MacBook A1502 EMC 2835 820-4924-A dies when installing firmware update
  • brconta
    • Jul 2020
    • 5
    • Brazil
    I have a macbook Early 2015 A1502 EMC 2835 820-4924-A.
    Whenever I try to update the system the device dies after reboot. It only comes back to life if the battery is disconnected, and then connected again (energy drain). Apparently the firmware update fails.
    I can install High Sierra normally, but I can't install a newer one.
    I can use a disk with a newer system that was installed on another machine.
    I've already tested another chip and another bios file, but no effect.
    Boot ROM: MBP121.0177.B00
    SMC: 2.28f7
    I've tried the procedure to perform the firmware update manually, using the macOS installer .fd file, but the macbook also dies when rebooting.
  • reformatt
    • Feb 2020
    • 1535
    Re: MacBook dies when installing firmware update
    Are you using original Apple SSD or M2 NVMe with adaptor? I have heard of FW updates failing due to the latter.
    In the donor EFI you are using, check that the serial number is correct for your machine, and Fsys checksum is valid in the dump. Note if you are using a donor EFI file, it must be a clean ME and configured for a MAC.
    • brconta
      • Jul 2020
      • 5
      • Brazil
      Thanks!
      I know of this problem with SSD + Adapter. I used genuine Apple SSD in testing.
      BIN files were ME Cleaned and FSYS is valid.
      Maybe a workaround would be to get a bin already with version 428.40.10.0.0, but I believe that the brick problem would not be solved in a future needed upade.
      • brconta
        • Jul 2020
        • 5
        • Brazil
        I couldn't find a solution for firmware upgrades crashs. But a workarround is good for me.
        I got a bios file from a similar machine with Monterey, clean ME and edit serial number. Then i able to install OS 10.14+, on genuines SSD ou Nvme + Adapter, without issues.
        Bios .bin is attached (don't forgot to change serial and validate F-sys to use this).
        BootROM Firmware: 428.40.10.0.0.
        bios moved to new thread: https://www.badcaps.net/forum/showthread.php?t=100913
        • reformatt
          • Feb 2020
          • 1535
          Re: MacBook A1502 EMC 2835 820-4924-A dies when installing firmware update
          I bought a Macbook Air off eBay as not working. It actually powered up ok. I noted that they had Big Sur loaded, but the EFI firmware was ancient (182.0.0.0). So I tried reloading MAC OS, and it had the same issue as you. On the first reboot, it would not power back on, and I'd have to remove battery etc to power on again. Then it would say that EFI update had failed.
          So I took a look at the board. All of the termination resistors for the SPI ROM measured ok, no corrosion. But I noted that Q8150 was missing on the board. Definitely removed or knocked off. It's part of the ALL_SYS_PWRGD logic, so it's interesting the board powered on at all. The seller said fan was intermittent, so I guess random fan spin fits.
          Anyway, installed that, and tried installing High Sierra. This was ok, no FW update. Then tried Mojave, this updated EFI from 182.0.0.0 to 188.0.0.0. Then tried Monterey, and it worked as well. So maybe your issue is elsewhere on your board, not specific to the SPI ROM.
          • reformatt
            • Feb 2020
            • 1535
            Also posting the EFI config for the SPI ROM from my SVOD3 for reference. This is as read from an existing ROM off a 820-00165 MBA board. Quad Enable bit must be set. I'm assuming it's the same for other Quad SPI boards. The 820-4924 board is Quad SPI.
            • gbuniva
              MacBook A1502 (820-3476-A) Repair case with solution
              by gbuniva
              Hi everyone, I want to share my tech experience with a MacBook Pro A1502 late 2013 that won´t turn on.
              The computer arrived dead, when connected to Magsafe no lights on the connector.
              Here some Measures at some testpoints on de LB 820-3476-A :
              PP3V42_G3H 1.7V
              PPBUS_G3H = 0V
              PPVBAT_G3H_CHGR_RE = 0V
              PP3V3_S5 = 0V
              PP5V_S4 = 0V
              P5V1_SW = 5.5V
              PP3V3_S0SW_SSD =0V
              PP3V3_S0SW_SSD_FET =0V
              PPDCIN_G3H_INRUSH = 16.10V
              PPDCIN_G3H_CHGR = 16.10V
              PP5V_S5 - 0v
              PP3V3_S5 - 0v
              PP3V3_SUS - 0V
              PM_RSMRST_L - 0v...
              04-09-2025, 07:11 PM
            • Miiuser
              Macbook pro a1502 emc 2835 bios error
              by Miiuser
              Hello when trying to flash bios to the motherboard I get Verification error on address: 0x00000010, Device: 0xFF, Buffer: 0x5A.
              Is there any way to fix this error?
              Also the computer will no longer boot....
              03-28-2023, 06:07 PM
            • echothegamer
              Macbook A1466 dies when charger disconnected
              by echothegamer
              Hello all,
              Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
              Details:
              Macbook 13' A1466
              Board (820-3209-A)
              Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
              Pictures below of Boardview and schematic...
              I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
              It's an older model and it is very likely that battery has become...
              10-28-2023, 12:00 PM
            • dclass-pro
              macbook A1502 not charging if battery is at 0
              by dclass-pro
              Hi guys,
              I have a macbook A1502 that does not charge if the battery is completely discharged!!
              If I unplug it and reconnect it to the motherboard it starts to charge well, and it charges up to 100% and works.
              If I let the battery completely discharge, and connect the charger, the magsafe2 LED turns orange but it never charges the battery.
              What do you recommend I try?
              I tried to change the battery with a new one and the problem did not solve it​
              Code mainboard 820-3476-A
              02-28-2025, 02:25 AM
            • envym
              MacBook Pro 2018 with Activation Lock
              by envym
              Hi everyone!
              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
              06-27-2025, 08:54 AM
