Early 2011 MBP 13 inch not booting
  • bvlad_alex
    • Jan 2022
    Hi!
    I would like to ask for an opinion regarding my 13 inch MacBook Pro early 2011 model. The motherboard is a 820-2936 B revision.
    The reason why it broke is pretty stupid, I just dropped a piece of aluminum tape on it while the back cover was off. It was not turned on but it had the battery plugged in so quite a few power rails were up and seems it still managed to short something out.
    I have a green light with just the charger, if I connect the battery it charges correctly and the battery indicator on the side is working correctly displaying the charge level.
    In SMC bypass mode the fan will come on at 100% but still no boot.
    So I started a little bit of troubleshooting with the schematics and the boardview and I saw that the "ALL_SYS_PWRGD" is missing which is basically a prerequisite for getting in S0 state.
    I then took each rail and measured it and as it turns out I am missing just "PPVCCSA_S0_CPU" so I concentrated on the IC generating it which is U7100 (ISL95870A).
    It is getting supplied with voltage and is also getting an enable signal. First though was that the output is shorted somewhere but I read a little bit on the forum and the resistance to GND that I am getting on the output of the DC-DC converter is pretty consistent to some of the values I found here, which is about 14ohms.
    I then took pin by pin and found some very low resistance values on the SREF, SET0 and SET1 pins of the IC:
    Pin 7: SREF -> 3R
    Pin 8: SET0 -> 0R
    Pin 9: SET1 -> 8R
    Trying to test the ESD diodes with the DMM on diode mode also bears similar results, 0 on all 3 pins.
    I have also tested the 2 NMOS (Q7100) package with the DMM and it seems fine.
    I am attaching a summary of the voltages I get on the main rails.
    My opinion is that I should replace this IC but I kindly ask for you opinion as well: do you see any reason that this would come from a different problem and if so what should I order besides this DC to DC controller?
    Many thanks in advance for reading this far!
  • mrsith
    Macbook Pro early 2011 - no audio
    by mrsith
    Hi. Got a Macbook Pro early 2011 model, EMC2419, with no audio. Was hoping for a loose speaker cable or audio jack replacement...
    Upon opening I have discovered some liquid damage. The R6211 had obvious corrosion. Replaced it and cleaned the board PCB as much as I could. Still no audio (no output devices, no startup chime, and before Macbook shows apple logo with loading bar, it displays white screen for about 10 seconds). I have noticed solder joints around audio jack a little bit worn/bad, corrected them so they appear neat now.
    Anserwing some questions before they're asked:...
    06-28-2022, 03:32 AM
  • worldofskin
    iMac A1312 2011 27" 820 - 2828 4mem Error Not booting to OS
    by worldofskin
    Hi guys. Hope you are having a great day. This imac iMac A1312 2011 27" with this logic board 820 - 2828. Came to the shop becouse it doesnt boot.I started the apple diagnostic and got 4mem error. I disassembled it, cleaned it and replaced the ram. For a little while it worked normally. But after a while it got to the same state. I tried changing all the ram with a good known working ones. Nothing, i tried a different drive to boot from, nothing. I tried to not boot from sata but i disconnected drive and connected only via usb. nothing. I tried to change the graphic card nothing. I dont have...
    11-03-2022, 05:07 AM
  • Aeisens
    Samsung UE50RU7170 not booting /no picture
    by Aeisens
    Dear all,
    My issue is the following:
    Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
    I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
    Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
    Question 1: Where should I start to...
    06-24-2025, 03:07 PM
  • Daniel Kubica
    Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
    by Daniel Kubica
    I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
    I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
    06-14-2025, 09:24 AM
  • sylvain_92
    iMac 2009 A1312 2009 not booting - 3rd led not on
    by sylvain_92
    I am trying to repair my iMac A1312 late 2009 intel i5.
    First of all it was booting but no screen on internal lcd but working with external one,
    I tried:
    - another screen and led power board (booting no screen - same as before)
    - another mxm graphic card (not booting missing 3rd led)
    * screen and mxm gpu tested are 100% working on another A1312 iMac.
    I putted back the original mxm graphic card and what a surprise, now it's not booting anymore even with the stock parts.
    The main...
    12-23-2022, 03:36 PM
