1 second then drop to 0v
                                      on SPI ENABLE pins
                                      pin 100 S5_ON 3.3v stable
                                      pin 106 ME_WR# 0v
                                      • Ariu
                                        • Dec 2020
                                        • 133
                                        the problem is, that i don't have that programmer .
                                        On the bios chip 3.3V is on all pins present.
