A1708 820-00840-A 5V 80-100mA
Re: A1708 820-00840-A 5V 80-100mA
Post the resistance to ground readings for the attached D6950 device.
Remove all power. Meter in resistance mode (2k scale).
Red meter probe on point to test; Black to ground (shield is ok).
Also, with all power removed, meter in DIODE mode.
Check & post the measurements for each CC1/CC2 line. Red meter probe to GROUND; Black meter probe to point to test in DIODE mode.Last edited by mon2; 01-29-2022, 12:33 PM.Comment
Ok! When the new cd3215 arrive i will post again adding some information. Thanks for your help
Im going to open a new thread about another board like this one. I hope you can help me too!Comment
This are the measuresment:Post the resistance to ground readings for the attached D6950 device.
D6950 in resistance mode: Pin1: 3,3Mohm / Pin2: 878Kohm / Pin3: 2,6Mohm
D6950 in diode mode: Pin1: 0,440V / Pin2: 0,555V / Pin3: 0,552V
U3200 diode mode: CC1: 0,599V / CC2:0,604V
U3100 diode mode: CC1: 0,604V / CC2:0,614V
Thank you for helping me too!Comment
Can you check your measurements again ?
Remove all power. Meter in 2k scale.
Red meter probe to pin to test; Black meter probe to GROUND.D6950 in resistance mode: Pin1: 3,3Mohm / Pin2: 878Kohm / Pin3: 2,6Mohm
If done properly, Pin # 3 should have been 0 ohms.
Then place meter in DIODE mode.
RED METER probe to GROUND (yes Ground); Black meter probe to pin to test.
If done properly, pin # 3 should be 0V.Comment
Sorry mon2! My fault! i measured D6905...
D6950 in resistance mode: Pin1: 102Kohm / Pin2: 120Kohm / Pin3: 0,3ohm
D6950 in diode mode: Pin1: 0,430V / Pin2: 0,430V / Pin3: 0,009VComment
Ok. So D6905 is not at fault.
You mentioned that PPBUS_G3H is not working - is this still correct ?
If yes, remove F7000 fuse (for now). Test again.
Do you see PPBUS_G3H working from the ISL side of the design ?
Respectively, remove all power - meter in 2k scale mode - check the resistance to ground on both, pad #1 on F7000 and then again for pad #2 on F7000.
The ISL is a buck / boost regulator and it should be working before we can move forward. The 20V is a separate issue.Last edited by mon2; 01-29-2022, 01:52 PM.Comment
Yes, PPBUS_G3H is not working. I removed the fuse and still nothing. Resistance to ground in Pin1: 2,5 Mohm and in Pin2: 940KohmComment
Post the voltage (with adapter) for:
TBA_AUX_DET
TBA_CSIR_P
TBA_CSIR_N
These are tiny parts so proceed with care.
C7025 (can be any point on the capacitor cluster)
Are these voltages stable or also pulsing ?
Next, remove all power -> meter in resistance mode again (2k scale).
Post the resistance to ground for C7025 capacitor cluster.Comment
TBA_AUX_DET: 1,3V pulsing
TBA_CSIR_P: 5,2V pulsing
TBA_CSIR_N: 5,2V pulsing
C7025: 5,2V pulsing / 3MohmComment
Voltage reading for SMC_RESET_L?
Remove the battery. Using only the power adapter, post the voltages of the power rails for each CD3215.
U3100 and U3200
Pin 2 PP1V8_UPC_XB_LDOD
Pin 10 PPDCIN_G3H
Pin 11 PP5V_S4
Pin 12 PP3V3_UPC_XB_LDO
Pin 35 PP1V1_UPC_XB_LDO_BMC
Pin 70 PP20V_USBC_XB_VBUS
Pin 75 PP1V8_UPC_XB_LDOALast edited by mon2; 01-29-2022, 10:25 PM.Comment
SMC_RESET_L: 3,4V pulsing
I connect the power adapter to the farthest usb-c port from trackpad
U3200:
Pin 2 PP1V8_UPC_XB_LDOD: 1,79V pulsing
Pin 10 PPDCIN_G3H: 5,2V pulsing
Pin 11 PP5V_S4: 0V
Pin 12 PP3V3_UPC_XB_LDO: 3,37V pulsing
Pin 35 PP1V1_UPC_XB_LDO_BMC: 1,1V pulsing
Pin 70 PP20V_USBC_XB_VBUS: 5,2V pulsing
Pin 75 PP1V8_UPC_XB_LDOA: 1,79V pulsing
U3100:
Pin 2 PP1V8_UPC_XB_LDOD: 1,785V pulsing
Pin 11 PP5V_S4: 0V
Pin 35 PP1V1_UPC_XB_LDO_BMC: 0V
Pin 70 PP20V_USBC_XB_VBUS: 0V
Now, I connect the power adapter to the closest usb-c port from trackpad
U3200:
Pin 11 PP5V_S4: 0V
Pin 35 PP1V1_UPC_XB_LDO_BMC: 1V pulsing
Pin 75 PP1V8_UPC_XB_LDOA: 1,8V pulsing
U3100:
Pin 11 PP5V_S4: 0V
Pin 75 PP1V8_UPC_XB_LDOA: 1,79V pulsingComment
When i reconnect the battery in pin 1 of the of F7000 i have 10,1V (i don´t have the fuse solder in place), thats the voltage of the battery, am i right? so ppbus_g3h is created.Last edited by Aitorflores7; 01-30-2022, 08:27 AM.Comment
See attached.
When you connect the battery - the battery mosfet @ Q7065 is enabled and allows for the flowing of measured voltage onto pad # 1 of F7000.
When you mate the battery - post the voltage on pin # 4 of Q7065 mosfet.
It does seem to indicate that the ISL is supplying the charge voltage to ENABLE this mosfet (unless the mosfet is shorted and is just allowing this to pass through).
After this test, remove all power / no battery.
Meter in resistance mode (2k scale) -> measure & post:
resistance between
source & drain
source (1-2-3) & gate (4)
gate(4) & drain (5-6-7-8)
for Q7065.
Post the voltage @ PP3V3_G3H.
Still interested to hear about your testing after D6950 is removed.Comment
i removed D6950. Still no PPBUS_G3H.
I reconnect the battery and in Pin 4 of Q7065 mosfet i have 9,6V.
Resistance measuresment:
source & drain: Open Line
source (1-2-3) & gate (4): 10,53Mohm
gate(4) & drain (5-6-7-8): 6,12Mohm
PP3V3_G3H voltage with only battery connected is 0V. With only the adapter is 3,4VComment
Yes, the fuse F700 is removed.
Yes, with adapter only all rails are pulsing. When the amp meter cycle, the rails go down and the back up again. With the battery no PP3V3_G3H.Comment
This specification for the Acer Aspire A517-52G-50MA + Extended Service Plans Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA + Extended Service Plans boardview and A517-52G-50MA + Extended Service Plans schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-07-2024, 02:20 AM
This specification for the Acer Aspire A517-52G-50MA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA boardview and A517-52G-50MA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:20 PM
This specification for the Acer Aspire A517-52G-50MA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A517-52G-50MA boardview and A517-52G-50MA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 09:10 PM
by obelix24Hi All I've one MacBook A1708 that is taking 20v 0.05a
I've checked and there is short to ground on PPBUS_G3H but I'm not able to locate it.
I've injected voltage on F7000 (1V 3A) but it was taking only 0,2a.
I've checked also C6465 but it's ok (I've take it from board and test with multimeter) - also when it was removed short was still there.
Can you please help me what is causing the short ? - Loading...
