Dell E7440 no signs of life
  • massaaris
    • Aug 2020
    • 12
    • Europe
    I've got some dell motherboard (LA-9591P) in an incomplete case, missing most of the components, keyboard, trackpad, screen, battery, etc. Looking for an opinion from someone more experienced with this model and maybe some common issues. CMOS battery was dead so I replaced it. Also, added one stick of PC3L Ram.
    When I plug in the charger (original dell) there are no signs of life, no LEDs, power button does nothing. Charger connector has blue light on it. Measured 19.5V on input and also on some other places on the board. Measured some random chips looking in the schematics and found 5V, 3.3V at the correct pins. Tested all the capacitors (I think) for shorts and found none.
    Please note that I have no experience with board level repair, but I would like to learn basics. Could replace some resistor, capacitor or a fuse, and that's about it (for now )
    For starters, I would like to know if this motherboard could be tested outside of the case, connected to HDMI monitor? What is the minimum stuff to connect for it to work?
    What would be the first steps to measure trying to find why there is no power light?
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Dell E7440 no signs of life
    Yes you can you need , ram ,cmos battery and powerbutton with lidswitch to test it out the case.
    • massaaris
      • Aug 2020
      • 12
      • Europe
      Thank you, I should have everything you mentioned. Power button is soldered on to the board. My main concern is that there is no light on the board when I plug the charger in. LEDs are good, I tested them with multimeter.
      I might have picked very complex board to start with. Case has some liquid damage traces, but there are no evidence on the board as far as I can see. Maybe someone already cleaned it.
      • massaaris
        • Aug 2020
        • 12
        • Europe
        I have tried to diagnose this problem but with no success. What is strange to me is that both bios chips (64Mb and 32Mb) have 3.3V on all pins except ground pin when charger is plugged in. There is no short between pins, I read between 1k and 14K resistance. Maybe someone with more experience can tell is this normal behavior?
        • mon2
          • Dec 2019
          • 14332
          Start with the charger section. Often the first 2 mosfets are the fault but remove all power.
          No battery.
          Meter in resistance mode (2k scale is ok).
          Measure and post the resistance readings for:
          source (1-2-3) & drain (5-6-7-8)
          source (1-2-3) & gate (4)
          gate(4) & drain (5-6-7-8)
          Checking for any low resistance values which will indicate that the mosfet is defective and will need to be replaced.
          If the resistance readings are ok then consider to use your meter in voltage mode (20v scale is ok).
          Apply your external adapter only.
          Carefully measure & post the readings on the charger IC @ PU700 (BQ24715RGRR_QFN). This is a popular charger IC so documents can be reviewed on how and when it works with respect to the external mosfets.
          • massaaris
            • Aug 2020
            • 12
            • Europe
            Here are some measurements:
            Input jack across + and - : 71 kOhm
            PQ700
            G to S : 4.5 MOhm
            G to D: 5 MOhm
            S to D: 40 kOhm and rising
            Voltages: G 0 V, S 19.5 V, D 19.5 V
            Similar resistance measured for PQ4, PQ704, PQ706
            PL500 0 V
            PJPDC1 13.5 V
            PJP1 19.5 V
            PL4 19.5 V
            Cap below PL4 19.5 V and 9.2 V
            PQ4 G 9.2 V, S 19.5 V, D 19.5 V
            PL700 19.5 V
            PR700 19.5 V
            PL701 13.5 V
            PR716 13.5 V
            PL100 13.5 V
            PL101 3.3 V
            PC113 3.3 V
            PL102 5 V
            PC115 5 V
            PL200 0 V
            PC207 0V
            PQ704 G 13.7 V, S 13.5 V, D 19.5V
            PQ706 G 0 V, S 0 V, D 13.5 V
            PU700:
            01. ACN 19.5 V
            02. ACP 19.5 V
            03. CMSRC 19.5 V
            04. ACDRV 25.2 V
            05. ACOK 3.25 V
            06. ACDET 3.12 V
            07. IOUT 0 V
            08. SDA 3.3 V
            09. SCL 0.18 V
            10. CELL 5.6 V
            11. BATDRV 13.5 V
            12. SRN 13.5 V
            13. SRP 13.5 V
            14. GND 0 V
            15. LODRV 0 V
            16. REGN 6 V
            17. BTST 19.5 V
            18. HIDRV 13.5 V
            19. PHASE 13.5 V
            20. VCC 19.25 V
            DC input connected, no battery, one stick of RAM, no additional cards, flat cables anything.
            • mon2
              • Dec 2019
              • 14332
              08. SDA 3.3 V
              09. SCL 0.18 V
              Confirm the voltage of the SCL pin. It is low and appears to be stuck low.
              Then, remove all power. No battery.
              Meter in resistance mode (2k scale).
              Measure the resistance to ground of the SDA pin.
              Them repeat the measurement for the SCL pin.
              Post your values.
              • massaaris
                • Aug 2020
                • 12
                • Europe
                SDA resistance to GND 10.6 kOhm
                SCL resistance to GND 180 Ohm
                SDA 3.23 V
                SCL 180 mV
                • mon2
                  • Dec 2019
                  • 14332
                  Code:
                  This line is being pulled down and causing problems.
                  Locate the ESD tvs diodes that are often on these lines near the battery. When found, remove this part.
                  Then check the resistance again. If no longer a low reading, power up and test again.
                  Post the voltage on the SCL line without the tvs ESD dual diode on this line.
                  • massaaris
                    • Aug 2020
                    • 12
                    • Europe
                    I'm not really sure where to look at. There is a diode "S510 M44" near PU700, or maybe something else?
                    Here are some pictures of the board from both sides.
                    • mon2
                      • Dec 2019
                      • 14332
                      Look for a 3 pin part with label PD1. If not silk screened on the logic board, show some pics near the battery connector. It should be close by.
