IT8350E Datasheet or Programming Protocol
  • webwicht
    • Oct 2021
    • 8
    Is there any information about the ITE IT 8350E Sensor Fusion/Hub Controller
    such a reverse engineered minimalist data sheet or a specification of it's programming protocol?
  • reformatt
    Intel iMacs, 3rd party SSD failures and Fusion setups
    by reformatt
    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
    12-18-2024, 10:34 PM
  • electomech-fixer
    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
    by electomech-fixer
    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
    09-15-2025, 01:42 AM
  • araxnido
    Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
    by araxnido
    Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
    When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
    06-10-2025, 09:26 PM
  • SoulFreeze
    Help finding datasheet for component marked G34662
    by SoulFreeze
    Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
    Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
    Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
    05-01-2025, 03:56 AM
  • Rainbow_Chameleon
    Searching Datasheet for AM113 IC by O2MICRO
    by Rainbow_Chameleon
    I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
    Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
    If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
    On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
    So if anyone has a datasheet or at least...
    01-23-2025, 12:03 PM
