NEED HELP! Battery issue - AA06XL - HP ZBOOK 17 G4
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    AA06XL is based on BQ30Z55 controller with RQ3E180BN mosfet and D6SA sefuse
    Pre-Story: Battery was deep discharged (month attached to zbook with lowest charge) So cell voltage was 3.2V.
    ICP596080C (Capacity: 7860(x2 3930) mah, Nominal: 8420 (x2 4210) mah) cells was disassembled and charged with 500 (the best for discharged cells) mah chargers and placed back.
    But after fully charged, there is 0 voltage on connector. Mosfets are closed and fuse is closed. Fuse bypass didn't solved mosfets opening.
    What could be wrong, except fuse?
  • EdwardGeo
    • Mar 2020
    • 109
    • Ukraine
    Re: NEED HELP! Battery issue - AA06XL - HP ZBOOK 17 G4
    BQ30Z55 reference schematic
    • mon2
      • Dec 2019
      • 14679
      Do you see a voltage on the battery connector after it is charged by your external method?
      Do not connect to the laptop and confirm that there is a voltage on the pre-charged battery.
      • EdwardGeo
        • Mar 2020
        • 109
        • Ukraine
        Thanks for quick response!
        No voltage on battery connector. x6 cells was charged directly. I cannot charge battery through connector, because of dead D6SA. But if i bypass fuse with jumper wire, that make no difference
        Currently trying map traces to figure out connections
        • EdwardGeo
          • Mar 2020
          • 109
          • Ukraine
          After deeper research, results:
          Mosfet which is responsible for output partially opening when battery is connected to laptop.
          Initialization sequence I have:
          When ac connected, 3.3v on smbus arriving for few seconds. The heater in fuse receives 12 volts to burn it again. So controller is stuck at status to disconnect battery source. Maybe controller requires flashing or replacement
          • mon2
            • Dec 2019
            • 14679
            The BMS circuit will be a design that only the vendor will know about. Doubt it that the firmware will be available to the public. For safety reasons, the entire battery pack should be replaced and sourced from a supplier that will take it back if the pack is garbage. Suggest to work with Amazon so that you will have some teeth to be able to return it just in case the pack does not hold up. Repairing battery packs is a serious fire hazard.
            • EdwardGeo
              • Mar 2020
              • 109
              • Ukraine
              The battery has only 6 charge cycles. So that's almost new. Ordered USB-to-SMBus CP2112, will try to restore Sealed status
              Not sure if that board mapping is good enough, as i have not tested all traces, but sharing as JPG.
              Later will report results
              • EdwardGeo
                • Mar 2020
                • 109
                • Ukraine
                SMBUS protocol logic analysis
                With Sealogic
                • EdwardGeo
                  • Mar 2020
                  • 109
                  • Ukraine
                  CP2112 arrived, will try to reset battery
                  also have found some new connections onboard. Also at last gate should be 21V to activate a battery. Fuses will arrive tommorow
                  • EdwardGeo
                    • Mar 2020
                    • 109
                    • Ukraine
                    To disable controller vcc and prevent it from brick ( sealed) only need to desolder 12v
                    • EdwardGeo
                      • Mar 2020
                      • 109
                      • Ukraine
                      SOLVED
                      Okay.
                      I brough donor battery for 15$ with bumped cells. Then dissasemble it, then desolder 12V cell pin to power off battery controller. after it i have to desolder other voltages - 8v, 4v, GND
                      Using hotgun i unsolder BMC and FUSE. I have made same with repearing battery. so FUSE and BMC was replaced.
                      After board got cold, i solder back GND cell wire. then 4v, 8v, and last is 12v which also VCC of BMC.
                      NOTE: all cells was charged to 4.2v to prevent sealing of controller.
                      After 12V was arrived to BMC, the BMS begin to reset itself and alll mosffets become open. after a minute, all voltages at connector arrived.
                      Good news - that is working great. also i have made few full charge-discharge cycles to let BMC recalibrate itself.
                      Bad news - i see 149 cycles, not 5 as before. But it working great!!!
                      • mon2
                        • Dec 2019
                        • 14679
                        Well done!! You have larger gonads than myself to attempt this repair at the battery pack level. Safety would be my biggest concern. Be sure there are no thermal faults with the repaired pack but very interesting that you fixed it. Believe you can alter the charge count over the I2C bus but not sure of the register to alter.
                        • EdwardGeo
                          • Mar 2020
                          • 109
                          • Ukraine
                          Thanks for your help!
                          Also i have found a really cheap way of unsealing of battery (i mean this is good for only reasons when it was discharged accidentally, do not recommend to do it if it was a safety protection scenario). So method: using LPT adapter with 74LS05, read and patch registers with UBRT software. It costs for 10$ for a day usage and free demo to learn it. 10$ its enough for one battery recovery. But in my case or my lpt port was faulty or I have made wrong adapter. But have no conformation that LPT port at least is working.
                          • mon2
                            • Dec 2019
                            • 14679
                            We manufacture LPT ports.
                            What do you need ? For PCI? PCIe?
                            Forget the usb lpt dongles, they suck.
                            • EdwardGeo
                              • Mar 2020
                              • 109
                              • Ukraine
                              I do have a motherboard with lpt port.
                              • mielta
                                • Apr 2015
                                • 368
                                Hi
                                Look here I think this is also a very good alternative
                                https://www.youtube.com/channel/UCbn...Wj3aTF5KkU5nOg
                                • EdwardGeo
                                  • Mar 2020
                                  • 109
                                  • Ukraine
                                  Originally posted by mielta
                                  Hi
                                  Thanks for info! That's a great program supposed to be!
                                  The software is actually is installing pl2303 (usb to RS232 device), actually could be used with additional RS232 to smbus converter!
                                  It would be a good option if they would make a cheap 10-15$ controller and software with One day license option. But as we all know, the cheap way is to buy a new battery instead of buying 200-500$ stuff
                                  Actually, battery after BMC replacement is working fine so far. A few days using it and really happy)
                                  • SeSeBe
                                    • Apr 2020
                                    • 4
                                    • Romania
                                    There are another solution but no soo cheap: ********************
                                    • code share
                                      Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                      by code share
                                      I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                      Here's what I've tried so far:
                                      • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                      • Booted successfully on AC power only with the battery disconnected
                                      • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                      • Battery
                                      04-21-2025, 12:50 PM
                                    • huzo
                                      HP ELITE X2 1013 G3 weird battery issue
                                      by huzo
                                      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                      01-31-2025, 12:09 AM
                                    • danielsak
                                      Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                      by danielsak
                                      Hello, I have issue with Dell Inspiron 3542.
                                      Motherboard marking:
                                      Code:
                                      PWB FX3MC REV: A00
                                      The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                      1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                      1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                      10-11-2024, 04:36 PM
                                    • Simone Vergani
                                      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                      by Simone Vergani
                                      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                      To assist with troubleshooting, I'm attaching two power circuit schematics:
                                      • Power
                                      03-05-2025, 02:25 PM
                                    • ahmarzo
                                      Acer laptop battery draining issue
                                      by ahmarzo
                                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                      08-02-2025, 06:39 AM
