Motherboard of Fujitsu E754 on E744 laptop
  • bran.iliev
    • Jan 2020
    • 9
    I have Fujitsu E744 with faulty motherboard, I bought motherboard for Fujitsu E754, because I can't find mainboard for E744. The motherboard of E754 is working with external display, but internal display(1600x900pixels) of E744 is not working with E754 motherboard, which is designed for 1920x1080pixels LCD panel. Can I make E754 motherboard to work with E744 1600x900 dysplay?
  • bran.iliev
    • Jan 2020
    • 9
    Re: Motherboard of Fujitsu E754 on E744 laptop
    • mon2
      • 14677
      Hi.
      Do you have the schematics for these logic boards ? Can you link them ?
      If not available, post the full markings / label pics of each display panel.
      There are many different styles of panels that vary in details such as:
      pinouts
      backlight voltage
      data interface - could be MIPI; LVDS; DP; eDP (just some from my memory bank)
      Each is a factor on which LCD panel can be used where.
      You cannot simply swap out panels unless all of the details are investigated. Perhaps the LCD vendor has a compatibility list and it may work for your case but just quickly guessing that it will not be a drop in replacement.
      You risk damaging the panel and/or logic board with the wrong substitution.
      • nikokin
        • Mar 2013
        • 20
        • greece
        e754 e744 e734 have lcd edid whitelist, laptop will only work on specific lcd,
        specific panel, fujistu is very unfriendly to swaps and repairs, i have two motherboards one for e754 and one for e734 both with broken lcds, and if you swap them they will not work, only backlight works but no image.
        • Conste
          • Oct 2018
          • 235
          on E554 models there is a eDP and LVDS version of board, which use the same connector on the mainboard.
          So the (wrong) screen will fit but not work.
          • Geeker007
            Friend messed up my laptop motherboard while working on my bench
            by Geeker007
            Hi All,
            So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
            So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
            I have not tried putting...
            06-16-2025, 01:40 PM
          • Username338
            Laptop BA92-09470B motherboard schematics
            by Username338
            Thank you for deciding to read this topic!
            Laptop: NP700Z3A-S02RU
            Motherboard: BA92-09470B
            I was trying to fix my old laptop that has stopped displaying image a long time ago. It boots up, lights light up, fan spins but no image. Conned it to TV by HDMI cable, but it was unsuccessful. Components look intact, no water damage/corrosion on the board.
            I don't really value this laptop too much, so I wanted to ask anyone for a schematic/boardview file or anything that describes motherboard in a simillar faison. I want to experience a challenge of figuring...
            03-09-2025, 03:52 PM
            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
            09-06-2024, 09:30 PM
            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 08:47 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
