820-2850-A: battery not detected
  • DrFalken
    • May 2008
    • 122
    #41
    Re: 820-2850-A: battery not detected
    Originally posted by mon2
    Replace U7000. These pins should not be 0V and pretty sure these pins are from an internal LDO that feeds from pin 2 as the input voltage.
    If U7000 has been replaced or was faced with possible liquid damage, consider to flux and reflow the part to test again. Fairly inexpensive part from Aliexpress or other sources.
    I'm replacing it again, maybe is defective or not perfectly soldered.
    Will report very soon
    • DrFalken
      • May 2008
      • 122
      #42
      U7000 replaced, F7040 still removed
      AC Adapter only (no battery) readings:
      F7040 pad #1 = 12.54V dropping to almost 4V in 4-5 seconds then rising istantly to 12.54V and dropping again to 4V... (cycle)
      F7040 pad #2 = 0.5V
      • DrFalken
        • May 2008
        • 122
        #43
        Put back F7040:
        F7040 pad #2 = 12.54V
        Solid green on the AC adapter and the fans started on their own
        Laptop is booting now ! Thank you @mon2 !!!
        Monday will check if the battery charging works and report back.
        • DrFalken
          • May 2008
          • 122
          #44
          Last minute update: the battery isn't yet detected.
          What can I check monday ?
          • mon2
            • Dec 2019
            • 14095
            Excellent on the update.
            Do you see the battery charging symbol once you boot up normally ?
            Does the battery have enough charge to operate the logic board (without the power adapter) ? Respectively, can this unit operate without the adapter (battery only) ?
            If the battery is not detected, need to check on the I2C bus used to communicate with the battery pack. This is where D6950 is involved again.
            With the adapter & battery connected - post the voltages on Q7055.
            Post all voltages on the battery connector.
            • DrFalken
              • May 2008
              • 122
              #46
              When I turn on with both battery and AC adapter there is an X on battery icon and isn't detected even on System information (see attached pic).
              Magsafe led is solid green, never turn orange.
              I think that the battery is empty, anyway I've tried battery only and laptop doesn't turn on (SIL blinking 5 times pressing check button).
              Removed motherboard from chassis and connected battery only:
              Q7055 pin #1-3 = 10.92V
              Q7055 pin #4 = 3.96V
              Q7055 pin #5 = 10.92V
              Added AC adapter:
              Q7055 pin #1-3 = 11.19V
              Q7055 pin #4 = 4.69V
              Q7055 pin #5 = 12.18V-12.20V
              Suddenly, when I've plugged in AC adapter to measure voltages, the logic board turned on, fans spin at maximum speed and Magsafe led turned solid orange
              After 2-3 minutes the Magsafe led turned solid green again and the fans are still at maximum speed.
              J6950 readings in this moment (AC+battery, fans @max speed):
              pin 1-2-3: 11.19V
              pin 4: 3.38V
              pin 5: 0
              pin 6: 3.39V
              pin 7-8-9: 0
              Removing AC adapter the battery keeps powering the logic board (fan still @max speed): I suppose the battery charged a little bit.
              Will put logic board back on chassis and report.
              • mon2
                • Dec 2019
                • 14095
                Flux and carefully remove D6950 off the logic board. It is a very tiny part.
                Test again.
                • DrFalken
                  • May 2008
                  • 122
                  #48
                  Test again.
                  I've just put everything back, same issue (Magsafe led solid green, battery not detected)
                  Turned off.
                  Lifted battery keeping connected the battery cable to motherboard, plugged Magsafe and his led turned orange.
                  Turned on Macbook, now there's a little flash symbol over the battery icon: booting MacOS the battery is detected and now charged @ 8% (see attached pic)
                  I'm suspecting some bad connections between battery cable and J6950...
                  (charge is 14% in this moment)
                  • mon2
                    • Dec 2019
                    • 14095
                    Very good. Do the pram reset to reset the parameters.
                    • DrFalken
                      • May 2008
                      • 122
                      #50
                      Done but has the same behaviour.
                      When I put back the battery doesn't get recognized.
                      When lifted get detected and charged.
                      99% confident it's a connector (battery or logic board side ?) problem.
                      I'll further investigate starting from J6950's pins 4-5-6.
                      • DrFalken
                        • May 2008
                        • 122
                        #51
                        Double checked J6950's pins 4-5-6 and also resoldered, same issue.
                        Currently the battery has a 100% charge.
