Lenovo nm-a161 no backlight
  • f-bone
    • May 2013
    • 96
    • Greece
    Hi guys,
    I got this motherboard that has picture without backlight.
    I measured +LEDVDD at 19V and also other voltages are present at LVDS connector. LID_SW# is at 3.3V and I noticed that BKOFF# is always LOW (0V). I tried new clean ME bios as well.
    Any pointers are really appreciated.
    BR,
    George
  • mon2
    • 14675
    Re: Lenovo nm-a161 no backlight
    Measure the voltage on LID_SW#, with the LID open. Then repeat with the LID closed.
    Any changes to the voltage values?
    The LID_SW# must be used by the IT8586E/AX (UE1) to then turn the backlight ON / OFF.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Ive faced BKOFF# being low on many Lenovo SOC mb's specially on LA-C771P(3-4 units so far). It was SOC fault in my case. I just cut the track of BKOFF# pin from EDP connector, removed the BKOFF# cable from EDP cable and connected it to 3v source from mb. It works now though brightness adjustment is no more available. Try it as a last resort but first findout the reason.
      • f-bone
        • May 2013
        • 96
        • Greece
        @mon2 I measured LID_SW# while the motherboard was on my bench with a LCD connected.. no BKLT.
        @mcplslg123 I tried that - I cut the trace going to pin 30 and attached a jumper wire to the LVDS connector directly and to LCDVDD_CON capacitor. No dice.. maybe I should try +3VS?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          @f-bone, you are shorting LCD_VDD to BKOFF# thru that jumper. It wont work. Take +3VS from any other source and connect it to pin30. Hopefully will work. If you have dc supply, then u can inject 3v directly on pin30 and see if u get backlit.
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            # - means that signal is ACTIVE with LOW voltage
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • techpointhull
              Lenovo V15 G3 No Backlight after liquid damage
              by techpointhull
              Good morning guys,
              I have a Lenovo V15 G3 that came in with liquid damage. The damage was very minor and some corrosion on the IO board where the power switch was. After cleaning both the motherboard and IO board in alcohol, the laptop turned on and I had backlight for about 3 seconds but nothing further. I don't have a boardview for this laptop (Have requested this in the Schematic Request section), however from previous experience on Lenovo laptops I have checked pins 1, 2, 3 on the EDP connector. When the battery is connected only, I get 8V and when AC adapter is connected, I get...
              11-28-2023, 01:57 AM
            • Echoo
              Lenovo ThinkBook 13s-IML (20RR) No backlight!
              by Echoo
              Hello!
              The image is visible, but there is no backlight! On older Lenovo laptops, this problem could have been solved by replacing a fuse, but now I can't find the solution!
              P207JXJ6...
              10-01-2025, 12:20 AM
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • XIII
              Lenovo CSA20 LA-D953P NO BACKLIGHT
              by XIII
              Hi, I have this Lenovo V510z AIO with the mobo CSA20 LA-D953P with no backlight at all, I've tried checking on different websites for schematics or anything leading to the location of the backlight circuit with no luck, there's nothing that seems to be burned out nor shorted is there any way to troubleshoot this issue? thank you in advance...
              06-18-2024, 12:38 PM
