FX505GD Realtek ALC233 not working
  • loic2907
    • Feb 2020
    • 34
    • France
    I repaired a FX505GD motherboard with a dead PCH.
    Today the laptop is working perfectly, but the sound is not working.
    Seems like the ALC233 is not detected.
    I checked :
    - The 3VS_AUDIO, 5VS, 1V5 coming in the ALC
    I replaced :
    - 2 times the PCH with a new one
    - the ALC233
    I attached the schematic + boardview
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: FX505GD Realtek ALC233 not working
    Voltage on Pin1/20/26/36/41/46 of audio ic??
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Btw, U mean Audio IC is not detected?? Or is it detected properly but no sound output?? Which one is correct??
      • loic2907
        • Feb 2020
        • 34
        • France
        Pin 1,20,36 : 3V
        Pin 26,41,46 : 5V
        Not detected at all, sound with a red cross in the taskbar
        • mon2
          • 14752
          Voltage on pin 40 of audio ic (AVDD2) ?
          • reformatt
            • Feb 2020
            • 1541
            If supplies etc are ok to the chip, then check HDA_SDI0, HDA_SDO, HDA_SYNC, HDA_BCLK and HDA_RST# lines for continuity to R2388, R2301, R2302, R2303, R2304 respectively.
            I had same issue on an Acer today (go figure). Problem was multiple open test pads from corrosion (which Asus also use) and an open track for the bitclock.
            • loic2907
              • Feb 2020
              • 34
              • France
              Have 1.5V
              I have the clock on BCLK, have some pulse on SYNC, have the RST too.
              Problem is on SDO, SDI0 no voltage.
              All the resistor are ok at 33 Ohm.
              I have no data on these lines, but it is connected to PCH, and I put 2 new PCH...
              I changed the EC too because it is connected to a diode PCH_FLASH.. *
              No voltage on PCH_FLASH too..
              • reformatt
                • Feb 2020
                • 1541
                R2388 appears to be a test pad so should be a short so check it. Did you check for continuity from the resistors to the audio IC pins? Where did you source the PCH's? Are they donor's off old boards?
                • loic2907
                  • Feb 2020
                  • 34
                  • France
                  All resistors have the good value.
                  And the continuity from resistor to IC audio is 2 ohm.
                  R2388 is shorted yes
                  The first PCH was from a donor, and the second PCH was a brand new PCH.
                  I have lot of donors, like FX505DD
                    • 22176
                    did you clean the bios ME firmware after changing each PCH
                    • loic2907
                      • Feb 2020
                      • 34
                      • France
                      Thanks for the reply
                      Yes because I had slow boot before ASUS picture.
                      With the clear ME slow boot is deleted but problem is the same
                      • loic2907
                        • Feb 2020
                        • 34
                        • France
                        Is this possible to UP this thread
                        • giangtt
                          • Oct 2017
                          • 18
                          • viet nam
                          try to load another bios, i have met acer laptop and asus doesn't recognize sound due to bios
                          • loic2907
                            • Feb 2020
                            • 34
                            • France
                            Thanks, I tried 3 different bios.
                            Maybe I have to mod it ?
                            • mon2
                              • 14752
                              HDA_RST# is active low. If this line is LOW, the ALC233 will remain in reset state.
                              What is the voltage on HDA_RST# ?
                              Do the donor boards from where the PCH was extracted offer the same ALC233 audio codec ?
                              • loic2907
                                • Feb 2020
                                • 34
                                • France
                                Hi, HDA_RST# is at 0.5V
                                Yes I replaced it 2 times with ALC233 from this donor and other donor
                                • mon2
                                  • 14752
                                  With this voltage on HDA_RST#, the chip is parked in RESET and will not work.
                                  Check for the presence of a pull-up resistor on this line. Often, reset lines are open drain signals and must use a pull up resistor to pull this line high.
                                  The pull up resistor or the voltage on the pull up resistor may be missing.
                                  • loic2907
                                    • Feb 2020
                                    • 34
                                    • France
                                    Sorry for being late, had to do computers.
                                    There is no pull up for the HDA_RST#, but a pull down names R2397. And the value is good.
                                    I did a bridge to a 3.3V directly to the HDA_RST#, but still the same...
                                    • loic2907
                                      • Feb 2020
                                      • 34
                                      • France
                                      Hi is this possible to up this thread ?
                                      • mon2
                                        • 14752
                                        Careful here, if the line is open-drain. So this means that an external signal can drive this line LOW but there is no logic high. An external pull-up resistor is required to pull-it high.
                                        If you bridge this line directly to 3v3, then you may have a collision of the pin driving the pin LOW and then your external hard-strap to 3v3. Not a good combination.
                                        If you cut the trace that is driving this trace and then take the floating HDA_RST# pin (due to the cut trace) and strap it to 3v3, this should be ok.
                                        Just asking on what the voltage level is on this pin after the hard-strap. If possible, check it with a scope which should show a pulse LOW and then HIGH if all is well - this should be the case, without the need to strap it to 3v3.
