Prevent the BIOS flashing from starting when the PC is started
  • Christian0734
    • Nov 2020
    • 92
    • France
    Hello
    I have driver update software that "bricked" me into my bios. I managed to reprogram the EPROM with a stock bios and the PC is working again. Only when I use the same hard disk, at each restart, the modification of the firmware is restarted and it crashes me again the bios. Where is the script on my hard drive that restarts flashing and crashes the bios? I would like to continue using my system with the hard drive where there are all my programs without having to reinstall everything. For information, with another system on another hard drive no worries, everything works, it's just with my main hard drive that the flashing of the bios is started at startup and that it crashes me the bios
  • mayss
    • Nov 2016
    • 30
    • Polska
    Re: Prevent the BIOS flashing from starting when the PC is started
    Start windows in safe mode and disable the start of the driver updater. You can do this from the cmd console in safe mode by typing msconfig and disabling the program in the auto-run tab.
    • kenkaniff
      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
      by kenkaniff
      Product Name: HP Pro x360 Fortis 11-inch G9
      System BIOS: U94 Ver.01.08.00 10/06/2023
      Serial Number: 5CG31946F5
      SKU Number: 85W05EC#AK8
      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
      I needed to remove bios password...
      10-01-2025, 04:32 AM
    • Timeeez
      X270 - Bios flashing help
      by Timeeez
      I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
      Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
      11-30-2022, 05:17 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • lucaszmn
      by lucaszmn
      Problem:
      Initial Findings:
      • I concluded that the
      08-12-2025, 03:01 PM
