A1708 820-00840-A 5V 80-100mA
  • mon2
    • Dec 2019
    • 14684
    Re: A1708 820-00840-A 5V 80-100mA
    With the battery no PP3V3_G3H.
    This is because F7000 is removed. The dual diode @ D6905 takes the input from F7000, pad # 2 (right side in the schematic), to power the LDO regulator which creates the 3v42 rail = PP3V3_G3H.
    Solder back the fuse @ F7000. Then confirm that PP3V3_G3H is back with the battery (only).
    Next,
    Measure and post all voltages on mosfet Q7065 with only the battery connected.
    1) Source (1-2-3)
    2) gate (4)
    3) drain (5-6-7-8)
    • Aitorflores7
      • May 2020
      • 30
      • España
      #42
      PP3V3_G3H is now present and stable. This are the voltages in Q7065:
      1) Source (1-2-3) :10,23V
      2) gate (4): 2,34V
      3) drain (5-6-7-8):10,23V
      Do i have to solder back D6950 and chech?
      • mon2
        • Dec 2019
        • 14684
        This rail is not pulsing ?
        Check the other rails that were pulsing ? Are they also stable ?
        Do i have to solder back D6950 and check?
        If the rails are stable then yes, apply D6950 back onto the board. If I followed this thread properly, the removal of D6950 caused the rails to stabilize. In this case, D6950 is defective and needs to be replaced. If you solder back the defective ESD diode then the SMBUS communication will halt and cause the observed issues. This is becoming a common fault but do confirm my understanding. This ESD device is a common part available from Arrow and other online stores.
        • Aitorflores7
          • May 2020
          • 30
          • España
          #44
          It´s working!! I solder back D6950 and connect to the battery. It turns on normally! The only problem i have now are the two CD3215. If i connect the adapter, the amp meter cycles. When the two cd3215 arrive, I will comment on how it went. Maybe bad solder on D6950?? Thank you very much mon2!! You help me a lot!! Now i have another board like this one. I open another thread. If you want you can help me too AGAIN, THANK YOU!!
            Acer Aspire A517-52G-50MA + Extended Service Plans Notebook 5 Specification for Upgrade or Repair
            This specification for the Acer Aspire A517-52G-50MA + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA + Extended Service Plans boardview and A517-52G-50MA + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
            09-07-2024, 02:20 AM
            Acer Aspire A517-52G-50MA Notebook 5 Specification for Upgrade or Repair
            This specification for the Acer Aspire A517-52G-50MA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA boardview and A517-52G-50MA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 11:20 PM
            09-06-2024, 09:10 PM
          • obelix24
            Macbook A1708 - 820-00840 20v 50ma
            by obelix24
            Hi All I've one MacBook A1708 that is taking 20v 0.05a
            I've checked and there is short to ground on PPBUS_G3H but I'm not able to locate it.
            I've injected voltage on F7000 (1V 3A) but it was taking only 0,2a.
            I've checked also C6465 but it's ok (I've take it from board and test with multimeter) - also when it was removed short was still there.
            Can you please help me what is causing the short ?
            09-05-2023, 03:39 AM
