Lenovo Yoga 510 no power!
  • Ariu
    • Dec 2020
    • 133
    Re: Lenovo Yoga 510 no power!
    Originally posted by mon2
    1) Check and post the resistance (no power to the board) for the other mosfets. See attached. Still checking to see if there are any damaged mosfets.
    2) For the first 2 mosfets (N-channel), the GATE voltage needs to be higher than the voltage being passed through to enable.
    3) Suspecting that the charger IC is damaged and needs to be replaced but check for possible mosfet damage.
    This Intersil charger IC is available from Digikey (and a few other vendors):
    https://www.digikey.ca/en/products/d...ource=octopart
    https://www.findchips.com/detail/isl...ion?quantity=1
    4) Do check the voltage on the OTHER side of PR307 which is driving the gate. Is the voltage there also ~0V ?
    UPDATE:
    after changing the charger ic now the first 2 mosfets are working fine and the 19V power rail is on board available, however the +3valw and +5valw are missing.
    ENLDO_3V5V on pu401 is there 4,7V but 5V_3V_EN5V_3V_EN is 0V , is possible that pu401 need to be replaced??
    • Ariu
      • Dec 2020
      • 133
      [QUOTE=Ariu;1098468]UPDATE:
      exactly the same thing on pu402 ENLDO_3V5V is 4,7V but5V_3V_EN5V_3V_EN is 0V
      • mon2
        • Dec 2019
        • 14169
        See attached.
        5V_3V_EN is driven by a resistor based voltage divider. From my information, a part with a '@' prefix = NOT STUFFED on the logic board.
        So, confirm the presence of PR410 (whereas PR411 location should be blank).
        Then check the voltage on PR410, pin # 1 = EC_ON. This signal line is driven by the EC IC @ U11, pin 112.
        • Ariu
          • Dec 2020
          • 133
          [/ATTACH]
          See attached.
          yes i have seen that EC_ON is driven by U11 pin#112 , pr410 no voltage on both pins...
          • Ariu
            • Dec 2020
            • 133
            See attached.
            not good i have seen now physical damage on SuperIO it muss be also replaced...
            • mon2
              • Dec 2019
              • 14169
              Ouch. Yes, indeed. @SMDFlea and others in this forum are the experts on EC programming, etc. Personally have not done one yet.
              From my limited knowledge on this component - there is an embedded 8051 architecture inside this device. Respectively, you will need an EC programming tool which vary in price and features.
              With the applied firmware, the GPIO pins will then behave as expected to power on the buck regulator enable pins, etc. to operate the logic board.
              Do you have a programming tool for this EC controller ?
              • Ariu
                • Dec 2020
                • 133
                Unfortunately is game over for this device , after a little bit search i realized that the blank chip need to be programmed and onfurtunately i dont have this programming tool...
                Physical inspection is very important to Save more time, but
                Thank you very much for your help.
                • mon2
                  • Dec 2019
                  • 14169
                  No worries. You are quite welcome.
                  Do not junk the device - just shelve it for now. We are studying the devices to understand how this programming works for a future widget. A lot to know but from the brief research so far, a developer in Russia (I believe) offers an instrument for this requirement. It is not cheap but apparently works well.
                  Perhaps one day, @SMDFlea and/or @Piernov will make housecalls for such repairs
                  • Ariu
                    • Dec 2020
                    • 133
                    Unfortunately is game over for this device , after a little bit search i realized that the blank chip need to be programmed unfortunately i dont have this programming tool...
                    • Ariu
                      • Dec 2020
                      • 133
                      These are very good news , in this forum are many talented guys such as programming like SMDflea
                      • Stevedb
                        Stevedb
                        • Feb 2018
                        • 624
                        • Belgium
                        #31
                        You can also buy EC Chips preprogrammed on ebay.
                          Lenovo Yoga YOGA Book Hybrid (2-in-1) Book Specification for Upgrade or Repair
                          This specification for the Lenovo Yoga YOGA Book Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the YOGA Book boardview and YOGA Book schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                          09-06-2024, 08:10 AM
