PS4 HDD not detected even after replacing it with a working one
  • walangalam
    • Jun 2024
    • Caemlyn
    PS4 HDD not detected even after replacing it with a working one in another PS4. What to check?
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Cables, power supply ....
    • walangalam
      • Jun 2024
      • Caemlyn
      hdd is connected directly to the motherboard so no cable. I will try another power supply...
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        the rest of the console is supposed to be working ? Only the original hdd was the problem ?
          • 31294
          trace the drive connector +5v lines - it may have a fuse
          • walangalam
            • Jun 2024
            • Caemlyn
            its working. when I turn it on I get the message "HDD not detected"
            • walangalam
              • Jun 2024
              • Caemlyn
              do you know which pins?
                • 31294
                https://pinoutguide.com/Power/sata-power_pinout.shtml
                • gcrezz
                  GameConsoleRezz
                  • Jul 2024
                  • 14
                  I suggest getting the metal cover off the board and inspecting the connector itself for damage. These aslo get extremely dirty and it may just be dust. Also inspect the 5v rail for a short or fuses on the board (typically labeled Fxxx). Hope this helps.
                  • titomno2
                    Acer AN515-52 SATA1 port not working no hdd detected in BIOS...
                    by titomno2
                    Hi guys,
                    On motherboard ACER AN515-52 type LAF951P.
                    I fixed issue with not starting computer (it was the PQ201 component not working properly).
                    But after checking everything I have still an issue with secondary SATA connector JHD1 (for HDD typically).
                    Basically some HDD spin but are not detected by the bios.
                    Already tried following:
                    checked the 4 data lines
                    #2 RDSATA_PTX_C_DRX_P4 => CO18 (10nF seems OK) => RO24 (0Ohm measured at 0.25Ohms).
                    #3 RDSATA_PTX_C_DRX_N4 => CO17 (9.68nF seems OK) => RO23 (0Ohm measured...
                    07-28-2024, 08:30 AM
                  • TyMercer
                    Can I flash a working BIOS from one computer to another of the same make, model, etc?
                    by TyMercer
                    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                    11-13-2025, 09:39 PM
                  • MMH3
                    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                    by MMH3
                    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                    Never ever i experienced problems with that.
                    Now i have one 5050sff machine, where this jumper isnt working at all.
                    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                    The history of the machine is that i used it in my office...
                    03-23-2025, 09:28 PM
                  • DynaxSC
                    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                    by DynaxSC
                    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                    The board is generally working now, all PCIe ports are working, Windows installs normally.
                    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                    03-10-2025, 12:27 PM
                  • hopkok
                    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                    by hopkok
                    Hi masters, I need your help.
                    I am working on Lenovo Legion 16ITHg6
                    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                    Power LED is not working as well, power button working well.
                    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                    Motherboard...
                    05-04-2025, 09:35 AM