                        The battery is detected and charged only when is lifted and the Macbook is able to turn on without AC adapter (battery only)
                        Conversely, when the battery is mounted in its seat Macbook turn on only with AC adapter (after is turned on I can unplug Magsafe and keeps working only with battery but doesn't detect it)
                        Could be battery issue ? (cable or plug)
                        Don't have another battery to check...
                        • mon2
                          • Dec 2019
                          • 14095
                          Sounds like a contact / connector fault with the:
                          pin 4: 3.38V
                          pin 5: 0
                          pin 6: 3.39V
                          Since the battery is able to power the logic board when the magsafe is unplugged, the battery detection pins are the only factor. Review the above 3 pins.
                          • DrFalken
                            • May 2008
                            • 122
                            #53
                            I've checked them on motherboard side, both under microscope and continuity mode
                            - J6950 pin#4 - R5281 pin#2
                            - J6950 pin#5 - R6980 pin#1
                            - J6950 pin#6 - R5280 pin#2
                            and are ok.
                            Also:
                            - J6950 pin#5 (SYS_DETECT_L) to GND = 9.86 KiloOhm
                            On the battery side (battery not connected to motherboard) voltages are:
                            - pin #4 - pin #9 (GND) = 0
                            - pin #5 - pin #9 (GND) = 0
                            - pin #6 - pin #9 (GND) = 0
                            • DrFalken
                              • May 2008
                              • 122
                              #54
                              Last update: I've ordered a brand new battery, yesterday arrived and it's correctly detected without any issues.
                              Now it's fully charged.
                              Looks like the previous one was faulty or damaged.
                              Again, thank you @mon2 for everything !!!
                              • spacez
                                XPS 15 9520 - tpm device is not detected - NO ssd detected
                                by spacez
                                I have an XPS 15 9520 with a damaged bios so I flashed another one from badcaps. in manufacturing mode I changed the service tag but unfortunately ssd is not detected and also the error -tpm device is not detected- please help me. I haven't changed the tpm chip yet. Thanks in advance
                                Service Tag: J2MSHW3
                                |Express Service Code: 41518077843
                                mother board LA-L402P REV 1.0(A00)​...
                                08-18-2024, 10:54 PM
                              • Nikan.e
                                Inno 3d RTX2070 not detected - no I²C connection
                                by Nikan.e
                                Greetings and Salutations!
                                I have encountered a faulty GPU — an Inno3D RTX 2070 Twin. There was a shorted MOSFET on the Vcore rail.
                                The faulty DrMOS was removed, and the burned PCB area was milled away.
                                All voltages are now good, but the GPU is not being detected.
                                I found that the CS pin of the BIOS (GPU) is not being pulled low, and thus, the GPU isn't detected.
                                I wanted to measure the SM_Data and SM_Clock, but to my surprise, there is no connection at all.
                                I thought these pins were used for communication during startup?!?
                                On all...
                                03-30-2025, 07:21 AM
                              • superdota2
                                HP 15s-FQ2552TU nvme drive not detected
                                by superdota2
                                HP 15s-FQ2552TU
                                da0p5hmb8f1 rev f
                                sn# 5CD138CCH4
                                problem is power on but no display,no bios post
                                i search bios here ,i found and it work and got display.
                                https://www.badcaps.net/forum/showthread.php?t=104925
                                second problem is nvme drive not detected in bios intel rapid storage,
                                i tried a working nvme drive but still not detected in bios,
                                also tried install system and install intel rapid driver,still not detected....
                                06-21-2023, 09:36 PM
                              • Scotchmist
                                Lenovo thinkpad 15 itl g2 - No Hdd detected
                                by Scotchmist
                                Hi
                                I got this laptop with bad onboard ram so edited the bios with SPD removal tool to disable the onboard ram and work with the ram slot - the laptop now posted so i thought all was good however when i put everything back together it will not boot to windows as no boot device found., In the bios is says hdd not detected, i disabled VMD in the bios but still the same, loaded windows on usb stick and windows install cannot find the hdd. I bought a second board that had water spill, repaired the damaged area and it posted ok but same issue no hdd detected.
                                I have now tried...
                                09-11-2024, 05:06 AM
                              • titomno2
                                Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                                by titomno2
                                Hi guys,
                                On motherboard ACER AN515-52 type LAF951P.
                                I fixed issue with not starting computer (it was the PQ201 component not working properly).
                                But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                                Basically some HDD spin but are not detected by the bios.
                                Already tried following:
                                checked the 4 data lines
                                #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                                #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                                07-28-2024, 08:30 AM
