Macbook pro 15 inch A1707 - 820-00281
  • fricosu007
    • Feb 2016
    • 29
    • romania
    i have a huge issue with this one here, client upgraded to lates osx and he was using "File Vault" he got some error when upgrading, now i cannot erase the drive by using normal software, pc boots into all modes, we use the password to access the driver which was File Vaulte-ed but still cannot delete it, i suppose ssd got corrupted in some way, i tried fixing it with all the tools i found but only software, cannot partition or erase the drive, it has 256 gb onboard ssd
    Do you have any suggestions ? Should i replace the SSd ? i have a donor board with same nands ... what else can i try ? i also tried flashing it using another mac or powering up in usb mode .. nada .. niente .. nulla, zip.. zilch hard is fked up .. from my opinion ..
  • mon2
    • 14370
    Re: Macbook pro 15 inch A1707 - 820-00281
    One idea is to use the data migration tool but not sure if it will work here. In theory it should. From a brief chat with the seller, they noted that contents of the SSD appears just like a USB drive that you can read / write using the remote PC. He said this can perform the same even on a dead board.
    https://www.ebay.com/itm/28298966413...4AAOSwJqNbEE3D
    • fricosu007
      • Feb 2016
      • 29
      • romania
      i see ... but it;s expensive gear for just one mac, i think i will just replace the nands and hope it will boot after .. donno how t2 will react to new ssd .. and this sh;t "file vault " that actually locked the ssd and now it;s so stubborn to not let itself being deleted even with the good password
      • fricosu007
        • Feb 2016
        • 29
        • romania
        DFU mode to reflash the os not working, logging in and mounting the ssd to that specific user works but again i cannot erase / format / partition .. if i check the UDID of that user i get different UDID so .. something went wrong with the encryption .. still if i mount the partition DATA i get all files readable, i cannot format it in any way, the headers probably got corrupted and they are not answering to that specific user no more ... cant understand this so well ... the good thing is that i have a good developed tech shop that i own and probably 10 yrs skills in repairing apple products so ... i guess i will go ahead with the replacement .. see what happens
        • fricosu007
          • Feb 2016
          • 29
          • romania
          i need to mention that i don;t need the data, it has all been backed up so .. just erasing all and make fresh install of the OS would be enough
          • leonemax81
            Macbook a1707 820-00281 Battery no Power
            by leonemax81
            Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
            08-23-2024, 09:24 AM
          • sofles
            Macbook a1707 2017 model 820-00928 GPU issue
            by sofles
            Hello there
            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
            11-21-2024, 05:25 AM
          • jesi
            MacBook Pro 820-00281-A A1707 macbook
            by jesi
            hi all techs
            require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
            adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
            update:
            when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
            08-23-2025, 02:35 PM
          • tommy97
            Apple MacBook A1707 No Audio/Sound
            by tommy97
            I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
            I've also replaced U6300, but the problem persists.
            Here are the current voltage readings:
            • PPV18_S0: 1.8V
            • R6402: 1V
            • R6405: 1V
            • R6403: 1V
            • AUD_SPKRAMP_RESET_L: 1.3V
            • PPBUS: 12.6V
            03-10-2025, 11:22 AM
          • Cemal Odabasioglu
            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
            by Cemal Odabasioglu
            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
            Observations...
            01-14-2025, 03:54 PM