                      See attached.
                      Update - I think I found the location - see the area of the battery.
                      • massaaris
                        • Aug 2020
                        • 12
                        • Europe
                        @mon2 I forgot to say, Thank you for all the effort
                        I found PD1 and removed it, but unfortunately no change, measurements are the same.
                        • mon2
                          • Dec 2019
                          • 14332
                          My bad...this logic board has multiple I2C (SMBUS) masters.
                          The charger bus master, CLK pin is at fault.
                          This could be:
                          1) due to a faulty KBC port pin that is responsible to drive the SCLK signal
                          or
                          2) the required pull-up resistor for the SCL line is missing (RP19) or corroded(?)
                          See attached. Inspect the resistor network @ RP19 which will be a 8 legged part (4 on each side). Does it look clean to you ?
                          If in doubt, apply flux and allow this part to 'dance' with the hot air so that the solder joints settle once again. Be careful to use low air pressure so that the part or neighbors do not go flying in the process.
                          • massaaris
                            • Aug 2020
                            • 12
                            • Europe
                            I think RP19 looks normal. I measured resistance between leg pairs and all are 10 kOhm, except third pair with 490 Ohm, not sure if that's relevant.
                            This is the part of the board where I found signs of flux (on two big chips), but it's cleaned now.
                            I don't have hot air station
                            • mon2
                              • Dec 2019
                              • 14332
                              I think a hot air tool is mandatory for such repairs. The large chip may have corrosion underneath that is not visible. For such cases, apply flux on top and around the pins of this part and hot air away till the part starts to swim into the solder. Use tweezers to gently nudge it - make it 'dance' so that the joints settle again.
                              If that does not work then likely this large IC is defective - not sure if it is a programmable device. If it is, then the part needs to be programmed with the proper firmware. Check on the internet or wait on some feedback from others on this KBC.
                              • massaaris
                                • Aug 2020
                                • 12
                                • Europe
                                I know it's basically mandatory, but I still don't have it or the skills to do such precision work (for now). My idea was to try, maybe if it was something simple, and also to learn some basics.
                                I measured yellow pin you marked on the RP19 and it has the same voltage as SCL 180 mV. Other pins have 3.3V. I suppose it comes from the chip, so it's probably defective or something.
                                Thank you a lot for the help!
                                If anyone else has any suggestions I'm ready to try it. If not, this could be a good practicing board for the future
                                • mon2
                                  • Dec 2019
                                  • 14332
                                  Confirm that the LEFT side of the RP19 pads are each @ +3v3.
                                  See attached.
                                  If yes, then it is all down to the large IC and its soldering.
                                  You can try to measure the DIODE MODE readings as follows:
                                  Meter in DIODE mode setting.
                                  Red meter (yes RED) probe to GROUND (shield is ok).
                                  Black meter probe to the SCL line on the RP19 that is showing the low voltage.
                                  What is the reading ?
                                  Then repeat for the SDA line on the RP19.
                                  As noted, you have a low resistance to ground on the SCL line and this is preventing the I2C (SMBUS) master (the large IC) from communicating with the other devices using this 2-wire communication interface.
                                  RP19 plays an important role and it must be pulled up to the ~3v3 value but we cannot see what is under the large IC so a reflow is recommended. If that fails to work, then the large IC must be replaced. At this time, I am not sure if this large IC is a programmable device or not. Sometimes such parts feature a small microcontroller (like 8051) inside the device and then will fetch firmware upon power up from a flash device. The flash device may be external to the KBC controller or could be internal - again, if at all programmable.
                                  • massaaris
                                    • Aug 2020
                                    • 12
                                    • Europe
                                    Yes, all yellow marked pins are 3.3V
                                    Diode mode on SCL 0.13V (same on the RP19 pin)
                                    Diode mode on SDA 0.5V
                                    • mon2
                                      • Dec 2019
                                      • 14332
                                      So to summarize,
                                      1) the issue is most likely linked to the large KBC controller
                                      2) with a hot air tool & flux, you can reflow this device to see if the low resistance value changes to allow for the SCL line to toggle as it should and settle @ 3v3 when not active
                                      3) with a hot air tool & flux, you can replace this part, if deemed to be defective. However, see attached - the part is a programmable device and does require firmware to function. You can program it yourself if you have the rather expensive programmer or purchase from a reliable vendor (perhaps Ebay) that can sell this part pre-programmed.
                                      The hot air tool is about $200 USD on Aliexpress - we use and recommend the BEST-863 but there are other devices on the market in this price range.
                                      • massaaris
                                        • Aug 2020
                                        • 12
                                        • Europe
                                        Thanks again. I will save this board to mess with later when I have the proper tool. It's an old board, not worth much, so ideal for practicing.
                                        I looked up some hot air stations a while ago, think I stumbled upon this model from Best. Also considered Atten ST-862D which I can get locally for a similar price.
                                          DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                          09-06-2024, 04:40 PM
                                          09-06-2024, 04:10 PM
                                        • someonenotyou
                                          Dell Vostro 3501 - no signs of life after BIOS read
                                          by someonenotyou
                                          Hi.
                                          I have a laptop Dell Vostro 3501 which did not POST. When connected to power supply and turn it on, the keyboard backlight would turn on but nothing else. Sometimes there was 1 BEEP code indicating problems with BIOS.
                                          Then I disassembled it to read the BIOS chips. It had 2 - 64mbit and 128mbit. I connected CH341A (with 3.3v mod) to both of the chips (still soldered on main board) and read them.
                                          After I reassembled laptop back and tried to turn it on. Now there is no sign of life. Not even keyboard backlight.
                                          Then I took the motherboard out...
                                          01-27-2025, 05:15 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
