Dell Latitude E7440 FAN issue
  • Shummi
    • May 2021
    • 16
    • Danmark
    Hi
    My own laptop Dell Latitude E7440 have a FAN issue, but i can't figure out what it is, so I am hopeing for a little assistance. I have only repaired one PC so far.....
    Suddently the PC shut down, it was due to overheating, as the FAN didnt' run.
    What i have tried
    1. replaced the FAN, no change.
    2. Removed the back-up, reset BIOS, no change
    3. Measured the 5V for FAN, always there.
    Sporadically the FAN runs when I force power down, so I suspect some kind of SW issue. but I have no idear where to look.
    Any help apriciated.
  • Adenitz
    • Jan 2021
    • 122
    • Congo
    Re: Dell Latitude E7440 FAN issue
    Hello Shummi,
    FAN is controlled by SIO chip. On its connector you have GND and +5VDC and there are two more signals:
    FAN1_PWM - control voltage produced by the SIO and the speed of the FAN is directly proportional to this voltage
    FAN1_TACH - this voltage is feedback information about the actual speed of the fan.
    Did you try with another fan? It is possible that its feedback information is faulty and therefore control signal is not generated.
    It could also be possible that something is wrong with the SIO chip and that is much harder to replace.
    • Shummi
      • May 2021
      • 16
      • Danmark
      Hi Adenitz
      Thanks for you reply.
      These signals are not DC, when the FAN spins theres pulses on both, when it dosn't work
      PWM is stady LOW
      TACH is stady high
      They are comming directly from SIO, but is there another reasons for not starting the FAN?
      I think normally the FAN always run at power up, but on this laptop it dosn't
      • Adenitz
        • Jan 2021
        • 122
        • Congo
        Originally posted by Shummi
        Hi Adenitz
        PWM is stady LOW
        TACH is stady high
        Hello Shummi,
        these signals are DC even though not constant. PWM is Pulse Width Modulation. It represents series of pulses typical frequency of about 10 kHz, so the multimeter should measure some average DC voltage. If I'm not mistaken, the pulses go from 0V to 3.3 V.
        Just for test, you can try to connect 3V to the FAN_PWM input to test if the fan works and produces feedback voltage on TACH.
        The fan should start spinning immediately after laptop is turned ON on DELL 7440.
        I had an issue with one HP laptop, the bearing of the FAN was bad and sometimes FAN wouldn't start, I had to provide a little help to start to spin.
        So the solution was to replace the fan. It was that simple.
        You need to rule out the possibility that the fan is faulty first.
        • Shummi
          • May 2021
          • 16
          • Danmark
          hi Adenitz
          Thanks for quick reply
          I It is a brand new FAN, and I have also testede it.
          I have cut PWM signal, then the FAN runs at full speed.
          In case it was the pull up resistor, I have supplied 3.3V throug a 10K resistor to PWM Pin, and it is still LOW, so it IS SIO that pulls it down.
          The funny this is, that sometimes the FAN run when I power down.
          • mon2
            • 14679
            Run the diagnostics to confirm that the thermal sensors are working.
            https://www.dell.com/support/kbdoc/e...e-on-a-dell-pc
            • Adenitz
              • Jan 2021
              • 122
              • Congo
              So this control voltage is generated by the SIO. The question is why, is it something wrong with the SIO, or some thermal sensors are out of the range or have intermittent problem, so SIO controls the fan in such way.
              Sorin has recently struggled with similar issue:
              https://www.youtube.com/watch?v=3Zube6vE5FQ
              • Shummi
                • May 2021
                • 16
                • Danmark
                update: It is not a FAN issue.
                The FAN dosn't start at power-on, only when it gets hot.
                The problem was intermittent power off.
                I have completely disassambled the laptop, and run severalt test, but i coudn't get it to turn off, I suspect the LCD connector, as the diaplay flickered sometime.
                Hopefully it will work now, it is currently testing.....
                If you hold Fn at pwr up, it goes into testmode in bios (ePSA)
                • Adenitz
                  • Jan 2021
                  • 122
                  • Congo
                  Can you please make this more clear? What is intermittent power off and what you cannot turn off?
                  • Shummi
                    • May 2021
                    • 16
                    • Danmark
                    Hi Adenitz
                    What I ment was , the laptop Power-off peridically by it self.
                    And it still does. Sometime I can use it for a day without problems, then suddenty it is dead, but I can start it again right a way. It is very strange.
                    I have talked with Dell support, but they just told me to buy a new mainboard.
                    I am lost, I dont know any tools than can get me closer to the issue, I dont get anything from the Windows log other than "it shut down unexpectedly".
                    • Adenitz
                      • Jan 2021
                      • 122
                      • Congo
                      Well, If I were you, I would use +3.3V_RUN and connect it to the FAN jut to test.
                      Your FAN has 4 wire (RED 5V, Black GND, Yellow is feedback voltage - RPM, and Blue is control PWM signal).
                      I would cut red wire from and connect it to +3.3V_RUN to test if the fan is spinning. This 3.3V should go to FAN only and not on the motherboard.
