Fx705gm fan full speed
  • quic307
    • Jun 2015
    • 255
    • Greece
    I have an Asus FX705GM and both fans works in full speed all the time. I was trying with software, same issue. I changed the fans and the problem remain.
    I'm looking for other problem in motherboard but I can't found anything.
    Do anyone solve this problem as mine?
    FX705GM - MB - FX505GM_REV2.1
    Thank you in advance...
    Nikos
    • 20592
    Re: Fx705gm fan full speed
    Does it take a while to boot up,have you tried cleaning the ME firmware
    • quic307
      • Jun 2015
      • 255
      • Greece
      I think it's cleaned, can you clean it, if it's not?
      https://www.badcaps.net/forum/showthread.php?t=93196
        • 20592
        are there any long white barcode stickers on the motherboard,or square QR codes, post pictures if there are
        • quic307
          • Jun 2015
          • 255
          • Greece
          No, probably removed from other service ...
          • quic307
            • Jun 2015
            • 255
            • Greece
            I change the bios with cleaned ME reg and same issue !!!
            • emil_t
              RTX3090 working fine but fans not spinning
              by emil_t
              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
              04-12-2024, 06:54 AM
            • Czompi
              HP EliteBook 745 G5 - Powered on + no image + fans at full speed
              by Czompi
              I've bought an HP EliteBook 745 G5 with the issue that the fans are at full speed and no image is shown, but the CPU is slightly warm.
              The laptop (probably) does not recognise when there is no RAM installed (it does not play a tone like other HP machines with Intel CPU, I have no keyboard to see if the capslock blinks).
              Is it possible, that said issue can be fixed or it is a dead CPU?
              Regards,
              Czompi
              04-06-2024, 01:01 AM
            • IvanAndreevv
              Acer Nitro 5 - CPU Fans spin full speed when turned off
              by IvanAndreevv
              Hello guys,
              I need some help with Acer Nitro AN515-54.
              As said in the title, as soon as I shut down the laptop, the screen goes black like usual, lights off, but cpu fans go full speed until the battery is dead.
              This started to happen yesterday after I have done some improvements to the laptop.
              1. Reinstalled new Windows 10 + drivers and updates
              2. Installed new 8GB RAM stick so total 12 now.
              3. Installed additional M2 NVME drive
              4. Installed additional hard drive (here comes my doubts, I installed 10 pin sata...
              01-05-2024, 10:05 AM
            • ostryo
              Sapphire Radeon TOXIC R9 270X problem with fans
              by ostryo
              Hello everyone. I have a strange problem for this card. Generally is fully operational, it gives a picture and can be used normally. The problem is that from the moment the computer is turned on, the fans are still working at 100% and it cannot be changed. Card temperature checked in gpu-z is very low. I checked on two BIOS which card has and the effect is the same.
              Does anyone have any tips or encountered such a problem?
              04-05-2022, 09:03 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
