HP 15 LA-G078P No video
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Hi friends
    Please help me with this laptop, it turns on without video...
    Model: HP 15-db0004la
    MB: LA-G078P
    Processor: AMD A4
    I have this laptop that powers up without video, has all of its voltages on its coils, and draws 460 mA.
    No schematic, no boardview, I have been using LA-C701P schematic with kb9022 EC.
    I have these measurements:
    LID_SW# 3.07v (EC pin 115)
    PCH_RSMRST# 1.8 v ??? (EC pin 100)
    PCH_PWROK 3.3v (EC pin 32)
    PLT_RST# 3.3v (EC pin 13)
    Ram Measurements (in red)
    DDR4 ram section voltage check list at ram slot
    DDR4 operating voltage VDD (at coil )= 1.2V 1.2v
    and 142 pin 1.2v
    VTT/Termination voltage= 0.6V PIN 258 0.6v
    VRef_CA. = 0.6V PIN 164 0.6v
    VDD SPD = 3.3V PIN 255 3.3v
    SDA data = 3.3V PIN 254 3.3v
    SCL clock = 3.3V PIN 253 3.3v
    DRAM_RST# = 1.2V PIN 108 0v ????
    Other measurements
    APW8868C (Ram IC) pin 10 (PG) 1.2v ( I guess is correct)
    SY8286BRAC (3alw IC ) pin 9 (PG) 1.3v (LA-F486 schematic)
    SY8288CRAC (5alw IC) ping 9 (PG) 1.2v (LA-F486 schematic)
    I know my problem is RSMRST# (1.8v) but without boardview or schematics is very dificult to find where component is connected, also, having PLT_RST# I thought that all of the above was fine.
    Could you tell me how to continue please?
    I attach all the files
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15 LA-G078P No video
    RSMRST# 1.8V is very likely correct as bios chip may be 1.8V on this mb. Your problem is DRAM_RST 0V. Check consumption on dc supply
    01 With RAM
    02.Without Ram.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      try a locate RC308 & find out the voltage top both sie of the RC308 feedback
      • ruletero
        • Nov 2018
        • 182
        • Mexico
        01 With RAM
        02.Without Ram.
        Thank you mcplslg123
        sorry for the mistake... It consumes 436 mA with Ram and 425 mA without RAM
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          System is not reading Ram. check ram ic requirement as well as voltage on ram slot. Thoroughly clean the ram slots(assuming its not onboard memory). Last but not the least, try with known good ram stick. Btw, Did you flash bios??
          • ruletero
            • Nov 2018
            • 182
            • Mexico
            Sorry, I forgot to tell it, yes, I have programmed bios with the oficial from HP ( I downloaded and extracted it).
            Too I have checked all the ram requirements,they are higher friend, all the voltages seem fine except DRAM_RST.
            And I have three DDR4 memory modules, I have checked each with without success.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              IF you have taken all the steps, it could be bad memory controller in SOC.
              • ruletero
                • Nov 2018
                • 182
                • Mexico
                Thank you friend but I didn't find any component o resistence connected to Dram_rst, only a test point...
                • ruletero
                  • Nov 2018
                  • 182
                  • Mexico
                  Ok, I'm going to give the bad news to the client: /
                  thanks for everything mcplslg123
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    @ruletero, faced this on many occassions specially more on SOC platform where we dont have the liberty to replace the cpu and/or pch. So have to give up.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      However, as a last ditch attempt, you can try to replace the pch power ic and its surrounding caps. The cmos cell must be inserted and ram stick also put in place and then power on-it may read ram properly but once you change the ram slot and/or remove cmos cell, it will start behaving same. This trick works on dell 3521 LA-9104P mb where system not reading ram is common fault(replacing the pch is the ultimate solution)-solved many cases utilising this. May help others struggling with this fault.
                      PS: Not sure whether it'll work or not on AMD Platform. Honestly never tried it on AMD Platform.
                      • ruletero
                        • Nov 2018
                        • 182
                        • Mexico
                        Sorry for my ignorance, in this platform what is the pch power ic? 1.05v?
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          very likely yes but need schematic to be sure.
                          • japlytic
                            Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
                            by japlytic
                            On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
                            So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
                            12-30-2022, 11:12 PM
                            HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM E-2124G Specification for Upgrade or Repair
                            This specification for the HP Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM boardview and Z2 G4 + 8GB (1x8GB) DDR4-2666 ECC RAM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                            09-12-2024, 02:20 PM
                            HP EliteBook 830 G5 + 8GB 2400 MHz DDR4 Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook 830 G5 + 8GB 2400 MHz DDR4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + 8GB 2400 MHz DDR4 boardview and 830 G5 + 8GB 2400 MHz DDR4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                            09-06-2024, 07:00 AM