                      Something like Sorin did here:
                      https://www.youtube.com/watch?v=ocTOD0vBFgc
                      If that doesn't work, try to connect it to blue wire also, but only to FAN and be careful no to touch pad on the motherboard. I would cut wires and left connector in the slot intact. This new voltage 3.3V should come only to the FAN.
                      I don't think you have anything to lose.
                      • reformatt
                        • Feb 2020
                        • 1521
                        Most modern laptops will only engage the fan as needed when temperature requires it. It's a power saving measure. That said, I have seen replacement fans provided with PWM and tach wires swapped so you should always check that replacements match the original in every respect. Sorin has his merits, but he sure does some dodgy stuff. Take what you learn from him with caution.
                        As it's a shutdown issue, you have to ascertain whether it's a thermally induced shutdown (unlikely, as a Dell will usually throttle the CPU well before that), or a hardware issue with a rail disappearing.
                        Use Core Temp to check CPU temperature and power output. As it's an Intel system, you can use the Intel Extreme Tuning Utility to indicate what flags are being sent to the CPU etc (like PROCHOT). Prime95 can be used to stress the system, CPU temps should not exceed 90 degress under full load. If it shuts down on full load, but temp is ok, then you have to look at the power subsystems on the board. A physical examination can sometime reap dividends.
                        • Shummi
                          • May 2021
                          • 16
                          • Danmark
                          Hi reformatt
                          Thanks.
                          It is NOT a termal issue. I was tricked with the FAN didnt start at boot.
                          If i twist the laptop i can sometime get the screen flicker, and sometime just cut off, even if i run it in BIOS test ePSA (hold Fn and PRW ON) So I would rule out HD etc.
                          When I had it Dissasambled, I couldt get it to cut off.
                          Any hints on what prw Rail I should track first?
                          • reformatt
                            • Feb 2020
                            • 1521
                            I usually just put a probe on each coil when the fault occurs and see what is missing. Take note that CPU Vcore is at the end of the power sequence and requires all others to be functioning for it to be enabled. So if CPU Vcore disappears, make sure it's not because another sub rail before it has also died.
                            I did have a Dell machine (not this model) a few months back with a similar issue. In that case it was the +1V rail for the PCH that died intermittently. That turned out to be the boost capacitor for that buck converter had a broken solder joint at one end. So any flexion of the board would induce the fault.
                            Word of warning; don't go randomly probing around any buck converter (especially low voltage ones) with power enabled. Mess up the feedback and you'll end up with a dead PCH or CPU. With power off, physically inspect each component under a microscope for any movement and/or damage. A keen eye can sometimes reveal the fault.
                            • Shummi
                              • May 2021
                              • 16
                              • Danmark
                              OK, now I have the Mainboar out again, it flickered and shut down once.
                              I have attached an Arduino Nano, and measure every second at:
                              +5V_ALW
                              +3.3V_ALW
                              +VCC_CORE
                              And now I cant get it to shut down, I have twisted it 15 min, and let it run an hour..... Just working.
                              I haven't attached HD, only FAN, RAM and LCD.
                              So my quistion is:
                              1. does it need more than
                              +5V_ALW
                              +3.3V_ALW
                              +5V_RUN
                              +3.3V_RUN
                              +1.35V_MEM
                              +0.675V_DDR_VTT
                              +VCC_CORE
                              2. As it dosn't seem to be a power issue, what could it then be?
                              This fault is frustrating....:-)
                              • lapfix
                                • Mar 2020
                                • 2765
                                • my workshop
                                Back to this issue, i think it's a common fault.
                                same lap with same motherboard (la-9591p) with a same behaviour....fan not working..display present.
                                If i power on the lap without ram the fan is working proprely..but with ram no chance.
                                i try official bios , another fan , à multiples ram but still same behaviour.
                                jfan1 with ram :
                                pin4 =5v present
                                Pin2 = fan1 tach 3v
                                ​​​pin3 =fan1 pwm 0v
                                jfan1 without ram :
                                pin4 =5v present
                                Pin2 = fan1 tach 1.6v
                                ​​​​​pin3 =fan1 pwm 1.6v.
                                R408/R376 pullup resistor are ok =10kohm.
                                when i try for test with a tweezer joint the 2 side of R408 the fan start working at full speed.
                                see all the discussion before can i cut the red wire 5v and 5v connect the part that go straight to fan with 3v run!..and remplace r408 with 0ohm Résistance !​
                                  DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                                  This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                  09-06-2024, 04:40 PM
                                  09-06-2024, 04:10 PM
                                • diamon
                                  Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                  by diamon
                                  I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                  Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                  Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                  Pictures of these boards:
                                  Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                  Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                  Dell...
                                  02-28-2024, 12:51 PM
                                • Ven
                                  Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                  by Ven
                                  Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                  Issue Description:
                                  1. CPU Overheating to 100°C
                                    • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                    • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                    • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                    • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                    • Thermal
                                  02-12-2025, 03:57 PM
