Hi all, my hp g62 is showing black screen. Connecting it to an external monitor works. I tried the panel and the flat on another motherboard and it works. I would like to know which component is causing this malfunction. Thank you all.
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappearedI bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
by redwireOnkyo TX-SR607 HDMI problem showing a black screen intermittently, audio was OK.
It would usually cut out a few minutes after power on, for maybe 1 minute then work OK, then cut out and go to black again. Or fade out to sparkles and noisy video.
Well known is these boards need recapping and there is a strange mix of parts on both sides of the board.
The bottom of the board has 100uF 4V (5.3*5.3mm, qty 5) and 220uF 4V (6.6*6.6mm, qty 5).
Per the service bulletin, an issue is the Toshiba LDO's want low ESR for stability so I went with 100uF 6.3V polymer...-
by turmixHello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
During another reassembly, I made a mistake, and...-
Hey folks,
I picked this neat monitor up from a recycling center years ago, and it worked fine for a long time. I know they are prone to T-con issues with the Altera chip, but I've yet to experience any symptoms of that going. I always perform scaling on the GPU though. It had occasionally thrown a black screen at me, that was usually reset by powering it off, and reseating the DVI-D cable in the sole input. I gave it to my brother who said the problem got worse, and it would be very difficult to get it to display a picture, it took lots of fiddling. As far as I understand him, it always...-
- Loading...
