I'm working on an A1708 Macbook Pro, 820-00840 board. It came in with 4.97V, 0.21A on USB-C meter. Both ports gave different readings, the other was 4.99V, 0.14A. Owner said it stopped charging but was running off battery fine. I replaced U3200 because I got 38.9ohm to gnd on C3208 which went to OL after I removed U3200. Both PP1V1_UPC_X*_LDO_BMC were 0V with original U3200. After replacing, I get 19.9V but current stuck at 60mA, I also get the missing 1.1V. I get a slightly different voltage sequence on both ports though, for the U3200 it's 5.02>12.5>19.9 and for U3100 it's 5.02>9.16>19.9. I get 13.04V at F7000 and at L7030 the voltage fluctuates between 9.7-9.8V
					Macbook Pro A1708, 820-00840, 19.9V, 60mA
	Tags: None
Re: Macbook Pro A1708, 820-00840, 19.9V, 60mA
1) Is the DC volts reading of PPBUS_G3H stable ? F7000, pin # 2.
2) Remove all power (no adapter / no battery).
Meter in resistance mode.
Measure and post the resistance to ground of L7030. Red meter probe on either side of L7030, black meter probe to ground.
Keep in mind that the mosfets @ Q7030 & Q7040 are switching ON / OFF to create the target voltage rail of PPBUS_G3H. For this reason, do not expect a steady DC voltage @ L7030.
However, the voltage @ F7000, pin # 1 & #2 must be stable to power the logic board.
Does this logic board power on now ?
3) Where exactly are you measuring the voltage up / down sequences of U3100 & U3200 ? Which pins ?
4) Post the voltages for:
a) PPDCIN_G3H
b) PPVBAT_G3H_CHGR_R
c) PPVBAT_G3H_CONN -
F7000 pin2 = Stable 13V
L7030 resistance to gnd = 4.5Mohm
Logic board does not power on
U3100 and U3200 I measure at C3*08, C3*06, C3*05, C3*04
PPDCIN_G3H = 20V
PPVBAT_G3H_CHGR_R = 20V
PPVBAT_G3H_CONN = 13V
All measurements taken with charger only, no battery connected. Does this suggest a faulty U7000?Comment
No, your U7000 appears to be working.
Review this webpage and post your updates:
https://repair.wiki/w/A1708_2016,_20...ar_MacBook_ProComment
R7192 was not there. Soldered one from a donor and all is good now. looking for a PP5V_S4 probe point led me to it. Thank you mon2 and thank you Louis Rossman!Comment
			by abajorLike title says A2141 came in with Water Damage, customer desperately wants the data.
The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
That said after cleaning up the... -
			i have a a1708 efi lock and cannot enter dfu.
Model: Macbook Pro Late 2016
Model Number: A1708
Serial Number: C02SQDCEGVC1
Board id# 820-00875-A
EMC2978
i need to unlock efi please...-
							Channel: BIOS Requests ONLY!
			by dbuergiHi all,
i fixed a A1708 which was not working. Not its booting but the left speaker is making buzzing and sizzling noises. I added a short video to show it.
https://www.dropbox.com/scl/fi/ju6v7...=lewlrdkh&dl=0
I already reflowed the audio codec chips but that didn't help. Any ideas what to do? -
			by ahoonidHi everyone.
I have MacBook Pro A1708 with a confusing issue.
The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
The initial issue however remains.
No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad... -
			by abajorJust looking for a second opinions before I try to source a CD3217
Rear USBC sits at 5.1V 0.01A
Forward USBC power cycles.
PPBUS_G3H 7.5-8.3V cycles with rear USB, Cycles 0-12.5V on forward USBC
PP3v3_G3H_RTC ~3.9V with rear USBC, cycles 0-5.1 on forward USBC.
PP3v3_UPC_XB_LDO diode drop reads about 0.074V
I'm almost positive it's U3200 (its also the only thing getting warm on thermal camera) second opinions always helpful.
Thanks! - Loading...
